Old 04-25-2010, 09:41 PM   #1
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Default 04/05 guys; anyone running PIAA fogs light in there JDM fog housings?
I'm getting a pair of JDM fog bezels, but just the bezels not the lights. After some searching I discovered you can use PIAA 540 or 580 and they will fit in the JDM housings.
Is anyone doing this? Can you please share pics and describe how good the fitment is? Which lights did you use the 540? or the 580? If you used the 580 which are 85W were you still able to use the stock wiring? Which beam pattern did you go with fog or driving lamp, and how is the output and spread of each. Does the driving lamp pattern shine low enough so not to blind on coming drivers? How much extra illumination does the fog pattern give?
Sorry, a lot of questions at once, but answers to any of them much appreciated.
UPDATE!!! Go to post #31 to see my solution
OUScooby is offline   Reply With Quote
Old 04-26-2010, 12:00 AM   #2
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
I am getting ready to buy some 540's for my JDM bezels. I thought it was the 520's and 540's that fit? How big are the 580's?
evan_impreza is offline   Reply With Quote
Old 04-26-2010, 12:04 AM   #3
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Maybe I'm wrong about the 580s, I think you're right it's the 520s or the 540, and the 540 are the 85w ones. My mistake.
But please post some pics after you get them in, and let me know how the fitment is. I'm also wondering if the PIAA rock guards (the ones that are a black grid that say piaa in white) will still fit on inside the JDM housing. I've got an idea to paint those WRB and paint the PIAA black.
Old 04-26-2010, 02:07 AM   #4
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
I guess supposedly the 540's are just a tad too small for the surround, but still fit nice. This may give you enough room for the rock guards. The 520's are supposedly a tad bit bigger but still fit..
Old 04-28-2010, 04:30 AM   #5
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
anyone else running the PIAAs?
Old 05-10-2010, 07:07 PM   #6
TheNailman
Member#: 133676
2005 WRX
bump for info.
TheNailman is offline   Reply With Quote
Old 05-10-2010, 09:29 PM   #7
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
You will have to remove the bumper cover and cut the ends of the bumper reinforcer off.
When you remove the bezels, you will see that behind the upper portion of the bezel is the bumper reinforcer. Mark it using the opening as a guide as to where you're going to cut.
As for the lamp itself, you will have to either obtain a mounting bracket for the inside of the cover (you'll see when you remove it) or fabricate your own to mount the lamp.
As for size, measure the diameter of the opening in the JDM bezel and then go onto PIAA or Hella or whatever lamp website you want to and look at comparable lamps and their respective specifications.
Good luck and have fun!
PS, you'll probably want PIAA's 510 series of lamp: http://www.piaa.com/Lamps/Lamp-pages/510.html
Old 06-02-2010, 01:59 PM   #8
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
bump.
Old 06-02-2010, 11:36 PM   #9
RichImpreza02
Member#: 106440
2004 WRX
Hey Eric!
Just FYI, my JDM fog bezels have a 5.25" opening. The 510's only have a 4"od, which will leave a pretty big gap. The 520's have a 6" total od, but it looks like if you sit the light flush, directly behind the bezel opening, it should look ok.
The 540 series have a 5 1/8"od. I think that will be the best fit.
RichImpreza02 is offline   Reply With Quote
Old 06-03-2010, 01:10 AM   #10
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
^^ Yup Ive gone over them all and feel like the 540's are the best fit for sure. Now I just need 200 extra bucks to buy the damn things..
Old 06-03-2010, 12:03 PM   #11
RichImpreza02
Member#: 106440
2004 WRX
me too
Old 06-04-2010, 01:34 AM   #12
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
So I took one of my JDM bezels with me to an off road accessory shop, and placed a couple PIAAs in it to see how it looked. The 520s lens was a perfect size for the hole, but the lamp itself was too large to fit flush behind the bezel. The 540s fit inside the bezel, but were too small there was about an 1/8th in gap all around the lamp. This gap may not look that bad once it's in the bumper and there is just darkness behind it. Would still like to see some pics of someone running these before I decide.
Old 06-15-2010, 08:30 AM   #13
RichImpreza02
Member#: 106440
2004 WRX
Just out of curiousity, how are you guys setting up your DIY foglight mounting brackets. At this point mine are just some strips of metal with mounting holes, kind of in a cross. This causes the mounting point to have to be at the top of the light, which usually means an upside down lamp.
I have to redo the whole setup this weekend since I just had a new front end put in. Looking to see what better methods may be out there.
Thanks.
Old 06-15-2010, 12:33 PM   #14
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Take some pics of your setup and share them here please.
Old 06-15-2010, 01:53 PM   #15
RichImpreza02
Member#: 106440
2004 WRX
well i would but it's pretty much back to stock. the car got banged up and i needed to replace the drivers headlight, bumper beam, fogs, etc... so as soon as i figure out where i want to order my piaa 540's from, and get them in my hands, i'll be able to work on how i want to mount them.
The old setup was with some crappy SS driving lights. I have no idea how the mounting points will vary from what i had before, so i'm wondering how others are mounting PIAAs in a jdm fog setup before i start my own reiteration.
Old 06-15-2010, 02:17 PM   #16
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
That's my lingering question at this point, how to mount them. Post some pics of the bracket you used for you SS, at least it'll be a starting point to figuring out how to mount the PIAAs. I'm guessing they don't mount too different from the SSs, just a post mount. The PIAAs may mount in a slightly different spot, but the idea should be the same.
Also if you have any old pics with the SSs on the car post those to please.
Old 06-15-2010, 02:18 PM   #17
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Take some pics of the OEM fog-lamp mounting brackets for me and I'll come up with some ideas.
Old 06-16-2010, 08:58 AM   #18
RichImpreza02
Member#: 106440
2004 WRX
I can't access my photobucket stuff, or even see linked photobucket pictures here at work, so I'm just copying the code out of an old thread when I installed the lights, I don't remember what the pictures are exactly, but I know they are of the car with the fogs installed. I don't think I have any of the actual mounting hardware.
Old 06-16-2010, 11:46 AM   #19
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
I meant the USDM OEM hardware (that the USDM OEM foglamps were attached), not the shady-tree mechanic mounting brackets for the aftermarket lamps.
Old 06-16-2010, 12:17 PM   #20
RichImpreza02
Member#: 106440
2004 WRX
I'll be getting home late tonight, but I'll try to remember to go out to the garage and take some pictures.
Just ordered a set of piaa 540 plasma ion fogs.
Old 06-16-2010, 03:56 PM   #21
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
^^ Ill be waiting for updates
Old 06-17-2010, 12:21 PM   #22
ryan2.5
Member#: 167205
2004 N.F.D
04 STi. FP Red + Meth
i have been pulled over twice by running my jdm fogs at night so i dont even use them anymore. some nice pics.
ryan2.5 is offline   Reply With Quote
Old 06-17-2010, 01:39 PM   #23
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Really? 'Cause I've got 4 Hella 500ff on a light bar up front on my car, I drive with the two center ones on all the time, cops don't even give me a 2nd look.
Old 06-21-2010, 01:06 AM   #24
ryan2.5
Member#: 167205
2004 N.F.D
well both times were by state trooper late at night so probably just an excuse.
Old 06-28-2010, 09:19 PM   #25
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
bump for updates
04-05 Aspen White fog lights in PDX wrxSTIcy NWIC Private Classifieds 4 01-25-2010 01:03 PM
JDM 04-05 BIG WRX fog lights in WRB djtrickstick Exterior/Styling 13 10-09-2009 11:40 PM
For Sale: NEW IN BOX JDM FOG LIGHTS FOR 04-05 WRX and STI ION BLUE syoung0298 Exterior/Styling 15 06-14-2009 08:57 PM
FS: PIAA Fog Lights & MY98 RS Fog Lights H5N1 Private 'For Sale' Classifieds 0 01-06-2006 03:47 AM
Will Piaa fog lights plug into stock fogs wanna ride in a sti Interior & Exterior Modification 4 08-23-2002 12:54 AM
