Old 04-25-2010, 10:25 PM   #1
norcalwrx816
Member#: 203489
03 wrx wagon
flat4/Mayhem Tuning!
Default problems
im having a problem un-marrying my AP V.2 for some reason i have everything hooked up correctly but then it says can not communicate with ecu
norcalwrx816 is offline   Reply With Quote
Old 04-27-2010, 06:56 PM   #2
zozza8
Member#: 118486
2003 WRX
I had a similar problem, I disconnected the battery over night and tried it again in the morning and it worked. I know, not very technical but it did work...
zozza8 is offline   Reply With Quote
Old 05-21-2010, 05:44 PM   #3
Cobb Tuning
Member#: 4803
Did you recently update your AccessPORT when this occurred? Have you been able to rectify the situation? Are you able to connect to your PC through AccessPORT updater or Manager?
Travis
COBB Tuning
Strange "overheating" problem on 02 WRX TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-07-2010 12:41 PM
Is there engine problem with the 2011 STI? speed12sil Warranty Issues & SOA Problems 19 06-14-2010 11:10 AM
A/C problem - Yes I've searched... GatoEnFuego Service & Maintenance 1 06-05-2010 10:23 PM
OpenECU timing problem check out logs vwjettavr67 Open Source Reflashes 7 06-05-2010 08:27 PM
Problems...Problems...Problems... ashtaron14 Vancouver Impreza Club Forum -- VIC 12 04-17-2001 01:00 AM
