Old 04-25-2010, 11:36 PM   #1
Xsile STI
Member#: 202961
2005 STI
Default Please Check My Data Log (New logs added)
So far I only have knock learning -2.1 at 2443 & 2532 RPM, would this be a problem? If their is anything else wrong let me know.
My mods are:
Cobb Stage 1 91OCT map
Unknown Cat-back Exaust 3inch
K&N Typhoon (SRI)
HKS BOV "will get rid of soon for stock BPV or turbosmart dual port BOV"
Sorry about the image size 1st time trying to post data log
Thanks
Xsile STI is offline   Reply With Quote
Old 04-26-2010, 12:07 AM   #2
kh15
Member#: 132400
you need to run wot or the logs are not really that helpful. right now your only showing around 50% throttle!
kh15 is offline   Reply With Quote
Old 04-27-2010, 08:51 AM   #3
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
I agree with above poster but at the same time you might get your wot tune perfect but other load points might knock.50% throttle needs to be tuned even more than 100% because your not 100% throttle that often.
scoobystas is offline   Reply With Quote
Old 04-27-2010, 11:10 PM   #4
Xsile STI
Member#: 202961
2005 STI
I hope this is a little better.
http://spreadsheets.google.com/ccc?k...DS0hEbEE&hl=en
Their were some bumps in the road. I will try another 4th gear pull this weekend.
Thanks
Old 04-27-2010, 11:50 PM   #5
kh15
Member#: 132400
Thanks
are you logging via ap or are you using romraider?
you need to floor it man, the logs look fine but you need to get your rpms to 2k in 4th and floor it to 6k, dont let up!
Old 04-30-2010, 02:09 PM   #6
Xsile STI
Member#: 202961
2005 STI
I am using the AP to log.
Here are 4 logs to check out, did these last night.
http://spreadsheets.google.com/ccc?k...WdXhvYXc&hl=en
Thanks
Old 04-30-2010, 04:17 PM   #7
burnrubber
Member#: 233517
2005 WRX
Looks like your IDC is too high, at 107% at its highest point. To fix the problem I am unsure but hold off pushing the car untill the problem is fixed.
burnrubber is offline   Reply With Quote
Any Tuning gurus want to check my data log? 3s-gte AccessPort 0 07-15-2009 09:57 PM
Please read my data logs. Joel21Wolter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-30-2008 02:58 PM
07 STi w/ tuned Enginuity... fuel learning / running rich? please check my logs... TROLL Commercial ECU Reflashes 26 11-21-2007 01:51 AM
Please Check My Logs clemsonteg UTEC 4 08-28-2007 06:30 PM
Please check my logs from today MidRex UTEC 15 04-14-2006 10:38 PM
