Old 06-06-2002, 12:55 PM   #1
bluimpreza00
Member#: 19094
2002 Impreza WRX
Wagon- Black
Question ?'s about Ludespeed Stage 1
I am thinking about buying a Ludespeed Stage Turbo Kit I have a 2000 RS. I would just like to know some information about any that has put one on.
1.How did it take to ship?
2.Did you have any trouble putting it on?
3.How did it take to put it on?
4Have you broke anythink with the kit on?
5. and any other comment that would help me decided on what to do
thanks, Matthew
bluimpreza00 is offline   Reply With Quote
Old 06-06-2002, 02:48 PM   #2
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
just ordered mine from Tom after about 6 month of reading and learning about turboing the 2.5L
try to contact Elliot, i know installed one on a 2002 like mine.
you should probably get Stage II kit because of the top mount IC and your air scoop, i am sure it would be well worth it.
make sure you get he fuel pump, J&S, gauges for fuel, and EGT.
also make sure you read every single post on this forum!!
rupteur7000 is offline   Reply With Quote
Old 06-06-2002, 04:05 PM   #3
spiralsmurf
Member#: 16085
2005 STi
rupteur7000 - which stage did you get? from all your research, how safe is it to run the stage 1 at low boost. like will it be fine for 10k? if I get a top mount ic, will it be just as reliable in the longterm as a stock car? because i want to keep my car as long as possible. i like mine more than the wrx.
spiralsmurf is offline   Reply With Quote
Old 06-06-2002, 04:06 PM   #4
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
even though the intercooler costs 700 more, it is worth it. and it makes the set up safer. as for tuning, you can get a link plus ecu for about 1500 bucks (about the same as an ITC, RRFPR, FPR, J&S, and the many gauges needed). with a laptop, you can have the gauge display out and it will show boost, knock, injector duty cycles and everything else you want to know. this may seem like a lot of money to you but there is no real way to do cheap forced induction. also, get the upgraded turbo. even at low boost settings, it pulls extremely hard. to sum up, stage 2 kit w/ upgraded turbo and a link plus.
KillerTHC is offline   Reply With Quote
Old 06-06-2002, 06:00 PM   #5
spiralsmurf
Member#: 16085
2005 STi
what is the upgraded turbo i.e. name, specs? also all those parts the ITC, RRFPR, FPR, J&S come with the kit right? If i asked ludespeed to not include these parts would it be cheaper? because that would offset the cost of a link. also I can get a wrx ic for less than $500 so i'd rather just do that.
Old 06-06-2002, 10:21 PM   #6
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
the upgraded turbo is a t3/t04b. it's the same turbine size as the the stage 1/2 but has a much larger compressor and therefore it displaces more air. as for using a WRX IC, good luck. i was gonna use it but the BOV and the throttle linkage are in the same exact spot so you will have to get creative with your BOV install. as for the piggy backs, the only kit that comes with any is the stage 3. the stage 1 has a cartech RRFPR but if you tell Tom not to include it, he will. Tom is really good about getting parts you want and parts you don't.
Old 06-06-2002, 11:20 PM   #7
spiralsmurf
Member#: 16085
2005 STi
hmm. well about the ic, my guy says he can do it. let him get creative.
Old 06-07-2002, 08:41 AM   #8
rupteur7000
Member#: 11585
02 2.5RS
the best way to figure out what you need is to call Tom, his phone number is on the first page of his site. great guy.
everything that is in the kit that you don't need/want he will credit you for.
Q
Old 06-07-2002, 11:15 AM   #9
spiralsmurf
Member#: 16085
2005 STi
cool. so what did you install? stage 1?
Old 06-07-2002, 11:27 AM   #10
rupteur7000
Member#: 11585
02 2.5RS
i haven't installed it yet, as i said i just ordered it and it'll be here in 3-4 weeks.
Old 06-07-2002, 11:28 AM   #11
rupteur7000
Member#: 11585
02 2.5RS
but i played a lot with G60 for a while, so i am assuming it should be easy
Old 06-07-2002, 03:48 PM   #12
spiralsmurf
Member#: 16085
2005 STi
g60? like a corrado g60?
some questions about COBB stage 1... ChrisWRB Engine Management & Tuning 8 07-04-2005 07:06 PM
Questions about cobb stage 2 03mbpREX Engine Management & Tuning 7 08-20-2003 10:35 PM
Question about ludespeed and gt-spec headers pimpomtic Normally Aspirated with bolt-on Forced Induction Powertrain 7 06-02-2003 07:42 PM
question about txs stage mapping Jerry Seagreaves Factory 2.0L Turbo Powertrain 1 03-26-2003 03:17 AM
Question about txs stage 2 unichip Carlito2002WGN Factory 2.0L Turbo Powertrain 5 02-25-2003 08:00 PM
Message Board Statistics All times are GMT -4. The time now is 10:58 AM.
