Old 08-12-2010, 06:38 PM   #51
Ryan314
Member#: 82989
Hybrid EJ257
^Thank you for that information. So on the STI, the plastic/metal pipe that connects the valve breathers, is that a 5/8 hose fitting?
We installed a crankcase evacuation system on mine yesterday. Welded a bung and check valve to the downpipe at a 45 degree angle. A hose then goes from the check valve to the crank case port (near the turbo) and PCV.
It certainly works, providing constant vacuum to the crank case.
Will it cure my oil consumption problem? Time will tell.
Ryan314 is offline   Reply With Quote
Old 08-13-2010, 12:12 AM   #52
sidewayz
Member#: 5810
2001 S366 2.5RS
Im not using a check valve in my evac system. I just deleted all of my pcv stuff and welded this in
http://vibrantperformance.com/catalo...oducts_id=1243
sidewayz is offline   Reply With Quote
Old 08-15-2010, 10:43 AM   #53
crashtke
Member#: 120912
Do some testing. Hook a boost gauge up to your crank case vents. We did not have very good results with a similar part. Crawford had similar experiences when they tested the same set up.
crashtke is offline   Reply With Quote
Old 08-16-2010, 02:47 PM   #54
sidewayz
Member#: 5810
2001 S366 2.5RS
600 miles later. motor is still fine, no smoke, no oil loss. She's working as planned
Old 08-16-2010, 02:53 PM   #55
crashtke
Member#: 120912
Cool stuff. It may have just been the motor that it was on. It had excessive blow by any ways from a mechanical issue.
Old 07-12-2011, 03:41 PM   #56
sorrowfulkiller
Member#: 170439
I <3 Lamp
Wanted to bring this up from the dead has anyone got any more to add to this thread?
sorrowfulkiller is offline   Reply With Quote
Old 07-16-2011, 02:40 PM   #57
Paulys05wrx
Member#: 82433
2005 STi EFR 6738 &
WRX EFR 8734 Twin Scroll
I have mine un-capped, and T'eed into the drivers side head breather. I recently tore down my intake and noticed a lot of oil through out the intake track... I have been consuming around 1/2 quart every 1000 miles. I purchased a catch can last week and will install it in line with the breathers to capture the blowby.
On a side note, I posted many many times years ago concerning leaking cam seals, and sure enough I went through 2 or 3 of them right after my initial build due to having the port blocked!
Paulys05wrx is offline   Reply With Quote
Old 07-16-2011, 02:46 PM   #58
AREA1320
Member#: 112508
You are consuming oil because you have an OIL breather t'd into a vapor line.
AREA1320 is offline   Reply With Quote
Old 08-01-2011, 10:34 PM   #59
eliezerrosario
Member#: 141949
2004 Wrx
JBP
Sorry if this is going to sound dumb but I'm going to throw it out there anyway:
Has anyone tried running a catch can and an AOS?
1) The catch can for the head breathers and pcv
2) the AOS would be for the 2nd crankcase vent.
Anyone?
eliezerrosario is offline   Reply With Quote
Old 08-06-2011, 01:17 AM   #60
samson05
Member#: 278836
2005 wrx,wrb
2005 forester xt,psm
i am running a grimmspeed aos and have the center breather t'd in with the other breathers and have no issues with blowby.all of the hoses are oil free!
samson05 is offline   Reply With Quote
Old 08-08-2011, 07:38 PM   #61
justooln2
Member#: 258482
I've posted this elsewhere. But here it is again.
I think this is a great picture for this (borrowed from slorice):
For 2.5 heads - it makes sense to hook up the new 2.5 block breather.
For 2.0 heads...[/quote]
Good Reference, here is how my Hard Breather line ended up. 200 Miles on New Hybrid, with 272 Cams, No problems yet. still tuning.
justooln2 is offline   Reply With Quote
Old 10-08-2011, 12:17 PM   #62
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Double post
5lipstream is offline   Reply With Quote
Old 10-08-2011, 12:23 PM   #63
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
On the 257 valvecovers, the plastic piece has dual barb fittings where the 205 has only one. My question is: on the 257 piece, are the 2 ports simply side by side and go to the exact same place in the valvecover or are they separated? I'm just wondering if I machine a new piece that has dual fittings to replace the plastic single port piece if that will work for the center crank vent routing.
Old 10-11-2011, 07:37 PM   #64
quicksubie
Member#: 221140
2005 hybrid=fun :-D
93 L 2.5rs rally preped
how well is this working for you and teh motor?
i am in the same boat as everyone else, i have ej257 hybrid setup and need to do a catch can or might be thinking this route as i would not have to worry about emptying it.
quicksubie is offline   Reply With Quote
Old 10-13-2011, 02:02 AM   #65
quicksubie
Member#: 221140
2005 hybrid=fun :-D
anyone have any input or experience using the evac setup way instead of a catch can?
Old 10-13-2011, 10:01 AM   #66
sorrowfulkiller
Member#: 170439
I <3 Lamp
Why don't you do both? Have a catch can in line with the exhaust evacuation line and check valve. You could probably even drain it back into the pan if you wanted to.
Old 10-13-2011, 06:32 PM   #67
quicksubie
Member#: 221140
2005 hybrid=fun :-D
then what would be the point of a catch can with the evac setup also?
my whole point in the catch can vs evac setup is that the evac setup there is nothing to drain it just gets burned up ones it hits the dp, catch can i will have to empty it and i dont feel like going the routing it back into the pan way either.
Old 10-13-2011, 11:28 PM   #68
quicksubie
Member#: 221140
2005 hybrid=fun :-D
anybody else have any input on this or experience with a evac setup.
theres got to be more people that can help shed some light on if this evac setup will work and or how it would work.
Old 10-16-2011, 10:55 AM   #69
sorrowfulkiller
Member#: 170439
I <3 Lamp
The point of it would be that the exhuast velocity creates a vacuum, pulling the oil through the hoses into the catch can where it will hit some turbulence (in a proper catch can) and then be drained out the bottom back into the pan. That way you don't have to ever drain it and it will always have a true source of vacuum, unlike the intake pre-turbo, which would pull way too much vacuum and just suck it right out of the catch can. Honestly its the best way unless you buy an air pump and use that as your vacuum source.
Old 10-23-2011, 03:02 AM   #70
future_subaru_owner
Member#: 172939
2011 Dodge Ram 3500
2003 Subaru Legacy L..ame
I'm running a Ej257 Shortblock with 2.0 Heads. Tomorrow I will be taking off my valve covers and tapping both VC's then T'ing the center crank case breather into the VC's.
I will update as soon as i finish.
future_subaru_owner is offline   Reply With Quote
Old 10-23-2011, 09:58 AM   #71
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
I want to caution you guys about draining your catchcan back into your oil pan. What gets caught in the can is not just oil. You have unburnt fuel and condensed water vapor in there too. Dumping that back into the system is a recipe for disaster. Don't believe me? Empty your can into a glass jar and let it sit a while to separate. Yuck.
Edit: for clarification, running the line from the center, unbaffled port on the 2.5 block into the valve covers is correct. What I stated above is in reference to the mess the catchcan pulls out of the other ports.
Old 10-23-2011, 01:45 PM   #72
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
If its draining back to the pan its a air/oil seperator, a catch can does just what its called. Im using the crawford aos and have been thinking of using a evac bung instead for vaccum, the large turbos pull way too much. Also the stuff that drains back to the pan will get burnt back up after the motors warmed up. I havent had any problems with it other than it pulling more vapor through it than I want after some high boost runs.
scby rex is offline   Reply With Quote
Old 10-23-2011, 06:18 PM   #73
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
I think you are fine with the Crawford piece as it was designed properly. The Grimmspeed AOS is a terrible design.
Old 10-27-2011, 02:53 PM   #74
saabarumedude
Member#: 299199
2005 Saabaru 9-2x
Can someone clarify the need for this. Is it just for high boost applications?
I am building a MILD hybrid using the stock TD04, Tuned for E85. Not sure how much boost it will be capable of? 15PSI maybe if I'm lucky.
Can I cap the extra crankcase breather? Or maybe just run the breather to ONE of the valve covers?
Seems like the pressure under the valve cover should be equal to the pressure in the crankcase, so what is the point of the plumbing?
Thanks
saabarumedude is offline   Reply With Quote
Old 10-27-2011, 04:30 PM   #75
Strider327
Member#: 131280
2004 Impreza WRX
Wouldn't an AOS solve this problem?
Strider327 is offline   Reply With Quote
PCV and Crankcase ventilation Question hustleshark206 Newbies & FAQs 4 08-20-2009 08:36 AM
Help me get a better grasp of crankcase ventilation gpatmac Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-06-2006 02:45 PM
hybrid crankcase ventilation sonic rx Built Motor Discussion 23 09-15-2006 09:27 PM
Crankcase Ventilation and Lateral Gs SloRice Built Motor Discussion 41 08-10-2006 04:43 PM
really need!! crankcase ventilation (blow by) valve Seeinstars Private 'Wanted' Classifieds 3 07-30-2005 06:51 AM
