Old 04-26-2010, 11:34 AM   #1
Mr Evolution
Member#: 103333
Default WRX 4pot calipers fit on '04 LGT???
Like the title states:
Will the WRX Red 4pot calipers fit on '04 LGT non-turbo???
Mr Evolution is offline   Reply With Quote
Old 04-26-2010, 11:37 AM   #2
aross
Member#: 831
11 Blurple WRX
03 BH MBP
yup. 123
aross is offline   Reply With Quote
Old 04-26-2010, 12:20 PM   #3
Mr Evolution
Member#: 103333
Originally Posted by aross View Post
yup. 123
Are there any pics?
Thanks
Old 04-26-2010, 12:34 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
You'll most likely need 17" wheels to clear the calipers.
Legacy777 is offline   Reply With Quote
Old 04-27-2010, 10:12 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
No, you don't. certain 16's can fit (like the 2.5RS 6 spoke and 5 spoke wheels).
My old autox setup (16" wheels w/ shorter sidewall R compounds), over 4 pots.
more pics of the old FHI 4pots
rougeben83 is online now   Reply With Quote
Old 04-28-2010, 12:52 PM   #6
Legacy777
Member#: 4800
I said most likely because I wouldn't think a lot of people have those specific 16" wheels
Old 04-28-2010, 04:21 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
It's not even "specific", it just needs a 7"+ width and 45-48 offset to clear the back of the spokes, I've had about 4 random sets of 16" wheels that I've picked up off CL that cleared my old 4 pots fine. There's nothing too impressive about the brakes themselves either, there's a marginal increase in pedal feedback, but youre still using the same size rotor.
The fun begins when trying to find 15inch wheels that will fit over them.
Old 04-30-2010, 03:55 PM   #8
iluvdrt
Member#: 46248
82 Brat
Tan
Dude there is a huge diff in performance over the stocks. Also, the rotors are not the same size. The 4 pot rotors are about 1/2" larger (than my 98 2 pot OEM's at least) and brake fade is largely reduced. IIRC the rotors are as follows:
pre my00 2 pots= 260x24 mm
post my00 2 pots= 276x24mm
wrx 4 pot rotor=294x24mm
So in my case I gained a 34mm larger rotor. NTL 18mm is still a good change.
I also have the two pots though and SS lines. Maybe the combo helps more then just the fronts. These brakes and the 5 spd conversion were the best mods I have ever done.
iluvdrt is offline   Reply With Quote
Old 05-01-2010, 01:12 AM   #9
jamal
Member#: 71875
98 Legacy GT
my wheels fit
1-pots are 260mm. The small 2-pots are 276mm. They're on 1st gen turbo legacies, and then later LGTs and outbacks and whatnot. Sometime around 02 the LGT got 294mm rotors, and then 316mm for 05.
jamal is offline   Reply With Quote
Old 05-01-2010, 07:22 AM   #10
iluvdrt
Member#: 46248
82 Brat
Tan
Gotcha. So depending on the year your car is, the rotor size may not be increased by doing this conversion.
I still gained quite a bit though, the copnversion was def worth it for me.
Thanks! I couldnt remember what was what. I could only remember the sizes and numbers.
IBRainman
Old 05-01-2010, 03:14 PM   #11
jamal
Member#: 71875
98 Legacy GT
my wheels fit
http://forums.nasioc.com/forums/show....php?t=1265631
according to this 02 lgts got the bigger brakes. That was one part I wasn't completely clear on though.
Old 05-01-2010, 07:06 PM   #12
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The fun begins when trying to find 15 inch wheels that will fit over them.
15x8" +45mm TE-37s fit.
The permanently encrusted brake dust only helps the fitment.
Old 05-01-2010, 10:01 PM   #13
iluvdrt
Member#: 46248
82 Brat
Tan
I do hate how darn dusty they are. I have Axxis pads and I can was my wheels, drive around the block and they are black again.
Old 05-07-2010, 11:58 PM   #14
Mr Evolution
Member#: 103333
Nice, good info, I am gonna stay with my '04 LGT setup than. Save the money for swap.
I will in the future move up to '05 Legacy Front caliper and disc and '04 H6 rear disc and caliper.
Old 05-08-2010, 12:02 AM   #15
Mr Evolution
Member#: 103333
Are you brake setup still the FHI 4pots, with the turbo engine???
Any brake fade???
I am not sure if you track your car or not as far auto X or Actual Time Attack
Old 05-08-2010, 12:09 AM   #16
Mr Evolution
Member#: 103333
Nice wheels, must be so light in weight.
The Work lug nuts are super light weight too. I have them on the other car I've got
Old 05-08-2010, 03:59 AM   #17
rougeben83
Member#: 115154
2005 Outback XT
White on grey
You already have the "H6" brake upgrade stock. All 00-04's came with 11.4" rear brakes. You can measure yours to double check, but do it before you actually buy the parts.
Old 05-08-2010, 07:09 PM   #18
Mr Evolution
Member#: 103333
I meant the vented rear disc
Old 05-09-2010, 08:45 AM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
9.5#, wheel/tire combo is about 29.5#.
They're actually the RAYS ones. From pictures I've seen of the two, I wouldn't be at all surprised if they're made by the same manufacturer and just have the different brand name on the end - they look identical other than the name.
Then that's the '05+ 2.5GT setup.
Old 05-09-2010, 07:38 PM   #20
rougeben83
Member#: 115154
2005 Outback XT
White on grey
yeah like pat said, 05+LGT setup, its still the same rotor diameter though, and honestly your rear brakes do very little work as it is, the possibility of fade back there is low.
Old 05-09-2010, 09:55 PM   #21
iluvdrt
Member#: 46248
82 Brat
Tan
If you havent already done it, get the stainless brake lines. They increase pedal responce and feel drastically. They are pretty cheap too. Also get a good fluid. I personally use Valvoline synthetic dot 4 fluid and have liked it a lot.
Old 05-10-2010, 12:19 AM   #22
Mr Evolution
Member#: 103333
I have the SS lines installed when it was time to replace the pads and I sheered the caliper bolt. I previous owner must have had some mechanic way over tightened or it just rusted in place. At that point I just ordered Semi-loaded front GT calipers and fr & r rotor disc.
I also flush the fluids out with Motul RBF600, but I will reflush it and put something else in. I had a lot of it left from a track car I setup.
Old 03-10-2015, 10:44 AM   #23
devine801
Member#: 364226
Is there anything else that needs to be upgraded? Or will these just fit right on? By that I mean master cylinder, anything along those lines?
devine801 is offline   Reply With Quote
02 WRX rims on an 06 WRX - Will caliper fit ? 2subiesinyard Tire & Wheel 6 08-26-2007 03:14 PM
Will 06 4pot calipers work on my 04?? longshot454 Brakes, Steering & Suspension 5 08-24-2006 02:04 AM
Will 06 WRX Front and Rear Calipers fit on my 05 WRX? mrtrex Brakes, Steering & Suspension 2 01-06-2006 09:04 PM
Will '02-'03 WRX springs fit on '04 WRX? SonicJLee Brakes, Steering & Suspension 0 04-16-2003 07:35 PM
4pot caliper swap on WRX question. Leonardo Brakes, Steering & Suspension 19 04-26-2001 12:41 AM
