Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 06-06-2002, 01:38 PM   #1
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Arrow Oil analysis on my destroyed 4EAT
Fluid came back with elevated Fe, Pb, and Al, and elevated oxidation, but is still "suitable for continued use."
I'll post the detailed report tomorrow when I get into the office.
Cheers,
/Andrew
Kha0S is offline   Reply With Quote
Old 06-06-2002, 02:48 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Re: Oil analysis on my destroyed 4EAT
Cheers,
/Andrew
Thanks bud!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 06-06-2002, 04:33 PM   #3
Willman67
Member#: 3439
2001 Chevy 2500HD
Mean Green Machine
Default what happened?
How did your 4eat frag? I'm curious about the circumstances.....or did I miss a post?
I used to us a "total analyzer" when I worked at DuPont/Conoco oil which gave a total elemental breakdown in oils...you could tell so many things about fleet maintenence and failure prediction!
Wm
Willman67 is offline   Reply With Quote
Old 06-07-2002, 09:51 AM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Willman -- you missed a post. Search for 4EAT and kaboom.
Here's the detailed analysis:
Date: 5/22/2002
Component: 41200/M
Oil: 3400/M
Oil Chng: Y
Glycol: Neg
Water %: < 0.05
Viscosity: 40*C: NA
Viscosity: 100*C 5.3
Solids %: TR
Oxd %: 31.1
Nox %: 4.3
TAN: 0.36
(in ppm)
Fe: 70
Pb: 25
Cu: 14
Sn: 2
Al: 27
Ni: 3
Mn: 4
Si: 23
B: 36
Na: 7
Ca: 237
P: 487
All other values were either 0 or N/A.
20020528006 -- Results of tests performed indicate:
Wear metal(s) underlined are elevated
Oxidation elevated
Oil is suitable for continued use
Resample at next regular interval
According to this, it seems that my fluid was just fine, and that heat failure was, most likely, not the reason why my 4EAT failed.
The elevated wear metals aren't particularly enlightening since this was the fluid inside the tranny when it all went, but the oxidation level, commonly very high with heat damage, is still within the operable range.
Hope this helps any of you hardcore 4EATers prevent similar destruction of your gears. Big thanks go out to Jorge (RiftsWRX) for the sampling kit to get this data.
Later all,
/Andrew
Old 06-07-2002, 12:32 PM   #5
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Maybe the gears were defective or weak. Would showing the oil anaylsis to Subaru do any good?
WRX_02_227 is offline   Reply With Quote
blackstone labs first analysis on my 2.0L ! paintballjunky Service & Maintenance 12 11-30-2006 01:05 AM
Oil analysis on German Castrol Syntec 0W30, 5,930 miles, FXT bluesubie Service & Maintenance 8 03-26-2005 10:06 AM
Oil analysis on WRX /M1 10W30 bluesubie Transmission (AT/MT) & Driveline 1 08-13-2003 09:04 AM
Oil leak on my WRX.. Where is the PCV? Wheels Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-14-2002 07:38 PM
first oil change on my WRX rex_ruthor Bay Area Impreza Club Forum -- BAIC 3 01-31-2002 03:19 AM
