Old 04-26-2010, 05:25 PM   #1
Tommi300
Member#: 238537
Default How do I log for fuel pumps?
There have been a batch of dodgy 255lph walbro fuel pumps knocking about but how would I know if mine was flowing 255lph or not with flow testing, is there some little trick with RR?
Cheers
tommi
Tommi300 is offline   Reply With Quote
Old 04-26-2010, 05:41 PM   #2
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
The only parameters I am aware of for logging the FP are the FP Duty cycle, Fuel pressure and fuel tank pressure depending on which ECU you have 16 bit or 32 bit.
Brock31 is offline   Reply With Quote
Old 04-26-2010, 05:45 PM   #3
Tommi300
Member#: 238537
I tried logging Duty cycle and it goes up to 100% but then again so would a faulty one, just wondered if there was anything else to look out for.
Old 04-26-2010, 11:59 PM   #4
Jubert69
Member#: 167739
04 WRX
I would think your injector duty cycle would show a bad fuel pump. But this could also throw faulty injectors to the mix.
But of course you could connect a FP gauge(I know this doesn't answer your main question)
Jubert69 is offline   Reply With Quote
Old 04-27-2010, 11:05 AM   #5
Tommi300
Member#: 238537
The reason I ask is that when I mapped the car it was running sweet 11.5's using a LC-1 it was running 12's etc the other day so i had to richen it up. Could this be a fuel pump on its way out?
Old 04-27-2010, 11:39 AM   #6
Jubert69
Member#: 167739
04 WRX
Could be many things, how much did the temperature change?
how do you test a fuel pump relay fyr3 Newbies & FAQs 2 04-04-2013 05:38 PM
how do you to that fuel pump? drewwrxrogers Water/Methanol Injection, Nitrous & Intercooler Cooling 18 12-01-2006 06:47 PM
How do I test for faulty Fuel Pump?? gtwagon941 Legacy Forum 4 10-03-2005 08:07 AM
how do my logs look? new map WRXout Engine Management & Tuning 26 03-22-2005 11:52 AM
how do install a walbro fuel pump Jimmy Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-04-2001 04:06 PM
Message Board Statistics All times are GMT -4. The time now is 02:18 AM.
