Old 04-28-2010, 01:56 AM   #1
Rod702
Member#: 132978
2004 Mike angel tund
efr 7670 1.05 Twiscroll
Default dyno tune 2.35L Ej22t sti heads gt35r 571 whp @ 25 psi
its come a long ways, still needs more work. id2000's will be the next round.
big thanks to kert millerspec.com, mike @ cnc motorsports.
dyno pull
Temp: 76 F
elevation: 2028 above sea level
weather: cloudy
Car: 2004 wrx
Tuner: Kert Miller Millerspec.com
Dyno: dynocom dc pods
transmission: 5 speed 1-4 ppg helical synchro stock 5th
All pulls were in 3rd gear
base line pull: 07 sti stock 251 whp @5700 rpm
target boost: 30 psi
Peak Torque at RPM: SAE J1349
Target Boost: 30psi
Target AFR: 10.8 @ 28psi
Fuel: E85 105 Octane Unleaded
mods:
engine:2.35L ej22t block: sti crank, pauter forge rods, cp forged pistons, stock sti heads. all blueprinted balanced, built by revolutionmotorsports in Colorado by adam (drac9 on nasioc)
Custom Perrin gt35r .82 a/r rotated kit full 3" downpipe, anti surge housing tial 44mm wastegate. Arc ram intake. Perrin equal length headers, 3" custom full catback.
Fuel: e85, walbro 255 feeding custom coverperformance surgetank feeding bosch 044 external pump. sard 110psi max fuel reg, Bosch ID1000's injectors, aeromotive fuel rails, push lock an fittings.
cooling: Greddy grex oil cooler, blitz radiator, Full race Reverse FMIC, tial bov. crucial thermostat.
drivetrain: PPG 1-4 helical synchro trans, Twin exedy clutch, r160 quaife lsd rear diff.
Electronics: HYDRA 2.5v EMS closed loop, aem digital gauge: fuel pressure, oil pressure, coolant temp, boost, apexi egt.
dyno plot @ 25psi
Uploaded with ImageShack.us
dyno plot @ 24 psi
Rod702 is offline   Reply With Quote
Old 04-28-2010, 02:58 AM   #2
mashedpaters
Member#: 167462
2003 wrx
sedona red
what does a stock sti or wrx pull on this dyno and why are you only revving to 7k?
mashedpaters is offline   Reply With Quote
Old 04-28-2010, 03:04 AM   #3
JustinV
Member#: 239875
2010 STI
bro, the music is real tight but I'd like to actually hear your car.
JustinV is offline   Reply With Quote
Old 04-28-2010, 03:26 AM   #4
GDB FAN
Member#: 105814
I'll throw down another vote for the music.
What kind of fuel you using?
GDB FAN is offline   Reply With Quote
Old 04-28-2010, 03:51 AM   #5
Rod702
Member#: 132978
i guess rise against is not on the top 25 list. E85 is the fuel consumed.
Old 04-28-2010, 03:54 AM   #6
Rod702
Member#: 132978
ill get back to tomorrow on the stock numbers. stock sti heads, 7200 is rev max set on hydra. the dip your seeing at end is because we are maxing out injectors at 25psi.
Old 04-28-2010, 08:06 AM   #7
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
We have a required format for posting dyno tunes/pulls and 1/4 mile times in prove power bragging. You can find the format here. Please update your first post when you get a chance. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 04-28-2010, 08:22 AM   #8
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
This is crank hp?
wrxwhat is offline   Reply With Quote
Old 04-28-2010, 10:00 AM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
no mod list, no care nice numbers though.
edit: saw the mod list in the video
Old 04-28-2010, 10:38 AM   #10
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+1^^^ mod list...
rexworx is online now   Reply With Quote
Old 04-28-2010, 10:57 AM   #11
javid
Member#: 54304
04 STi
TopSpeed-dAng!
That dyno chart is hard to read.
Does it show that you are losing power from 5600 to 6300 and then making power again???
why would this happen?
javid is offline   Reply With Quote
Old 04-28-2010, 11:21 AM   #12
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
+ 10000000 I hate when people do that!!! I want to hear your engine!!!
Also where is the mods list?? i see that your running e85...thats it
BlackJavaPearl04 is offline   Reply With Quote
Old 04-28-2010, 11:59 AM   #13
Rod702
Member#: 132978
ok stock pull 07 sti 251 @ 5700rpm on this dyno.
majority of mods are in beginning of video.
Old 04-28-2010, 01:05 PM   #14
nhat
Member#: 140163
03 STi
hellaflunctional
your thread is gonna be locked if you don't follow the format stated in this thread...
Old 04-28-2010, 01:44 PM   #15
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
Need to clean up timing, that dip can be reduced with a nicer curve.
j255c is offline   Reply With Quote
Old 04-28-2010, 02:37 PM   #16
javid
Member#: 54304
04 STi
TopSpeed-dAng!
They indicate it is due to fuel but it makes no sense.
The fuel system was capable of making 570 hp at 5600 but only ~500 hp at 6000... Most tunes I see have the same AFR at 5500 as 7000 rpms. Unless they decided to run a good bit richer above 5500 the dip has to be something else...
Old 04-28-2010, 09:31 PM   #17
LVBugEyed
Member#: 186870
2010 WRX
Car must pullllll
LVBugEyed is offline   Reply With Quote
Old 04-28-2010, 11:00 PM   #18
1fly05sti
Member#: 151009
05 STI OBP
under construction
very nice must badass on the road...can you post some pics of the engine bay i want to see how rotated intake mani set up came out
1fly05sti is offline   Reply With Quote
Old 04-29-2010, 02:56 AM   #19
Rod702
Member#: 132978
updated, hope this pleases the mods. sorry for not following format.
Old 04-29-2010, 08:54 AM   #20
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
cams?
Old 04-29-2010, 10:45 AM   #21
Nuke209
Member#: 108089
2003 WRX
NF Performance
need some headwork
Nuke209 is offline   Reply With Quote
Old 04-29-2010, 06:04 PM   #22
atvracer111
Member#: 112179
2015 0RS,15STI,16wrx
Red, Black, Black
Did you sleeve the block?
atvracer111 is offline   Reply With Quote
Old 04-29-2010, 06:10 PM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
assuming that your boost isnt falling off the planet up top it would seem your car should be able to take a crap load more timing.....that 100hp fall off is weird.
A gt35 should be making peak hp close to redline on a 2.35 litre.
Old 04-29-2010, 10:41 PM   #24
mke723
Member#: 219094
07 95L-RS Rally
custom OBS paint
the ej22t are closed block from factory....
mke723 is offline   Reply With Quote
Old 04-30-2010, 12:35 AM   #25
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
you can still sleeve it...and peps do
