Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 06-06-2002, 06:28 PM   #1
Subi-fied
Member#: 13483
Question How accurate is SBC-id boost gauge?
It will be cheaper for me to buy the Blitz than to buy the Profec B and a gauge. Can I use the SBC-id only for now to control my boost w/out buying a gauge?
Subi-fied is offline   Reply With Quote
Old 06-06-2002, 06:35 PM   #2
Subi-fied
Member#: 13483
I plan to hide the controller in my console and I want to do many more mods before I put a Defi pod with Greddy gauges on the dash. Kinda makes people think it should be really fast with those gauges so I want to wait until it is
Old 06-06-2002, 08:02 PM   #3
WRChris
Member#: 13418
blur
think about it.........
i would assume its pretty damn accurate considering that the boost level it displays on screen comes from the same pressure sensor it uses to determine the solenoid duty.......and thus how much boost you make.
its just easier to see boost spikes etc using an analog gauge
WRChris is offline   Reply With Quote
Old 06-06-2002, 09:18 PM   #4
mpj_becks
Member#: 6265
I have found that mine reads 1-2psi lower than actual.
I had Greddy electronic gauges first and now Defi and both have shown consistently that my SBC-id is reading lower than actual.
This is just mine and others I'm sure have not had this or we would have seen it posted here a dozen or so times, none the less something to think about all the same.
Mike
www.mpjperformance.com
www.redstarracing.net
mpj_becks is offline   Reply With Quote
Old 06-07-2002, 02:40 AM   #5
WRChris
Member#: 13418
blur
were the gauges and sbc-id getting their signals from different sources?
Old 06-07-2002, 02:53 AM   #6
mpj_becks
Member#: 6265
WRChris - at first they were but then I switched them and still had the same effect, I thought the same that perhaps it was the difference from where we tapped but this proved to not be the case.
Mike
Old 06-07-2002, 09:45 AM   #7
Tuning Factory Inc.
Vendor
Member#: 3600
SBC was dead on for me at lower pressures but once you start going over 16 PSI on a PE turbo it starts reading a bit low.
Tuning Factory Inc. is offline   Reply With Quote
Old 06-07-2002, 10:35 AM   #8
Subi-fied
Member#: 13483
So I guess it will work fine for a stock turbo @15.5 psi.
Old 06-08-2002, 03:22 PM   #9
mpj_becks
Member#: 6265
I just tested mine and it too seems fine at lower boost levels on my car.
Mike
Old 06-08-2002, 04:02 PM   #10
SpooledRex
Member#: 10216
2002 WRX - WR Blue
My Greddy guage and my SBC-id are both tapped at the FPR line and at "0" the SBC-id reads about a half of a pound too low. And in the upper range it reads about a pund and a half too low.
i just ignore the boost level on the sbcid and watch the greddy guage.
SpooledRex is offline   Reply With Quote
Old 04-08-2003, 09:18 PM   #11
Turbo Tin Can
Member#: 18383
yea but it gets tricky when yer setting the boost spike saftey feature
Turbo Tin Can is offline   Reply With Quote
Old 04-09-2003, 12:03 AM   #12
tdxflex
Member#: 13634
my sbc-id was dead on with my greddy electronic. i only tested up to 1 kg/cm3, i think those are the units. when i hooked up my defi boost/timer, it read 0.07 bar higher than the sbc-id.
tdxflex is offline   Reply With Quote
is this normal ??? how accurate is maddad boost gauge boostedsti06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 12-26-2007 10:33 PM
How accurate is the factory boost gauge compared to other gauges? snvin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 08-06-2004 11:44 PM
Blitz SBC iD boost gauge??? bhkim126 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-29-2003 10:09 PM
How accurate is the factory boost gauge? DJDaizzy STi Forum Archive 3 07-14-2003 11:08 PM
SBC-ID users - gauge may not be the most accurate... is2scooby Hawaii Impreza Club Forum -- HIIC 3 11-18-2002 11:26 PM
