Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 06-06-2002, 06:08 PM   #1
spiralsmurf
Member#: 16085
2005 STi
Talking turbo plans
After a lot of thought about different ideas, i've come to the conclusion that I'd like to build a low-pressure turbo system (4-6psi) built around a stock wrx turbo (td04) and a stock wrx ic. I would use a Link plus ecu as well. I have someone knowledgable in subaru tuning who can do all the exhuast piping and build me a great exhaust for for cheap. Also I will be getting my clutch replaced soon buy SOA! So i'll wait to turbo until after that. I'm hoping to get it finished by mid-August.
Any comments or input would be appreciated.
Thanks,
Dan
spiralsmurf is offline   Reply With Quote
Old 06-06-2002, 11:56 PM   #2
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
Dan....
Don't bother with the stock clutch replacement. With 4.4 lbs of boost it slipped realy bad in fourth and fifth gears. It was worthless. If you go to all of the trouble to have it changed it just wont hold the torque of the 2.5 turboed motor. Get a better clutch. Otherwise, go for it. Get timing cotroll or you will break!
Paul...
hayscoob is offline   Reply With Quote
Old 06-07-2002, 12:43 AM   #3
inpreza kid
Member#: 3334
stock wrx turbo(TD04) the internal wastegate bleeds off at ~8psi. you will need a external wastegate to control at lower boost.
inpreza kid is offline   Reply With Quote
Old 06-07-2002, 03:09 AM   #4
spiralsmurf
Member#: 16085
2005 STi
I know about the external wastegate. also i was thinking, does the wrx stock clutch fit our cars? because that obviously can handle the power so maybe i just have them put that in instead.
Old 06-07-2002, 06:09 AM   #5
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
the clutches do not fit... but the flywheels do...
KillerTHC is offline   Reply With Quote
Old 06-07-2002, 10:59 AM   #6
spiralsmurf
Member#: 16085
2005 STi
damn it. should i go with an aftermarket clutch? and what kind? i still want something organic, i dont want a race clutch
Old 06-07-2002, 05:01 PM   #7
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
i use the exedy street clutch. it is basically the stock friction disc with a stronger pressure plate. it has a very stock feel but has enough holding power for ~350HP.
Old 06-07-2002, 05:46 PM   #8
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I had the clutchmaster stage III prior to my tranny exploding due to a loose screw. Retains pedal like feel while being about to hold about 350hp
kastle is offline   Reply With Quote
Old 06-07-2002, 06:16 PM   #9
spiralsmurf
Member#: 16085
2005 STi
how much are both clutches?
Old 06-07-2002, 06:50 PM   #10
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
CM stage III is around 500
Old 06-07-2002, 08:26 PM   #11
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
$280 for a act clutch pressure plate. http://www.writerguy.com/primitive/motor.htm#copper
-Chav
Chav is offline   Reply With Quote
Five-cylinder turbo planned for new Audi TT-RS and RS3 AVANTI R5 Non-Subaru News & Rumors 36 08-23-2008 10:07 AM
TRUEDAY TEAM TURBO planning event xenonk Mid Atlantic Impreza Club -- MAIC 43 08-02-2002 10:58 PM
Need Opinions on Turbo Plans XazerpmiX Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-28-2002 02:30 PM
Turbo Plans and Questions joefocker20 Normally Aspirated with bolt-on Forced Induction Powertrain 14 03-03-2002 04:04 AM
My budget turbo plan. Comments, please! Jon Bogert Normally Aspirated Powertrain 39 02-02-2001 05:08 PM
