Old 04-29-2010, 07:04 AM   #1
2000wrx
Member#: 66659
2000 L WRX'd
Default 2002 WRX FXT 2.5L, 18G, boost/rev issues
Okay, I just picked up a 2002 wrx with a 2.5L FXT engine, an 18G and a 6mt. Its running a FMIC, stock BOV, 810cc inj, tested by RC, 255lph fp, CAI, borla header, bellmouth DP and cobb cat back. It was tuned at at a local shop and put down 284ish AWHP. A stock wrx puts down 150ish... fyi.
The issues, first and second gear only make 7ish and 11ish PSI respectively, while 3rd and 4th make 20-22psi. It also seems to want to hesitate slightly in the first couple of gears at lower RPN, I mean it just doest seem eager to rev.
When its cold first thing in the morning is has a rough idle, (very slight) though nothing to crazy ( I assume its the 810cc inj). Though first and second gear the car just doesn't want to rev well or make much power, while 3rd feels better but still not what I would expect for a car with this much claimed power.
I have talked to shop where is was tuned and plan on taking the car in and having them look it over.
I was just curious what people thought it might be.
Thanks all!!
2000wrx is offline   Reply With Quote
Old 04-29-2010, 04:56 PM   #2
johnt2k7
Member#: 194151
2008 WRX
RED
who did the tune it may be they didnt adjust the boost compensations theirs one on my 08 that will Raise WGDC to lower Boost under a certain speed and their is also 1st gear compensation as well
johnt2k7 is offline   Reply With Quote
Old 04-30-2010, 06:54 AM   #3
2000wrx
Member#: 66659
2000 L WRX'd
hmmm I don't know if that was done or not.... I am going to have the car looked at by the shop that tuned it.
I have had it mentioned that it may be a exhaust leak, and maybe a BPV issue... we'll see.
Old 05-02-2010, 03:06 PM   #4
krich503
Member#: 245674
2002 wrx/sti
sliver
it just sounds like the tune. but its easy to check the exhaust and other stuff but i would get it retuned for sure
krich503 is offline   Reply With Quote
Old 05-13-2010, 06:25 PM   #5
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Sounds like the tune, 16bit ecu's don't have the ability to tune WGDC per gear fyi.
907Bum is offline   Reply With Quote
Old 05-13-2010, 06:36 PM   #6
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Bring it in and talk to the original tuner to trouble shoot or a new tuner for a re-tune. While WGDC might not be adjusted there are still many things to make your car run way better!
Will
GrimmSpeed is offline   Reply With Quote
2.5l 18g- 12.89 @ 112 eb_rat_7 Proven Power Bragging 22 10-31-2009 06:25 AM
E85 2.5L 18g WRX Wagon -- 402wtq, 377whp through slipping clutch lancelucas Proven Power Bragging 10 08-19-2009 06:35 PM
2002 WRX wagon 2.5L hybrid w/ Blouch 2.5R turbo triguy Proven Power Bragging 12 10-18-2008 03:09 PM
2002 WRX sedan 2.0L upgrading to STI 2.5l BLOCK, concerns or suggestions? alex02wrx Engine/Power/Exhaust 2 01-17-2008 12:25 AM
2.5L Wrx vs 2.5L Sti syntrix Newbies & FAQs 6 12-16-2006 04:25 AM
