Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 04-29-2010, 02:39 PM   #1
AMR
NASIOC Manufacturer
Vendor Sales Rating: (1)
Member#: 171509
Default ••• NEW Product: AMR PRO-COM ECU (OBD2 Compliant!) for the 2008-2010 Subaru STi •••
The AMR PRO-COM is the perfect engine management solution for the 2008-2010 Subaru STi.
Designed and engineered by AMR & Haltech USA specifically for the 2008-2010 Subaru STi, the AMR PRO-COM features a direct plug and play harness to make installation easy and straight forward. The PRO-COM comes with stage map calibrations to suite your vehicles supporting modifications. Giving the customer and/or tuner an easy starting point. Another big problem today is emissions testing (CEL lights/OBD2 Scans). The AMR PRO-COM is OBD2 compliant. Making it easy to drive right up and get your inspection without swapping computers! Power of a standalone without the headache!
No more worrying about sensors going bad, sluggish throttle response, maxing out sensors or even dealing with the headache of the tuning the stock ecu itself. The AMR PRO-COM is the perfect solution for the daily driver, track racer, or just an enthusiast at heart!
AMR PRO-COM Features:
* - OBD2 Compliant (yes, thats correct!)
* - Knock Light with built in shift light
* - Aux Control ON-THE-FLY Dual map switching (Fuel/Ign/Boost)
* - Aux Control for AMR Smart Injection (Meth Injection (fuel, timing, boost))
* - 3D 32 x 32 Fuel (VE or PW) & Igntion Tables (speed density) (no more mass air flow sensor!)
* - Individual Boost, Fuel & Timing Tables
* - Wideband "Auto tuning" using user definable target AFR table (tap into aftermarket wideband or gauge)
* - Staged injection control for multiple injectors per cylinder
* - Soft and hard cut rev limiter
* - Coolant Temp, Intake Air Temp, EGT Fuel & Ignition Correction
* - Throttle (TPS) by manifold pressure (PSI) fuel & ignition correction
* - Launch Control
* - Anti-lag (Rally and Launch style)
* - Internal 2.5 BAR MAP sensor (or use with external MAP up to 10 BAR)
* - Custom sensor calibration (Use your own sensors for temps or fuel/pressure, etc..)
* - Open or closed loop boost control (Road speed, RPM or gear based mapping)
* - Extra injector control
* - Thermo-fan control (Duty cycle or on/off)
* - Programmable Intercooler fan or Intercooler Spray
* - Nitrous switching with fuel / ignition correction
* - Staged shift light outputs
* - Tacho output (5v,8v,12v)
* - Turbo timer
* - Windows 2000, XP, Vista compatible software
* - "In the field" updatable firmware provides all the new features as soon as they are available
* - Onboard and laptop data logging with Data Viewer software
* - USB communication with laptop/PC
* - CAN Bus port for direct plug in communication with Racepak and Aim Dash system.
* - NOW AVAILABLE - *
(available through AMR & AMR dealer only)
__________________
[LEFT][SIZE=1][B][COLOR=red][SIGPIC][/SIGPIC][/COLOR][/B][/SIZE]
[SIZE=1]
[/SIZE]
[FONT=Century Gothic][B]Instant Messenger:[/B] [COLOR=red][I][B]AMR Performance[/B][/I][/COLOR][/FONT]
[SIZE=1][COLOR=black][B]
[/B][/COLOR][/SIZE]
[SIZE=1][FONT=Lucida Sans Unicode][COLOR=black][B]ECU SOFTWARE & PERFORMANCE PARTS MANUFACTURER[/B][/COLOR][/FONT][/SIZE]
[/LEFT]
AMR is offline
Old 04-29-2010, 09:12 PM   #2
berdugo
Member Sales Rating: (1)
Member#: 163108
07 EuroDM STi 2.5L
awesome product Rob! does it work for USDM STIs only like Cobb AP?
berdugo is offline
Old 04-29-2010, 11:53 PM   #3
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
No 04-07 sti love huh?
cellgeek101 is offline
Old 04-30-2010, 07:04 PM   #4
02fastWRBLUE
Member Sales Rating: (4)
Member#: 52590
sounds quite tasty!
I run Hondata on my turbo S2000 and i must say, there is NOTHING better than an OBD-II compliant "stand alone" system. I have had this car inspected in 2 different states without changing a thing, including the tune.
I commend you on making something that seems to be similar, as it is not often that a manufacturer will take the extra steps to make it OBDII compliant.
02fastWRBLUE is offline
Old 05-01-2010, 09:14 AM   #5
AMR
NASIOC Manufacturer
Member#: 171509
I would have to check the ECU pin-out on the EURO vehicles. As long as there were no changes. The unit will work with them as well.
Already in the works!
Originally Posted by 02fastWRBLUE View Post
sounds quite tasty!
Thank you and I agree with 100%
It is no fun having a high horsepower daily driver if it is not OBDII compliant.
-Rob
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 05-01-2010, 11:54 AM   #6
jigga
Member Sales Rating: (16)
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Is this EMS "OBDII compliant" when it is piggybacked on top of the stock ECU, or are you saying that without the stock ECU in the car at all and this one in place, the OBDII port works and all that stuff? In other words, is it the EMS system that generates the trouble codes?
Reason why I ask is that if you piggyback any standalone ECU on top of the stocker, they are "OBDII compliant" also...
That's the trick many with the HKS FCon ECU use, as well as some with the AEM EMS, UTEC, etc. etc.. Have the stock ECU control the boring stuff, and have the EMS control fueling and timing.
Just trying to see if this one does things differently..
jigga is offline
Old 05-03-2010, 09:49 AM   #7
AMR
NASIOC Manufacturer
Member#: 171509
The PRO-COM comes with a plug-n-play harness that runs parallel to the factory ECU. We have the factory ECU control all of the OBDII information.
On the 2008-2010 STi, this becomes very tricky due to the canbus.
-Rob
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Closed Thread
Magnaflow's Stainless Steel Cat-Back for the 2008+ Impreza WRX STi Krondor Engine/Power/Exhaust 8 07-22-2010 08:11 AM
