Old 04-29-2010, 02:43 PM   #1
BirdsBeChirpin
Member#: 236859
2014 WRX Hatch
PBS
Default Tell me if this makes sense
I bought an AP back in Feb, Just saved up enough to buy a catback tomorrow. I do plan on getting a invidia divorced downpipe but I want to order my catback first. Really the only reason I want to order my CB first is because I want the Apexi N1 and I cant find it anywhere but 1 shop. Kind of want to buy one before they sell out too! Question is, should I order the catback, install it and then install the dp when i can have enough saved up for it? or jus install everything all at once. Is it a pain in the ass just swapping out a dp? or is it easier swapping everything at once? Also, what map do i use for just a catback? Correct me if im wrong but i think you need a dp with a catback to tune it to stage 2. I have a 06sti.
BirdsBeChirpin is offline   Reply With Quote
Old 04-29-2010, 02:48 PM   #2
rabydanimal
Member#: 63126
'00 BMW 540i
Of course it will be less work swapping everything at once. However, replacing the downpipe after the fact only requires removing and replacing 2 bolts on the catback/downpipe flange. So, I would say it isn't that much additional work.
rabydanimal is offline   Reply With Quote
Old 04-29-2010, 02:51 PM   #3
BirdsBeChirpin
Member#: 236859
2014 WRX Hatch
PBS
Ok cool, and howabout the accessport part? What map would I use?
Old 04-29-2010, 02:55 PM   #4
X JBM X
Member#: 179639
'84 Carrera / '13
Golf R / '02 Corolla
stage 1...
stage 2 won't work until a dp is installed.
X JBM X is offline   Reply With Quote
Old 04-29-2010, 02:59 PM   #5
wit2003
Member#: 104395
2007 Element/06 Ford
F-350PSD/87MC-SS/11 TDI
flash stage 1 now and then install catback. You dont need any mods for stage 1.
wit2003 is offline   Reply With Quote
Old 04-29-2010, 03:00 PM   #6
BirdsBeChirpin
Member#: 236859
2014 WRX Hatch
PBS
Woot, thanks guys.
Old 04-29-2010, 03:16 PM   #7
morph1n3
Member#: 149742
2002 gears go
weeeeeeeeeeeeeeeeeeee
Sell the AP and get an opensource tune. Use the money from selling the AP to buy a downpipe.
morph1n3 is offline   Reply With Quote
Old 04-29-2010, 03:33 PM   #8
chzoom
Member#: 206990
06 Black STi
3 motors and a 35r fthis
+1
chzoom is offline   Reply With Quote
Old 04-29-2010, 03:34 PM   #9
mattminer
Member#: 90642
WKD Everything
you could run the invidia n1? its pretty much the same part as the apexi and easily accessible
mattminer is offline   Reply With Quote
Old 04-29-2010, 03:49 PM   #10
wit2003
Member#: 104395
and loud as ****!!!
but like stated above, you could essentially sell the AP and get open source tuned and buy the DP with the extra cash.....
Old 04-29-2010, 04:15 PM   #11
X JBM X
Member#: 179639
'84 Carrera / '13
Originally Posted by chzoom View Post
+1
Originally Posted by wit2003 View Post
and loud as ****!!!
+1
+2
+3
+4
Ridding yourself of the AP and using the money for an OpenSource tune AND downpipe is definitely the way to go.
Old 04-29-2010, 04:23 PM   #12
rinsed
Member#: 167870
2007 STI
UGM
I concur
rinsed is offline   Reply With Quote
Old 04-29-2010, 04:49 PM   #13
BirdsBeChirpin
Member#: 236859
2014 WRX Hatch
PBS
Why is everyone against the ap? Opensource is expensive isnt it? Espically when I am going to be slowly adding parts.
Old 04-29-2010, 05:05 PM   #14
mattminer
Member#: 90642
WKD Everything
its much cheaper overall actually.
Old 04-29-2010, 07:32 PM   #15
This Is Not Mike
Member#: 131737
2006 STI OBP
2013 Tacoma TRD OR
Just make sure to use globs of anti-seize on the bolts if you do the catback first...I've never had luck with exhaust bolts coming apart well after they've been on the car for a bit.
This Is Not Mike is offline   Reply With Quote
Old 05-04-2010, 08:23 PM   #16
Cobb Tuning
Member#: 4803
The notion that an OS tune is somehow "better" than an AccessPORT tune is a little flawed. Since the stock ECU is still in control over the engine the delivery system for that calibration is not going to make one tune better than the other. Since you already have the AccessPORT and have access to all the advantages of that unit, it would be best to install a stage 1 map and drive your car. Then when time and money allow, install the downpipe and flash on the stage 2 map.
Travis
COBB Tuning
so tell me if this makes sense at all? (body shop issue/rant) legacy2003 New England Impreza Club Forum -- NESIC 23 12-08-2004 11:04 AM
A vid I made. Can someone tell me if this all works DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 15 03-15-2003 09:11 AM
Tell me if this is a good idea for a business.... GooseMan Off-Topic 42 03-07-2003 08:17 AM
Can someone please tell me if this will be safe psixxxpsi Bay Area Impreza Club Forum -- BAIC 3 11-07-2002 01:16 AM
Hey can someone tell me if this is dumb? barkall4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-25-2001 06:36 PM
