Old 04-30-2010, 12:16 AM   #1
pacotaco
Member#: 202170
2004 saab 9-3
black
Default 97 Legacy Outback starting problem
hey guys i havent been on the forums in ages i have a 97 outback legacy ej25. i blew the motor about a year or 2 ago and its honestly just been sitting in my garage being slowly rebuilt it have a semi new bottom end from a jdm legacy and it looked like the pistons were slightly higher compression (dont think that matters). and we have rebuilt the heads everything is hooked up so there should be no reason why it shouldn't start. When i go to start the car the engine runs in counterclock wise motion which dose not seem right (because it is going against the tensioner), but every once and a while it seems like its catching and throws into the other direction. can anyone help me out here im on my last leg and its getting very tempting to part out. thanks for any help
pacotaco is offline   Reply With Quote
Old 04-30-2010, 09:53 AM   #2
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
I know my car's motor runs clockwise based on the crankshaft pulley. I have no idea how your motor is running in reverse (could be fun) but also, isn't that very bad for the valves?
Frogsthatmoo is offline   Reply With Quote
Old 04-30-2010, 02:39 PM   #3
pacotaco
Member#: 202170
2004 saab 9-3
black
no i think the valves should be fine seeing as it cant run i am honestly stumped i dont want to have to part out cuz that will be even more of a bitch.
Old 04-30-2010, 03:22 PM   #4
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
But I thought you said it doesn't run. It just turns over? Fuel pump? Fuel filter? Did you connect the injectors? Are you getting fuel pressure?
Old 04-30-2010, 11:43 PM   #5
pacotaco
Member#: 202170
2004 saab 9-3
black
the problem is, i turn the key the motor spins counterclockwise and does not start it catches some times and throws the other direction but never starts. fuel pressure seems fine and it is injecting. i dont think it should be spinning counterclockwise thats the main thing i want to figure out.
97 legacy outback auto into 95 Legacy - will it work? Boosted5speed Transmission (AT/MT) & Driveline 1 08-22-2008 11:30 AM
Problem with a 97 Legacy Outback DizzyTT Outback Forum 1 05-21-2005 08:26 PM
Interior trunk light 97 Legacy Outback seowitz Legacy Forum 4 08-14-2001 03:14 PM
Parts from 97 Legacy Outback for sale on eBay Impresario Legacy Forum 0 06-25-2000 05:16 PM
97 Legacy Outback parts for sale on eBay Impresario General Forum Archive 0 06-25-2000 05:12 PM
