Old 04-30-2010, 09:40 AM   #1
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
Default Stage 2 Setup, impressions? CEL?
Hello,
I have an 07 WRX TR and I'm ready to go to Stage II!
Cobb AP v2
ERZ Bellmouth Catless DP
STI TMIC, with y Pipe and 90* Hose.
Blitz Nur Spec R CBE (already on)
Injen Intake <-(not by choice, came on the car... ugh)
I got a couple Q's. I know I should NOT to Run the OTS Maps with an Intake, so I'm going to get and E-Tune for it before doing anything.
Q: Since by CBE tapers to 2.5in at the DP and the ERZ DP is 3in all the way do I need to get a special Gasket? Or how will they fit?
Q: Is there anything else I need to do or look into? I have read things about boost issues and such. Or just bolt up my DP and IC, Apply the correct map and go?
Q: I live in NJ, and will be able to run the 93 oct Map. But since I am going catless will I have CEL issues? Any way around this?
Thanks, I did search but wasn't able to fine much conclusive information.
Kupkake is offline   Reply With Quote
Old 04-30-2010, 10:11 AM   #2
THEVERGE
Member#: 127421
2002 Subaru WRX
I can only help with two of your questions.
1. You should'nt need a special gasket for the catback. I had a Greddy Evo 2 that tapered and I was able to use the standard 3" gasket.
2. The Accessport will turn off the CEL's for the catless downpipe. So no worries there.
Hope that helps.
THEVERGE is offline   Reply With Quote
Old 04-30-2010, 01:18 PM   #3
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
Hey, thanks for the incite!
Is it bad that the AP will turn off the lights? lol
Also, for anyone Catless, what do you do with the 02 sensor? Just unplug it? or will it still plug into the DP?
Old 04-30-2010, 09:28 PM   #4
jason02wrx
Member#: 222893
2016 WRX DGM Limited
2002 WRB/2012 SWP Hatch
Your downpipe should have a bung for that o2 sensor.
jason02wrx is online now   Reply With Quote
30r setup for stage 2 setup rexsti06 Tri-State Area Private Classifieds 27 04-12-2010 09:52 PM
As promised: An example of a catback stage 2 setup for a 2005 STI RiftsWRX AccessPort 1 09-27-2006 05:24 PM
Stage 2 first impressions atotten Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-25-2005 11:48 PM
Which Stage 2 Setup Would You Rather Have? subaru18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-01-2004 04:56 PM
ludespeed stage 2 throwing a CEL Derk1127 Normally Aspirated with bolt-on Forced Induction Powertrain 2 12-27-2002 04:15 PM
