Old 06-06-2002, 11:05 PM   #1
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Default 95 1.8 hp 110 tq 110 97 1.8 115 hp 120 tq????
anyone know why the 95 L 1.8 engine had 110 hp and torque and the 97 1.8 got 115 hp and 120 ft lbs? just curious to know as i am going to be rallying a 1.8 and need power! thanks
mcu81 is offline   Reply With Quote
Old 06-07-2002, 06:55 AM   #2
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Why
Have you posted this question at the 'Ultimate Subaru Message Board'? I'm curious to know myself and will be following this post.
Kevin Thomas is offline   Reply With Quote
Old 06-07-2002, 09:34 AM   #3
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I believe they went from single port exhaust to dual port....
wac would know... ( I think)
AO
m750 is offline   Reply With Quote
Old 06-07-2002, 01:31 PM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
They changed the compression so they must have messed with other stuff too.
Probably the same reason the 2.2L got a couple horse bump as well.
CosmoTheCat is offline   Reply With Quote
Old 06-08-2002, 01:32 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Edit: Wierd, i'd like to take a look at a 97 1.8 now...
The compresion ratio is 9.7 on 97's vs. 9.5 on previous 1.8's... Hmm...
Old 06-09-2002, 03:57 AM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Also found out that the 97 EJ18 gets its 120 torque at 4000rpms vs. 4400 rpms for the previous EJ18's with the 110 torque...
I do know for sure now that the 97's have OBD-II vs. our OBD-I
Old 06-09-2002, 08:01 PM   #7
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
kev, whats the ultimate subaru message board?????? oh btw, when you goin to atco and spraying the xt6? i wanna see and film!
Old 06-09-2002, 08:01 PM   #8
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
oh btw, i sourced my info at cars101.com
anyone got specs on these motors?
Old 06-10-2002, 01:47 AM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
What specific specs do you mean?
Old 06-10-2002, 08:47 PM   #10
Hawk296
Member#: 14555
1995 Impreza L
Baja
I was unaware that they even made the 1.8 after 96. Also what is meant by dual port exhaust? A port for each cylinder, meaning 4 in all? Or 2 per cylinder? this confuses me, please explain?
Hawk296 is online now   Reply With Quote
Old 06-10-2002, 09:00 PM   #11
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
were there only 3 valves/cyl pre 97 then 4 in 97?
Old 06-11-2002, 02:24 AM   #12
Kevin Thomas
Member#: 110
1989 1989 XT6
Default The Board
The Ultimate Subaru Message Board
This place is old school scooby paradise.
I don't want to spray the XT6 because my fuel issues are still present. I still have to resolve my lean running condition between 5k-6k rpm. Otherwise, the bottle is full and just begging to be used in the trunk.
Old 06-11-2002, 09:27 AM   #13
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
kt have u figured out why its running lean? do you have a different intake system on the car? on our rexes some intakes lean out the mixture......do you have a S-AFC?
Old 06-11-2002, 11:29 AM   #14
cardin555
Member#: 9972
2007 Jetta
grey
They were always 4 valves per cylinder IIRC.
cardin555 is offline   Reply With Quote
Old 06-11-2002, 11:49 AM   #15
CosmoTheCat
Member#: 3409
98 My FMIC
I think it's the # of exhaust holes coming out of the head into the exhaust pipes. But I didn't know that the 1.8 or 2.2 had dual ports. If you go to SPO's website they've got the 2.5l header and the 2.2l header, and you can see what I'm talking about.
SPO performance parts
Old 06-11-2002, 12:38 PM   #16
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
In 1997 Subaru made several changes to the engines regardless of the displacement.
1) they raised compression to 9.7/1, the engines became interferance motors.
2) they reduced friction in several ways;
eliminated piston side-skirts
changed from Hydraulic Valves to Solid lifters (adjustable)
3) made adjustments to the FI map.
The question of Dual-Port or Single-Port applies to CA emissions vs Fed emissions. Before 1995, all EJ motors were Dual-Port. In 1995 CA Emissions Vehicles (Subaru) became TLEV motors and went to the Single-Port configuration.
SubyTechMaster is offline   Reply With Quote
Old 06-11-2002, 12:58 PM   #17
cardin555
Member#: 9972
2007 Jetta
grey
The solid lifter were only on the 2.5L engine.
I am going to double check the exhaust ports but I am pretty sure that my 97 1.8L has double ports, but don't quote me on that.
Old 06-11-2002, 02:40 PM   #18
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
wow! thats alot of redesign for one year! maybe ill have to go for that!
Old 06-11-2002, 04:22 PM   #19
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
I have a factory Service Manual to referance, if there is a referance to contradict this please share it.
Otherwise, please don't make absolute statements if your facts are in doubt.
Old 06-11-2002, 05:24 PM   #20
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
WOW! solid lifters for the 1.8! i gotta find a 97 1.8 for my 95 L
Old 06-11-2002, 07:03 PM   #21
cardin555
Member#: 9972
2007 Jetta
grey
I stand corrected. The 2.5L was the only one to use shims to adjust the valve clearence.
Solid lifters plus the higher compression ratio would certainly make more power.
My apologys to everyone.
Old 06-11-2002, 07:15 PM   #22
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
1) what is invovled with that specifically?
2) I guess I cant mess with the piston side skirts, but I would have to get '97 heads in order to have the solid lifters no? Or could I just get the lifters and put them on my current heads?
x) My exhaust ports are identicle to an RS exept my header is .25 smaller in diameter... An RS header can bolt right up to my car (I had them side by side)
Old 06-12-2002, 12:44 PM   #23
RaceCarRiot
Member#: 6542
1997 Ver IV
why all the fuss over this? unless you're limited to 1.8 liters as some kind of racing class rule...?
RaceCarRiot is offline   Reply With Quote
Old 06-12-2002, 02:40 PM   #24
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
i am, im racing production in scca club rally
Old 06-12-2002, 06:35 PM   #25
RaceCarRiot
Member#: 6542
1997 Ver IV
gotcha. that's what i figured...just wanted to make sure.
DNA Motoring FMIC Results? ROFLBOXER Car Part Reviews 25 09-18-2013 08:17 PM
Just TTW: 17x8 Rota Torque URMOMHASVTEC TXIC Private Classifieds 6 06-06-2010 12:51 PM
motor swap help STI longblock into a Legacy gingertooth Legacy Forum 6 06-01-2010 09:16 PM
1997 Outback Sport fog light help 1997OBS Interior & Exterior Modification 1 06-01-2010 07:09 PM
[PICS] Black WRX w/ Full Royal Sports Bronze Rota Torques hock2k5 Tire & Wheel 0 06-01-2010 05:08 PM
