Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 05-01-2010, 01:18 AM   #1
Member#: 121459
Default '91 has a temp. fluctuation issue....
Hey all, I've been the proud owner of an '02 wrx for the past few years & today my girlfriend picked up a '91 Legacy sedan for 500 bucks! Granted, it's got 234k miles on it & needs some maintenance stuff but all in all isn't too bad. The Subie fleet is growing & I am stoked
Anyway, the story behind the car is that it was mechanic-owned most of it's life. The people we bought it from said they recently replaced the thermostat, yet once the car warms up, the needle will tend to rise 'till it's just below the red, then steadily fall back down to normal operating temp. To me, this sounds like:
-the thermostat they installed is a piece of junk (quite possibly from NAPA) & already needs to be re-replaced
-There is air in the system & it needs to be properly bled
-Something is up with the water pump
What do you all think? I don't think we're looking at a head gasket, as there is no oil in the overflow tank & the car shoots NO visible smoke out of the exhaust when revved.
Really though, the overheating issue, some moderate oil leaks & some exhaust gaskets that obviously need to be replaced are really the only pressing issues with this car. For 500 bucks, I think we got a great deal.
Any ideas on the temp. issue are greatly appreciated!
silence2-38554 is offline   Reply With Quote
Old 05-01-2010, 02:50 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I've blown head gaskets 4 times (I'm driving around on bad head gaskets right now, as a matter of fact) and have never seen either of those symptoms. I honestly don't think I've ever heard anyone report those symptoms with a Subie with bad HGs, it's just not the way they blow apparently. Every time they've gone bad for me the engine will gradually blow coolant out of the cooling system and into the coolant overflow tank until it overflows. If the HGs are really bad, or if I try to drive the car hard, it will do that pretty quickly and make quite a mess, blowing coolant all over the driver side of the engine compartment.
With that said, it's definitely worth checking the other things you mentioned before you go through the trouble of doing the HGs. AFAIK the EJ22s are not nearly as likely to blow HGs as the newer EJ25s are, so hopefully it's something simpler/easier/cheaper.
Pat Olsen
Old 05-02-2010, 03:13 PM   #3
that one legacy
Member#: 103665
i've been having some odd problems with the cooling system on my 95 brighton (also a ej22e), and i've narrowed the list down some kind of problem with the electrical system that monitors the cooling system. i already replaced the temp sensor, but the car still says its overheating even when I first start it up after letting it sit overnight. i also replaced my thermostat just because. i did notice that if i take out the fuses for the heater before i start the car, the temp gauge won't climb up. when i put them back in, the temp gauge will stay down for a while, but then will eventually shoot up to the H. haven't seen a single drop of coolant leak out from the engine bay, or shoot out the tail pipe though.
i know this doesn't really answer your question, I'm just sharing my experience to give you some more ideas of other things to look at.
that one legacy is offline   Reply With Quote
Old 05-06-2010, 01:53 PM   #4
Member#: 161594
1972 Datsun 240Z V8
Can-am White
i think you answered your own question, aftermarket thermostats are junk! but, might as well go borrow a coolant pressure checker from autozone to make sure you have no leaks. if none are found, i bet you that "new" thermostat is the culprit. when it comes to rice and thermostats, i only use OE. i bought a honda crv with "blown head gasket" on the cheap and it turned out to be a Napa thermostat.... btw, the 2.2 legacy will run in excess of 300k miles with regualr scheduled maintenance.
bry593 is offline   Reply With Quote
Old 05-06-2010, 09:43 PM   #5
Member#: 71419
drill a few holes in the crappy napa thermo. The temp shouldnt rise so high before thermo opens and fans kick on thats for sure. Then bleed the system of air, add good anti corrosion coolant and see how it goes. If that fails, have a close look at the pump, although its probably ok
ncarn8 is offline   Reply With Quote
Coolant Temp fluctuation at times randomly??? UpSideDownDesi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-28-2009 08:41 PM
temp gauge issue jdmwrxej20 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-30-2007 10:13 PM
HELP! Car temp. fluctuating bambam7171 Service & Maintenance 2 08-28-2005 09:15 PM
Need help with some seriously bizarre boost fluctuating issues! SoLo OnE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-04-2004 11:04 PM
A/C temp fluctuation blitzpb Service & Maintenance 5 11-10-2003 02:59 PM
