Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-06-2010, 06:46 PM   #26
patr
Member#: 97
four words
motorsport diff controller needed
trust me
patr is offline   Reply With Quote
Old 05-07-2010, 04:20 AM   #27
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by 68Cadillac View Post
Just watched the video.
IMO, the car could be much faster if you changed the driver's driving style. He saws the wheel like a blade at a lumber mill. Smooth is fast. Tell him to stop twitching and fiddling with the steering wheel. Smooth inputs to the wheel and steer with the throttle.
Smooth is fast.
I'm sure that whatshisname could learn a lot from you.
Personally I thought that was pretty humbling to watch. The car was squirrely but he consistently unsquirreled it very well. Only one substantial mistake (looked like he overcooked a corner at 6:40 or so), but if the fastest lap wins, then it's probably a winning strategy to drive so close to the edge that you sometimes make mistakes like that. Just need one clean lap.
Thanks for posting that, garageGT!
Old 05-07-2010, 08:28 AM   #28
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Originally Posted by patr View Post
four words
trust me
I think you should take Pat's advice.
It's a reliable source
mapleleaf is offline   Reply With Quote
Old 05-07-2010, 10:33 AM   #29
patr
Member#: 97
The active diff is doable for the 5mt (xfer gears and c-section) and you can get proper controllers for it as well, its been used worldwide for many years. with the proper setup it will be faster
Old 05-07-2010, 11:52 PM   #30
garageGT
Member#: 80524
four words
trust me
we have one
http://1.bp.blogspot.com/_CFVLrb_PbN...h/DSC00173.JPG
garageGT is offline   Reply With Quote
Old 05-07-2010, 11:54 PM   #31
garageGT
Member#: 80524
good eye and yes, all it takes is 1 clean lap.. hopefully cleaner next time
Old 05-07-2010, 11:56 PM   #32
garageGT
Member#: 80524
now I'm curious about the adjustent on the emcd..any idea?
Old 05-08-2010, 12:38 AM   #33
Maxwell Power
Member#: 190729
I had the cusco tarmac gear center diff and cusco MZ diff in the rear. Loosen up the lockup ratio on the rear diff to around 60%. It helps quite a bit, at least it did for me. The high lockup ratio just resulted in an instant loss of grip and since the diff is OPEN, the rears get all the power once they break loose.
the tarmac gear is 35/65 with traction, 0/100 without. Loosening up the rear diff keeps the back end from kicking out so fast and allows the fronts to get a bit more power.
with low traction out back, the Tarmac Gear center diff is a drift diff. That's what I used it for initially.
Maxwell Power is offline   Reply With Quote
Old 05-08-2010, 02:14 AM   #34
garageGT
Member#: 80524
Thanks for the input..we had the rear at %60 as well, but it was a RS unit. Cusco told us to switch to RZ as you mentioned. But they dont think their center diff is suitable for buttonwillow..They also ran there and had chance to fine tune their 6spd dccd setup, they want me to run that but its too costly for us to switch to 6spd after all the investment we did in the 5spd. Our west coast tracks are very slippery & rough. So we will try to increase grip by an EMCD & RZ setup, or simply a usdm 50-50 & RZ. I also heard early WRX came with a 60-40 split but have to do some more research..I always liked the 35-65 but its getting harder to control with more power. The car didnt have any traction problems when it was slower lol
cheers,
cenk
Old 05-10-2010, 02:08 PM   #35
patr
Member#: 97
you can easily run the 5spd emcd with an active controller, we've had many out there winning hillclimbs, rallies and time attacks in europe, africa and asia...
depending on your current 5mt case (there are 4 designs), to convert your 5mt you just need the transfer gears, or if its a different case style then you'd just need the rear end of the 5mt case (or you can modify yours), then use the ver6 emcd. For high stress situations (yours isn't to be honest) the coils are also often re-wound. It depends if you currently have the 30/33 gears or 31/31 and which rear end of the case.
the 5mt and the 6mt also have some coil differences but you can order an active diff controller specifying the 5mt and there are proper maps out there for time attack and different circuits
Old 05-10-2010, 07:13 PM   #36
garageGT
Member#: 80524
nice, thank you canada is the best place to find these parts i assume
Old 05-11-2010, 07:43 PM   #37
lotarg
Member#: 90940
Cool vid. I bet at 4:00 you were glad you were in an AWD car haha
lotarg is offline   Reply With Quote
Old 05-12-2010, 03:01 PM   #38
garageGT
Member#: 80524
yep
The Flex Tool XC 3401 VR is here this is the ultimate orbital polisher DetailersDomain Car Care & Detailing 0 12-24-2007 08:16 AM
think this is the right place for this question SubieSubieDoo Tire & Wheel 2 08-22-2007 10:05 PM
This is the ultimate showdown -WTLW for sure edkwon Off-Topic 26 06-10-2006 11:09 AM
Ok....The chopper fad is sorta gay....but this....this is the ultimate chopper! Nightwing Off-Topic 4 04-02-2005 08:52 PM
The ultimate suspension setup for the GC8 Teh Legacy Brakes, Steering & Suspension 3 02-01-2003 02:01 AM
