Old 05-01-2010, 03:51 PM   #1
DJS1
Member#: 153690
2006 STI
Default How to remove rear differential sensor? ASAP
I have my '06 STI on stands and need to know how to remove the rear diff sensor. I tried to do a quick search but I am in the middle of two other maintenance projects (coolant and oil change) and need some quick help.
I looks pretty straight forward but I don't want to break the harness off the sensor by forcing tools into it, etc. Do i loosen the fill/sensor bolt first then remove the wire or do I remove the sensor wire first then loosen bolt? How do I release the clip from the sensor (special tool/flat head screwdriver)? All stupid questions but again...don't want to break anything!
Thanks in advance and I will check back in an hour or two...pics, other threads would be helpful.
DJS1 is offline   Reply With Quote
Old 05-01-2010, 05:31 PM   #2
SJwrx
Member#: 14970
1997 GF8
multi
I'd be a fan of 'unclipping' it
Rich
SJwrx is offline   Reply With Quote
How to remove rear seat cushion for folding rear seat function? rice h8r Off-Topic 11 11-16-2006 08:31 PM
How to remove center differential assembly/transfer case?? WRXINTX Transmission (AT/MT) & Driveline 8 03-08-2006 11:46 AM
How to confirm rear differential and ratio? ryceracerx Transmission (AT/MT) & Driveline 2 10-22-2004 03:48 PM
how to remove rear differential protector? exhondaguy Transmission (AT/MT) & Driveline 1 07-30-2003 11:37 AM
