Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 05-01-2010, 03:57 PM   #1
HB_Dad
Member#: 45190
2014 Impreza Sport L
Default HELP!! My '06 Tribeca is overheating with longer idling again!!!
Hey all, as you may recall I had issues with my '06 Tribeca overheating awhile back. After several attempts at quick remedies at the dealership (thermostat changed, flushed system, etc), the dealer found the head gasket was blown and replaced it. The overheat went away for a few months after that but recently it came back. I returned to the dealership and they now found the radiator was bad so they replaced the radiator and cap. A few weeks later, the overheat is back again at idle.
The question now is what else could be causing this? If I idle with A/C running for about 10 minutes or so, the fan kicks into high and the temp gauge starts going up past half way and goes all the way to the max if I let it. However, it doesn't always happen as I've waited in the car idling for almost an hour before with the A/C running and had no issues. What's weirder is that while overheating, revving the engine will bring the temp back down and often the overheat does not return even after continuing to idle. Does anyone know what else can be the cause of this? What other parts are involved in the cooling system that may be the culprit?
HB_Dad is offline   Reply With Quote
Old 05-01-2010, 10:40 PM   #2
22BKEEPER
Member#: 15687
08 Tribeca
Bbronz
Are both fans coming on when this issue is occurring? Do they both achieve High speed?
If you rev the engine up do you hear bubbling sloshing?
Do you have access to a laser pyrometer to verify the engine is actually over heating? Could be a bad temp switch and /or bad ground circuit.
Hope this helps
22BKEEPER
22BKEEPER is offline   Reply With Quote
Old 05-02-2010, 09:18 AM   #3
immortal_suby
Member#: 1711
140 rogue points!
2013 GBS BRZ Limited 6MT
Could be a failing thermostat.
immortal_suby is offline   Reply With Quote
Old 05-02-2010, 02:20 PM   #4
HB_Dad
Member#: 45190
They just replaced it though... along wih the cap and a new radiator.
Old 05-02-2010, 03:02 PM   #5
that one legacy
Member#: 103665
when you first start the car up in the morning (or any time after letting it sit for a few hours), does the temp gauge go up any, or does it just sit there until you've let the car run for a bit. does your a/c drop off when the temp needle climbs? if you remove the fuses for the heater, does the temp gauge drop?
it's starting to sound like you have a bad temp sensor, but it's hard to pinpoint. the problem with cooling systems is that every single individual problem could end up being a symptom, or the actual problem.
that one legacy is offline   Reply With Quote
Old 05-08-2010, 05:40 AM   #6
HB_Dad
Member#: 45190
UPDATE: So I brought my Tribeca in to the dealership AGAIN, and have yet ANOTHER 09 Forester loaner car (nice car by the way). Anyway, they now say it is a bad "throttle body gasket" which is causing system pressure issues and bubbles that are somehow evaporating my coolant. Apparently my coolant level was very low even though they just topped off the radiator they installed only a month ago. I have no idea what this part is exactly, but I sure hope it fixes the problem. They won't get the part in until Tuesday so I have the loaner until at least Wednesday. I hope this ends the overheat saga...
Old 05-08-2010, 09:28 AM   #7
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
Steel Silver Metallic
Interesting saga. Post up over at sb9t.com. All Tribeca all the time.
Magic Marker is offline   Reply With Quote
Help! My 5mt gearbox is trashed in my 2.5RS Coupe. Katonka Transmission (AT/MT) & Driveline 2 11-20-2007 10:16 PM
Subaru wants to BUY BACK my '06 Tribeca!? nycb9 Tribeca Forum 9 08-02-2007 04:34 AM
My old STi is back up for sale again glilly Texas Impreza Club Forum -- TXIC 9 07-04-2006 08:46 PM
Something is wrong with Greg's car..... again.... but very strange this time. GregUnd Texas Impreza Club Forum -- TXIC 28 05-22-2003 05:01 PM
