Old 05-01-2010, 10:38 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default 07 WRX - Blouch DOM 3 8cm housing vs. 10cm housing!
I'll start out by eating my words a bit . I had previously posted that the 10cm housings that Blouch is using seemed to add too much lag without any real power advantage. This was based on all the results I had seen posted with the turbo but I hadn't had a chance to do a true comparison until now.
The car in question is an 07 WRX. I tuned this car about a year ago with the same setup but with the original DOM 3.0R with 8cm housing. The housing started cracking, so the customer sent it in to Blouch for repairs. They covered the issue under warranty and replaced the exhaust housing with one of their new 10cm housings. The rest of the turbo was untouched, so this is not a true XTR model. The results showed about a 300-400RPM increase in boost threshold and a 28whp gain. With the 10cm housing I was still able to get full boost by about 3700RPM and torque peak is still just past 4000RPM. This is much better than a lot of the results I've seen previously, so I was pleasantly surprised with the outcome. There is definitely a difference in spool and transient response with the larger housing, but its not nearly as big of a difference as most of the results have shown to date. This turbo performed almost identically to the ATP3076. It would be very interesting to see another comparison with the XTR wheel.
Here's the info and chart:
Event: Custom Tune/Road Dyno
Ambient Temp: 75 degrees Fahrenheit
Elevation: ~180ft above sea level
Car: 2007 Subaru WRX
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 352whp @ 7000RPM
Peak Torque at RPM: 325ft-lbs @ 43000RPM
Target Boost: 19.5psi Peak
Fuel: Cali 91 Octane
Engine/Power Modifications:
Blouch DOM 3.0R 10cm housing (non-XTR)
Catless TBE
APS 70mm CAI
Perrin Inlet/MAF hose
Hallman MBC
Walbro
DW750cc injectors
E-Bay TMIC
EQ Custom Tune
Here is the chart from todays tune:
And here is the overlay with the previous tune with the 8cm housing:
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 122-123mph traps
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 05-02-2010, 09:36 AM   #2
stidoc
Member#: 147579
stidoc is offline   Reply With Quote
Old 05-02-2010, 01:04 PM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Isnt it weird after looking at all the results?
Im not getting what we're doing different than the other tuners. Maybe its just from using the hallman and the other tuners all have really conservative turbo dynamics mapping?
Old 05-02-2010, 01:12 PM   #4
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Maybe cause your tuning on Public Roads, creates different loads than on the dyno so of course your plot is going to look different.
02WRX2.5 is offline   Reply With Quote
Old 05-02-2010, 01:32 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
even when comparing dyno results of gt30 range turbos all the 10cm results have been very laggy
Old 05-03-2010, 12:14 PM   #6
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Its very strange. I guess the MBC is just helping that much with these larger turbos?
-- Ed
Old 05-03-2010, 12:16 PM   #7
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Sure, doing pulls on a real road can create different loads, but that just means the dyno operators need to adjust their settings to get a more accurate representation of real world loads. That being said, I've also seen road dyno plots show similar very laggy results.
-- Ed
Old 05-04-2010, 09:32 AM   #8
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
-- Ed
Right on it just seem obvious to me, but i think your idea about the MBC is spot on, with my experience there is nothing better then MBC. Keeping it very simple = very fast.
Matt
Old 05-04-2010, 01:21 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Matt
Yep. I've worked extensively with just about every type of boost control currently on the market and I keep coming back to the good old Hallman MBC for its response, stability, and consistency that is just unmatched by anything else I've worked with.
-- Ed
Old 05-04-2010, 01:28 PM   #10
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I would love to see this turbo on E85 and 25-27psi, 450whp???
Old 05-04-2010, 02:08 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'd probably expect around 430-440whp out of it if we maxxed it out on E85 .
-- Ed
Old 05-06-2010, 07:53 PM   #12
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bumpin up. I thought people would be more interested in this comparison as its the most direct 8cm vs 10cm comparison I've seen to date .
-- Ed
Old 05-06-2010, 08:28 PM   #13
Phatron
Member#: 36033
CEO PhatBottiTuning
yeah. people biatch about doing them....then dont care once they're done.
its nothing really surprising though....
Old 05-06-2010, 09:38 PM   #14
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
This is one of those threads that I wanted to see. My interpretation of the 10cm housing was pretty much just as Ed had said. Most previous threads showed pretty dismal spool, and I had pretty much written off the 10cm housing.
Unfortunately well backed up comparisons like this don't really warrant a whole lot of comment. It's all there. It's not that we don't care, it's that nothing more really needs to be said. (Except, thanks Ed)
Concillian is offline   Reply With Quote
Old 05-06-2010, 10:52 PM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I guess if there's no drama the thread dies. I'll try to include some controversial results next time.... boost leak anyone?
-- Ed
Old 05-06-2010, 11:01 PM   #16
C J
Member#: 132587
2006 JrTuned STi
[email protected]
I wish I had the funds to play with a badass new turbo like this, awesome results. Now lets see it on some E85 or C16 please.
C J is offline   Reply With Quote
Old 05-07-2010, 12:03 AM   #17
modaddict
Member#: 95840
sold to a good bud
awaiting next car
There's a boost leak noted about 1800rpm
modaddict is offline   Reply With Quote
Old 05-07-2010, 12:09 AM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
you detected a boost leak before the pull even began... you MUST be good
-- Ed
Old 05-07-2010, 12:11 AM   #19
modaddict
Member#: 95840
sold to a good bud
awaiting next car
-- Ed
Your VTEC crossover point is too soon also.
Old 05-07-2010, 12:24 AM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
bazinga
Old 05-07-2010, 09:57 AM   #21
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Hey Ed thanks for posting this. I have had a 8cm dom3 for some time now. Ive been playing with the idea of swapping out to the 10cm housing, but I was affraid of it being too laggy, because I do a lot of autox etc... But I always wish it had some more top end on the street, the track etc.
Seems to be worth it to me.
rexworx is offline   Reply With Quote
Old 05-07-2010, 11:59 AM   #22
im2ninja4u
Member#: 183389
Hm, wish it was an XTR model. I have a Dom4 that might need to get sent in.
im2ninja4u is offline   Reply With Quote
Old 05-07-2010, 12:13 PM   #23
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
It should perform almost identically to the ATP with the 10cm housing. The ATP housing is ~10cm itself so now the only difference between the two would be the compressor cover.
Old 05-07-2010, 12:29 PM   #24
jason miller
Member#: 158313
2003 WRX
Concillian is right on the money. I was glad you posted this, but there really isn't much else to say about it. Thanks for taking the time to share.
jason miller is offline   Reply With Quote
Old 05-07-2010, 01:55 PM   #25
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep that's true. They're very similar turbos at this point.
-- Ed
FS/FT: feeler Blouch Dom 3 Turbo 8cm - BRAND NEW $1300 shipped Sato_unit Engine/Power/Exhaust 5 03-11-2010 03:38 PM
f/s:va: Blouch DOM 3 2.4inlet 8cm zero miles** sold sold** moorebl MAIC Private Classifieds 2 01-11-2010 09:00 PM
f/s:va: Blouch DOM 3 2.4inlet 8cm zero miles** SOLD SOLD SOLD** moorebl Engine/Power/Exhaust 2 01-11-2010 05:35 PM
FS (DFW): Blouch Dom 3 Essentially New (3inch/8cm/EWG) 75 DOLLAR FINDERS FEE TOO! fatcircles TXIC Private Classifieds 53 12-12-2009 02:17 AM
FS: Like New Blouch Dom 3 Turbo (3inch inlet/8cm exhaust/EWG Only) fatcircles Engine/Power/Exhaust 39 12-12-2009 02:16 AM
