Old 05-07-2010, 01:57 PM   #26
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by jason miller View Post
Concillian is right on the money. I was glad you posted this, but there really isn't much else to say about it. Thanks for taking the time to share.
Yep... that's how it goes. Post a straight forward, complete comparison and there's not enough drama to keep the thread up .
Oh well. Hopefully people will be able to find this when they need by searching.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 05-07-2010, 02:06 PM   #27
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
I am curious to see what the xtr wheel would have done. Though this is a good 8cm vs 10cm housing comparo.
Illusive is offline   Reply With Quote
Old 05-07-2010, 02:26 PM   #28
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
-- Ed
make this a comparison template for garageGT Ed. This is how its done ,lol
Old 05-07-2010, 04:53 PM   #29
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
What? You mean I can't show that the 8cm housing spools faster AND makes more power?? Just loosen a clamp a bit and we're there! .
-- Ed
Old 05-07-2010, 07:48 PM   #30
CatfaceType-R
Member#: 81102
wow...the 10cm housing is a for sure winner, no doubt no matter what...well unless you auto x
CatfaceType-R is offline   Reply With Quote
Old 05-08-2010, 10:54 AM   #31
antonch
Member#: 170384
2006 Sti
Maybe I am not looking at the same graph, but 8cm looks like a winner to me.
Only 28hp loss but more torque below 3700rpm.
P.S. Excellent apples-to-apples comparison.
antonch is offline   Reply With Quote
Old 05-08-2010, 11:43 AM   #32
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
^^^ some see it this way. I think its worth a lil loss. I think you would see a bigger improvement on a motor that naterally flows more. "big cams, PnP heads, etc"
Or if someone PnPd and coats everything from the turbo cold side to the hot side and "everything" in between.
The turbine housing is the true bottle neck. Also a nice thing about the larger housing is it will drop the EGTs, in turn making the engine less prone to knock.
Not trying to rip on this car at all, it makes good power IMO. Just stating that it currently has a pretty basic mod list. With some other mods, it "should" show more.
rexworx is offline   Reply With Quote
Old 05-08-2010, 02:22 PM   #33
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Its all relative to what you want really. 28hp peak isn't anything to sneeze at and in reality when you're really on it you won't be in the rpm range where the 8cm shows its low end advantage for long.
Old 05-08-2010, 03:25 PM   #34
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Exactly. It's always a balance between response and power. Which is better depends entirely on the application and preference.
Thanks
-- Ed
Old 05-08-2010, 03:29 PM   #35
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
low end tq is for people who like to FEEL like they're going fast.....
high end hp is for people who actually like to go fast
Old 05-08-2010, 06:42 PM   #36
stidoc
Member#: 147579
...and for people who like to keep their motors near redline all the time
stidoc is offline   Reply With Quote
Old 05-08-2010, 07:01 PM   #37
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You can't really go all that fast revving out to 3500 rpms
Old 05-08-2010, 07:21 PM   #38
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
i appreciate this comparison ed, nice job. curious of the inlet size?
Steve.804 is offline   Reply With Quote
Old 05-08-2010, 07:22 PM   #39
rexblake
Member#: 178426
2010 S4
Gray
Lol, I like it. Best statement to date.
Also nice to see an apples to apples comparison. Thanks for the info. I'm still glad I went with the xt-r. Otherwise I'd always get that "what if" feeling.
rexblake is offline   Reply With Quote
Old 05-08-2010, 08:56 PM   #40
stidoc
Member#: 147579
I can...and all the way to 6K too
Old 05-13-2010, 03:51 PM   #41
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I believe its a 3", but not 100% sure.
-- Ed
Old 05-13-2010, 06:06 PM   #42
nhat
Member#: 140163
03 STi
hellaflunctional
great test and info ed. if i stay stock location, 20g-xt with 10cm hotside
Old 05-16-2010, 09:39 PM   #43
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'd be curious to try a 20G with the 10cm hot side. I'm not sure if you'd see the same type of gains at lower flow rates.
-- Ed
Old 05-16-2010, 10:24 PM   #44
Phatron
Member#: 36033
CEO PhatBottiTuning
I'd be curious to try a 20G with the 20cm hot side.
when did they start making that
Old 05-16-2010, 10:29 PM   #45
im2ninja4u
Member#: 183389
I'd be curious to try a 20G with the 20cm hot side. I'm not sure if you'd see the same type of gains at lower flow rates.
-- Ed
Where do I get one of those
im2ninja4u is offline   Reply With Quote
Old 05-16-2010, 10:32 PM   #46
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ ur a pretty slow ninja
Old 05-16-2010, 11:59 PM   #47
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Didn't you guys hear?? You're way behind the times! 20cm is where its at now!
-- Ed
Old 05-17-2010, 09:38 PM   #48
LittleBlueGT
Member#: 96204
2013 STI GR
I know you posted the temps on this tune, but what about the temps in the after tune? I suppose relative pressure (due to weather) may by a bit different too.
Phatron: You talked about spooling slower due to conservative td values. I don't see it. Doesn't an old DOM3 have a 15 lb WG spring? If so, then boost threshold up to 280 wtq or so is gonna be completely unaffected by what boost controller/MBC you are using (not saying I have a preference, but I like Hybrid). By the looks of the curves, they both build boost beyond 15 psi by about the same rate.
LittleBlueGT is offline   Reply With Quote
Old 05-18-2010, 12:16 PM   #49
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ i think you misunderstood what i said. i wasnt even talking about this car as its running a mbc.....so td's dont even come into play.
Old 05-18-2010, 01:55 PM   #50
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
The temps were within 2-3 degrees between the two tunes. We lucked out there .
Even if the wastegate spring is 15psi, a boost controller will get you to that 15psi significantly faster than just the wastegate on its own. Wastegates open progressively, so as you hit 5psi, it opens a bit, 10psi, it opens more, 15psi, it opens more and stabilizes boost. With a good boost controller, the wastegate doesn't see any boost until it gets very close to its target. This allows the wastegate to stay closed much longer and greatly improves spoolup.
-- Ed
FS/FT: feeler Blouch Dom 3 Turbo 8cm - BRAND NEW $1300 shipped Sato_unit Engine/Power/Exhaust 5 03-11-2010 03:38 PM
f/s:va: Blouch DOM 3 2.4inlet 8cm zero miles** sold sold** moorebl MAIC Private Classifieds 2 01-11-2010 09:00 PM
f/s:va: Blouch DOM 3 2.4inlet 8cm zero miles** SOLD SOLD SOLD** moorebl Engine/Power/Exhaust 2 01-11-2010 05:35 PM
FS (DFW): Blouch Dom 3 Essentially New (3inch/8cm/EWG) 75 DOLLAR FINDERS FEE TOO! fatcircles TXIC Private Classifieds 53 12-12-2009 02:17 AM
FS: Like New Blouch Dom 3 Turbo (3inch inlet/8cm exhaust/EWG Only) fatcircles Engine/Power/Exhaust 39 12-12-2009 02:16 AM
