Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 05-02-2010, 10:06 AM   #1
Obsessive
Member#: 77302
damn well better
bail me out of this ****
Default Rubbing/Grinding Sound After Pad/Rotor Install - 2006 WRX
Hello all.
I helped a friend put new SS lines, Hawk HPS pads, and 'OE type' rotors on his 2006 WRX along with a full Motul fluid flush.
The install went relatively well, with the 'standard' rusted brake fittings (which a little bit of heat unstuck), but after assembling the brakes and bleeding the car exhibits a grinding sound (definately rotational - hits once per revolution). This is not always audible, but will start when the brakes get warm (normal driving).
We initially thought that the small anti-rattle or locating clip (they go on one upper corner of each pad on the 4-pots) were to blame as they would not stay in position as the HPS's appeared to be slightly wider than the stock pads. Removing these had no effect. All factory lube points have grease on them, as I just came off of a 4-pot install on my 2009 and remembered all the factory listed lubrication points. We also compared the brakes to mine - they matched assembly wise. Everything is clean and tightened and quadruple checked.
I found a few threads that stated that sometimes a defective rotor can cause rubbing (too large of a rotor), but by the time we get it up on stands, it seems to cool enough that it goes away.
Ideas??
Obsessive is offline   Reply With Quote
Old 05-02-2010, 10:16 AM   #2
dlross
Member#: 244931
2006 wrx
aspen, white
Originally Posted by Obsessive View Post
Hello all.
Ideas??
could be a bad rotor. if you can hear which one it is coming from take the rotor somewhere that has a lathe machine and have the run it on there with a dial indicater to make sure its true.
dlross is offline   Reply With Quote
Old 05-02-2010, 03:04 PM   #3
Obsessive
Member#: 77302
damn well better
Ahh, good suggestion. I used to turn rotors when I worked at NAPA when I was going to college (about 15 years ago )... We put them on the lathe and checked runout with a dial indicator with a magnetic base.
Didn't even think of that for some reason....
Thanks!
Old 05-02-2010, 05:19 PM   #4
Scooby-ohses
Member#: 187707
06 Impreza wrx
obsidian black
have the same problem, same pads and oem rotors. no fluid or lines though. broke them in the way hawk recommends, expected a little noise during break in. now it sounds like bare metal contact. and they rub all the time(swishswish).
Scooby-ohses is offline   Reply With Quote
Old 05-02-2010, 05:33 PM   #5
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
The only time I have done something similar to this is when I accidentally bent the the "depth feelers" down onto the rotor, meaning those thing rubbed and made a LOUD ANNOYING sound. Took the pads back out, and bent the "feelers" back, and Bob's your Uncle.
Good luck!
- dow
dowroa is offline   Reply With Quote
Old 05-25-2010, 12:34 AM   #6
FXTRunner
Member#: 104289
05 Forester
CGM
Any update on the grinding noise did it go away? I'm having the same issue...
FXTRunner is offline   Reply With Quote
Old 05-25-2010, 10:50 PM   #7
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Same exact setup here. Hawk hps pads, oe style rotors, motul dot 5.1 fluid. Swish swish swish. I can't figure it out. I've just learned to live with it and accepted it as part of being able to stop the car extremely fast for oe calipers
Pearly_Whites is offline   Reply With Quote
Old 05-25-2010, 11:15 PM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
make sure the pad packing plate is not too large. If it is it will rub the tophat on the rotor.
ALSO, if your grinding noise is from the rear check the dusk shields to make sure they are not hitting the rotor. the lower edge seems to get bent very easily.
After that check the protrusion of the lip for the hand brake drum. There's been a number of threads that the protrusion on many aftermarket rotors is too big and it rubs.
Old 05-25-2010, 11:20 PM   #9
Obsessive
Member#: 77302
damn well better
Thanks for the advice. The rubbing was from the front (drivers side) only - so the handbrake drum wasn't an issue nor is the dust shield. The 'packing plate' (do you mean backing plate??) could be an issue. We didn't see any rub marks, directly after the install - but by now he should be able to see something if it's been rubbing.
From what I understand, the noise has diminished, but is still there...
Old 05-26-2010, 06:38 AM   #10
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Yeah mines upfront too and no score marks on anything. Phantom rub lol
Old 05-26-2010, 01:57 PM   #11
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
OP, what pad are you coming from?
Since you're going to HPS, I'm guessing you might be coming from stock; in which case, this might just be the chatter the non-OEM pads sound like. After break in and wearing the pads enough to mate with the rotors, the scrapey sound goes away.
chimchimm5 is offline   Reply With Quote
Old 05-26-2010, 02:28 PM   #12
bzbuzz
Member#: 116052
2011 STI ( Sold )
lol same exact problem i have.. autozon rotors, hawk hps.. i get swish swish swish...
bzbuzz is offline   Reply With Quote
Old 05-26-2010, 02:29 PM   #13
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Make sure you didn't bend the dust shield so its rubbing on the rotor. Give it a good push around its edge away from the rotor.
twizzstyle is offline   Reply With Quote
Old 05-27-2010, 10:36 PM   #14
Obsessive
Member#: 77302
damn well better
HE was coming from stock (it's a buddy's car). He did say it has diminished, so we'll see what happens as the miles get put on em'.
Thanks for the input.
Old 05-29-2010, 03:32 AM   #15
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
I have the same setup and get the noise... Did anyone find out what this was besides the shield?
RallyIt07 is offline   Reply With Quote
Old 05-29-2010, 10:53 AM   #16
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
There is a long thread on here that I can't seem to search for now (has search been disabled?)
The park brake drum often contacts the backing plate on the bottom after it has some rust buildup.
Sometimes you only hear it on turns when there is some flexing.
That thread should be a sticky. I believe it's titled something like "solution to this common problem"
-Ken
KNS Brakes is offline   Reply With Quote
Grinding sound after brake install scooter4483 Brakes, Steering & Suspension 1 04-14-2010 12:12 PM
soft rubbing/grinding sound from rear mc2 Transmission (AT/MT) & Driveline 3 09-14-2009 11:33 AM
Need brake help: terrible grinding sound after coilover install shanemono4 Brakes, Steering & Suspension 11 06-19-2009 10:02 PM
rub/grind sound when i turn the wheel VTSubieRS Brakes, Steering & Suspension 7 03-29-2006 08:34 PM
Grinding sound after kartboy ss/bushing install flyingace Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-05-2002 12:30 PM
