Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 05-02-2010, 10:27 PM   #1
05BlackSTiCarbon
Member#: 185492
2005 STi
OBP FR 3071 twinscroll
Default fitment issues 2009 STi bbs on 2005 STi?
Im thinking about picking up a set of the 2009 BBS 18x8-8.5? +55 offset? correct me if im wrong please, wheels that are on the new STi. Tryed to find the answers im lookin for but havnt been able too. What all is needed to fit these wheels on a GD body STi? Fenders? Spacers? ....also im on k&w coilovers..if that helps.
05BlackSTiCarbon is offline   Reply With Quote
Old 05-02-2010, 11:14 PM   #2
mosc
Member#: 177401
2015 STi White
they fit fine, no work needed. The offset is high if you want to run wide tires but they're great with 225/40R18 or 235/40R18
mosc is offline   Reply With Quote
Old 05-03-2010, 02:43 AM   #3
JDM Junkyard
Member#: 31062
1985 land bruiser
still will not fit...need 10 mm spacers in the back to clear the struts.
Either that or throw on 25mm bolt on spacers all around for a safe and reasonably better way to make them fit. 25mm spacers don't require stud removal or trimming of the stock studs.
FYI...I have a full set of 25mm spacers for sale...=) kics 25mm bolt on spacers used for 3 days...haha.
JDM Junkyard is offline   Reply With Quote
Old 05-03-2010, 03:35 PM   #4
krazy
Member#: 56400
2004 Subaru STi-SOLD
custom roofrack brackets!
JDM Junkyard, so what you're saying is that they are wide and would interfere with the struts... soooo in theory, if I were to get some 5x100 to 5x114 hub adapters that were 25mm thick, I would be peachy (aside from wheel bearing issues)? I've really been throwing this idea around in my head for awhile.
krazy is offline   Reply With Quote
Old 05-03-2010, 04:23 PM   #5
JDM Junkyard
Member#: 31062
1985 land bruiser
Yes that will work
Old 05-03-2010, 04:32 PM   #6
mosc
Member#: 177401
2015 STi White
This is bad information. They fit without spacers. 18x8.5" +55 clears the strut.
NO!!!! FFS. Again, bad advise. First off the 04 STi is 5x100 and if you want conversion adapters, they're like 39mm thick. 55 - 39 is a pathetically low +16. That's absurd offset. "peachy" is not even remotely close.
Old 05-03-2010, 04:37 PM   #7
JDM Junkyard
Member#: 31062
1985 land bruiser
This is not bad information….it’s great information.
They do not fit KW coilovers as the OP stated he has. They do fit with stock struts, but the 2nd person asked for a 5x100…so you need to get the hub conversion spacers.
Read before responding please….
Kics makes a 15mm hub conversion spacer...and Ichiban makes a 25mm conversion spacer.
Old 05-03-2010, 04:42 PM   #8
krazy
Member#: 56400
Yea there are a number of different manufacturers for the wheel spacer/hub adapters out there. I believe 15mm is the smallest they make. I'd love to do this one day, but it is a lot of money to drop at one time to find out they dont work. Good info in this thread nonetheless.
Old 05-03-2010, 04:44 PM   #9
mosc
Member#: 177401
2015 STi White
15mm hub conversion spacers involve cutting the stock bolts.
Sorry if K&W coilovers are so much wider than stock struts.
Old 05-03-2010, 04:45 PM   #10
krazy
Member#: 56400
Yea, I would opt for 25mm spacers all around to accommodate the width of the wheels too.
Old 05-03-2010, 05:56 PM   #11
JDM Junkyard
Member#: 31062
1985 land bruiser
exactly...which was what I stated above...
Old 05-10-2010, 03:53 PM   #12
iDrove
Member#: 183992
'08 WRX Hatch
WRB 18G-XT'd
OP,
I just picked up a set of the 08 STI BBS in the size you mentioned and stuck them on the wife's 07 STI. They fit and DO NOT touch on stock suspension. At full lock over uneven road, they slightly rub, but other than when I was doing a u-turn after putting them on to see if they rubbed, she's had no rubbing issuses since. THis is with the 245/40 Sport Cups that they came with. They look really really nice as well.
iDrove is offline   Reply With Quote
Old 05-10-2010, 04:02 PM   #13
krazy
Member#: 56400
Originally Posted by iDrove View Post
OP,
peektures?
Old 05-10-2010, 04:21 PM   #14
mosc
Member#: 177401
2015 STi White
I would argue they only rub at all because the tire is too tall. if you got a reasonable tire height instead of using the stock 08 STi tires, you'd have zero issues.
And the k&w coils must be pretty wide to have clearance issues with 8.5" of width at +55. That's only 8mm closer than the stock wheel even ignoring the tire. 235/45R17 is a common tire choice for the factory STi wheels which is 5mm wider and a little taller. I am surprised somebody makes a set that thick.
Old 05-10-2010, 04:23 PM   #15
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
That's a ridiculously stupid idea to be honest. 10mm is what he should be looking at.
Uh, no. Scratch that idea from your head.
Byzantium is offline   Reply With Quote
Old 05-11-2010, 04:46 PM   #16
iDrove
Member#: 183992
'08 WRX Hatch
WRB 18G-XT'd
Default 08 STI BBS on 07 STI.
It's the wife's car, so I got no say on tires or anything. We found these fairly cheap, and she didn't want different tires or anything. She's a cheapass.
They look really good though, and fit well. Enjoy!
Even the wife was pleased with how the pictures came out. I had to DRAG her kicking and screaming to go out and take these, but she was pleased when she got there!
Old 05-11-2010, 04:49 PM   #17
krazy
Member#: 56400
^wow that does look sweet!
Old 05-11-2010, 08:41 PM   #18
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
nice cars, old ellicott city is the shyt have you ever hit new cut?
jdmboy is offline   Reply With Quote
Old 05-12-2010, 08:17 PM   #19
followmylead
Member#: 238875
05 sti
aspen
+1 nice pix
followmylead is offline   Reply With Quote
Old 05-13-2010, 01:50 AM   #20
JDM Junkyard
Member#: 31062
1985 land bruiser
stock STI shocks along with WRX shocks for that matter will allow the 08-10 STI BBS wheels to fit. It just doesn't fit with the KW coilovers.
Old 05-14-2010, 04:30 PM   #21
iDrove
Member#: 183992
'08 WRX Hatch
WRB 18G-XT'd
Yeah, I love New Cut Road. And a few out near BWI.
Thanks for the feedback. It was a cost-effective way for the wife to "spruce up" the looks of her car. I really like how it turned out.
White STi BBs on UGM STi....... gregbenoit Member's Car Gallery 26 07-11-2008 01:56 AM
2005 sti bbs on 2004 wrx? Bogus83 Tire & Wheel 2 10-23-2006 11:11 AM
any fitment issues with 35mm offset on 05's? VTSubieRS Tire & Wheel 1 05-17-2006 10:21 AM
5 bbs rims-2005 sti-4 sale tvblue22 Private 'For Sale' Classifieds 3 02-27-2006 11:55 PM
