#1 |
Vendor Sales Rating: (61)
Member#: 18920
BAIC
Vehicle:2004 WRX/STI Aspen White |
Due to many calls/PM's about services, figured I'll post it up for you guys to see what's everything we do for your Suby.
30K,90k Mile Service : Price $350 OTD ($380 for Automatic Trans) * Mobil 1 Synthetic 5W-30 Oil W/ OEM Oil filter and Crush Washer * Tranny Fluid Flush: * Rear Diff Fluid Change: * Coolant Flush * Brake Fluid Flush: Valvoline Synthetic or ADD$50 for Motul RBF600 * OEM Air Filter * OEM Fuel Filter (not done on cars with intank filter at this mileage) * Check and Top Off All Fluid * Tire Rotation , Check Pressure & Retorque Wheels * Inspect Brakes, Belts, Oil leaks and ETC.... 60K,120k Mile Service : Price $400 OTD ($430 for Automatic Trans) * Same as 30/90k along with Denso Iridium Spark Plugs for 2.5L. NGK Platinum for 2.0L These Services will usually take about 3-4 hours Also... Every 105K miles, you should change out your Timing belt and Water Pump. We ONLY Use OEM Subaru Parts Price: $1450 * OEM Timing Belt * OEM Timing Belt Tensioner * OEM Water Pump + gasket * OEM Thermostat + gasket * OEM Idler Pulleys (4) * OEM Crank Seal * Coolant Flush GREDDY Timing Belt upgrade also available for extra charge Timing Belt Service will be a Full-Day 8 Hour Job. Please give us a Call to schedule an Appointment Thanks, Rob 510-226-8822
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 1701 Rogers Ave Ste# 10 San Jose, CA 95112 408-573-8899 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Paypal: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. *CA residents add 8.375% sales tax. AK, HI Shipping additional.* MAY SPECIAL ON MISHIMOTO/VOLK/PERRIN /BLOX. PM US FOR SUPER LOW PRICING! |
#2 |
Member#: 18920
BAIC
HKS drop in air filters are also available instead of the OEM filter. 02-07 WRX and STI add $35. 08+ WRX/STI add $40
__________________
| Thread Tools | |
| Display Modes | |
| TopSpeed Performs Subaru Services 15k/ 30k/60k/90k Services!!!! | TopSpeed | Services | 47 | 12-13-2009 03:44 PM |
| Need 30k, 60k, 90k Service ? ... LOOK HERE :) | SpeedElement | BAIC Vendor Classifieds | 0 | 04-12-2006 08:34 PM |
