Old 05-03-2010, 02:06 PM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Killer B Motorsport Header - Prototype Testing
I know a lot of you have been asking when I was going to get going on this thing. So here we are with some pics and 3rd party testing results
Some features:
The Killer B Motorsport Holy Header was developed using state of the art CAD software & simulations to determine optimal design to increase power in the mid to high RPM range. Short as possible primaries with a single secondary significantly decrease header volume allowing exhaust gas pressure to build quickly. Symmetrical 4-1 design maintains high and consistent exhaust velocity as RPMs rise. You can expect faster spool up time compared to long primary/double secondary designs. A difference you will immediately notice in throttle response and the ability to hold more power higher into the revs.
Features include:
Short Equal Length Primaries. The shortest possible length primaries you can have on an Equal Length header. Short means less header volume and quick spool up.
Symmetrical Primary Design. All primaries have a similar tube length AND bend geometry. This keeps the pulse velocities high and consistent compared to equal length headers with different (non-symmetrical) primary tubing geometry.
Smooth Mandrel Bends. All of the bends utilize a mandrel for smooth non-restrictive flow. Not only that, we use the largest bends possible at every location. It would be cheaper to use 2” bends everywhere, like others do, but that’s not going to give the best performance.
Thick Walled 321 Stainless Steel Construction for Long Life. 321 is alloyed with titanium, costs more, a lot more, but it’s the ideal material for high temperature turbocharged applications. Would 304 stainless work, yes, but the temperatures on our turbocharged cars can exceed the limits of 304 stainless enough to make them brittle and crack. 321 stainless steel has higher strength and toughness at elevated temperatures. It was developed by the aircraft industry specifically to address 304 stainless manifolds that were cracking. Killer B Motorsport is the only company that manufactures full 321 headers.
High Heat Retention. 321 stainless steel conducts less heat than 304 stainless steel. The short primaries and properly sized secondaries also pull less heat from the exhaust gasses increasing turbine efficiency. Large tubing headers expose the exhaust gasses to more surface area transmitting more heat and reducing exhaust energy. You can also ceramic coat or wrap our headers (and keep the warranty) without exceeding the temperature range like you can with 304 stainless.
V-Band Up-Pipe Connection. Why V-Band? Fast, easy, no gasket, no leaks, perfectly concentric alignment of tubes for no disruption of flow, what’s not to like!
Up-Pipe included. Of course it comes with an Up-Pipe! This header was designed as a complete system. Using other up-pipes would only compromise performance, and nobody wants that.
Weights only 17 pounds (vs. OEM weights 25 pounds)
Works with OEM EJ25 Oil Pans, and Killer B Motorsport Performance Aluminum Oil Pan
Made in the USA and Killer B quality!
The Pics...
Testing by YimiSport...
15ft/lbs of peak gains, 40+WTQ at 3,900RPMs
27whp peak gains and bigger mid-range gains
More power EVERYWHERE!
Testing by EFI Logics...
8wtq of peak gains with 28+ WTQ at 6,100RPMs
27whp peak gains with 31+ WHP at 6,200RPMs
And more testing... THANKS EPIC MOTORSPORTS!!
18wtq of peak gains with 27+ WTQ from 4,400-5,500RPMs
25whp peak gains with 30+ WHP from 4,800-5,700RPMs
When do these headers choke? We still don't know
Killer B's GD
Customer's GR
KillerBMotorsport is offline   Reply With Quote
Old 05-03-2010, 02:31 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Questions that will sure to come:
What cars will this fit on?
Why are you using a crappy Fram filter?
Old 05-03-2010, 02:41 PM   #3
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
It says Equal Length above. at least read the post first
xrocket21 is offline   Reply With Quote
Old 05-03-2010, 03:07 PM   #4
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Do you need a test car :-) I am will to try.
BlackFighter is offline   Reply With Quote
Old 05-03-2010, 03:31 PM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Good questions.
It fits an 05 STi for sure and probably a safe assumption it will fit pre-08 Impreza models, although that has not been verified.
The filter was free with my purchase of a whole bunch of the "that stuff will blow your motor" Mobile 1.
It sounds NOTHING like the OEM header. The GPMoto that was on there had the usual EL sounds. This one is a touch quieter from the front of the car (my guess is because of the thicker wall material), but has a deeper tone than the GPMoto
You're not the first to ask, but I'm not taking anyone up on that offer until I get the final material costs nailed down.
Oh and it also weighs 16 pounds. For comparison the OEM one weighs 25 pounds.
Old 05-03-2010, 04:12 PM   #6
WRX SEX
Member#: 212171
08 SSM WRX
MSPT Tuned: 254whp/343wtq
Design looks good, im officially curious
why wouldn't this fit on 08+ WRX?
WRX SEX is offline   Reply With Quote
Old 05-03-2010, 04:20 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It may. I know the crossmember is different from 08-on so I'm trying to be a bit cautious until I know for sure.
Old 05-03-2010, 04:28 PM   #8
WRX SEX
Member#: 212171
08 SSM WRX
well i'm crossing my fingers because I'm very interested to see how this turns out, especially because I'm in the market for a quality header
Old 05-03-2010, 04:33 PM   #9
RE4PER
Member#: 142753
2005 STI
This may be a stupid question, but how come on your graph the power and torque line cross at 4200 instead of the usual 5252? Just curious if I'm missing something?
RE4PER is offline   Reply With Quote
Old 05-03-2010, 04:54 PM   #10
richy_21
Member#: 58670
2005 got muuuuu?
and before the header was installed dyno printouts?
richy_21 is offline   Reply With Quote
Old 05-03-2010, 04:58 PM   #11
nhat
Member#: 140163
03 STi
hellaflunctional
saw this in person. i'm saving up to buy one by the end of this year
fitment will probably require the 2.5L oil pan unless you don't care about your exhaust manifold rubbing on the 2.0L pan.
Old 05-03-2010, 05:32 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Good eye. Look on the sides and you'll see the scaling is different. I don't know why it's setup this way.
I have plots from last year, the year before and a few others, but none on that same dyno. I had a window of opportunity, but not the time to do a true comparison. The numbers are better than any I've had with the GPMoto header, which as you know I really liked. I can post some old graphs, but I don't know how relevant they would be. I'll dig through what I've got tonight.
It will definitly only work with a EJ25 pan (or Killer B pan ) but if you do any performance or track driving you should consider an EJ25 pan or aftermarket piece anyway. The EJ20 pans have a higher probability of oil starving under hard cornering.
Old 05-03-2010, 09:17 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Here is one from fall 2008. Exact same setup, but with the GPMoto header.
Here's another one from Spring 2009. Again, exact same setup but with the GPMoto header.
Old 05-04-2010, 02:00 AM   #14
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Looks pretty cool. What are the diameters of the primaries and secondary / UP?
Old 05-04-2010, 01:27 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
ID 1.50 and 1.75
Old 05-04-2010, 01:56 PM   #16
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Do you think you will build these to fit stock or aftermarket 2 bolt up-pipes?
Murphdog is offline   Reply With Quote
Old 05-04-2010, 02:42 PM   #17
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No, it will have a v-band to our up-pipe that is included. We'll eventually have EWG, rotated and other options. Building to other up pipes just adds variables to the 'system' that may or may not perform properly.
Old 05-04-2010, 06:49 PM   #18
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Makes sense. So you should defiantly build ones for EWG right away so I won't have to wait.
Old 05-04-2010, 07:38 PM   #19
ardevas09
Member#: 164710
05 440whp STi
2014 Evo X
this! I'd love to ditch my 3 bolt setup
ardevas09 is offline   Reply With Quote
Old 05-04-2010, 07:50 PM   #20
arghx7
Member#: 232940
arghx7 is online now   Reply With Quote
Old 05-04-2010, 10:29 PM   #21
KurtP
Member#: 44836
1999 Fozzy
but i dont want to buy another header
KurtP is offline   Reply With Quote
Old 05-04-2010, 10:43 PM   #22
seekndestroy19
Member#: 209358
06 Sti
sound clips?
seekndestroy19 is offline   Reply With Quote
Old 05-04-2010, 11:16 PM   #23
BlackFighter
Member#: 193940
2004 WRX STI Black
will there be a non eq setup?
Old 05-04-2010, 11:33 PM   #24
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by seekndestroy19 View Post
sound clips?
I hope to have some this weekend. Idle, throttle blips, and a WOT through the gears.
No.
Old 05-04-2010, 11:38 PM   #25
richy_21
Member#: 58670
2005 got muuuuu?
Id like to see these on a big turbo setup...not some tiny vf39
Killer B Motorsport Radiator Shroud Legba Car Part Reviews 24 03-05-2011 02:06 PM
Google Streetview Catches Porsche Prototypes Testing AVANTI R5 Non-Subaru News & Rumors 17 12-31-2008 09:12 AM
Killer B Motorsport Sphere Shift Knob 30 bucks shipped Legba Car Part Reviews 0 12-21-2008 12:52 AM
Carbon Fiber Brakes - Prototype Testing araknyd Brakes, Steering & Suspension 34 01-24-2007 11:14 AM
