Old 05-04-2010, 02:56 AM   #1
The G.O.A.T.
Member#: 149724
1999 leggy gt 5speed
Blood red
Default How do I get rid of my cel's after header install???
Well I finally put my headers on (heat wrapped and hi temp painted with 9 coats) yesterday and was wondering how to get rid of my cel's.
I do have a AccessPort and was wondering if there is any way to permanently clear the codes? I currently do not have the o2 sensors plugged in but I am planing on getting them installed and modified soon in the stock mid pipe before and after the cat, but will that clear the code?
I need to have cruse as I am going to be driving about 7,000 mi in the next 3 weeks (road trip )
And it would really suck not having cruse for the trip so any answers would be most helpful.
Thanks
Nick
The G.O.A.T. is offline   Reply With Quote
Old 05-04-2010, 04:29 PM   #2
The G.O.A.T.
Member#: 149724
Blood red
The Codes are p0037 and p1139 is there any way to turn those off???
Old 05-04-2010, 06:01 PM   #3
Dan707
Member#: 213282
Default Front o2 sensor
Make sure you have the front o2 sensor install (driver side of exhaust/headers) otherwise you will keep getting the the cel's & gas millage will be very bad.
Before install the front o2 sensor reset your ecu first with your access port.
Just installed headers last week in my '05 STi & my front o2 sensor went bad after the installation so had to buy new one (not cheap)!!!
Good luck,
Dan
Dan707 is offline   Reply With Quote
Old 05-04-2010, 07:03 PM   #4
The G.O.A.T.
Member#: 149724
Blood red
So just the front? Or do I need both? And what do I do if I want to go catless?
Update
Saen from rallitek just called and explained everything. what service!!! FTW
Old 05-04-2010, 07:26 PM   #5
Cobb Tuning
Member#: 4803
You cannot turn off these codes, they are for the front O2 sensor. This sensor is vital for proper engine function. You will need to have this sensor installed IMMEDIATELY in order for your car to run properly. Right now your ECU has no idea what your fueling is, which is very bad.
Travis
COBB Tuning
Old 05-05-2010, 07:33 AM   #6
Dan707
Member#: 213282
Take Travis advise,
I have both & now going to install my LC-1 wideband also after the downpipe and I'm already catless with a protune stg.2 map.
Believe me you have to install especially the front o2 sensor (A/F ratio Part number is 22641-AA211)in you exhaust/header manifold.
Dan
How do I get rid of my cel's after header install??? The G.O.A.T. Normally Aspirated Powertrain 23 05-07-2010 03:54 PM
How do I get rid of my cel's permanatly with accessport The G.O.A.T. Engine Management & Tuning 4 05-05-2010 12:48 AM
How do I get rid of my Hickups?????? TheSilverFox Off-Topic 49 06-07-2007 09:03 AM
How do I get rid of my squishy feeling brakes? Homemade WRX Brakes, Steering & Suspension 17 10-24-2003 10:42 PM
How do I get rid of my front liscense plate holder? imprezive Interior & Exterior Modification 5 02-19-2002 01:33 AM
