Old 05-05-2010, 12:33 PM   #1
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
Default 2006whitesti's engine build PTE 6466 Updates on page 2
I figured I might as well document the process. Mostly standard stuff, just more info for the people who plan on a major build.
Specs are as follows
Engine/Power
Engine
K1 Billet Crankshaft
Manley Turbo Tough Rods
Manley box in box Pistons 9.3:1 cr
ACL Race Bearings
ARP 1/2" head studs
ARP Case Bolts
ARP sump hardware
ARP intake manifold hardware
Subaru OEM gasket set
OEM subaru ej257 block halves 203
AEBS wet sleeves
OEM Subaru B25 head casings
Kelford 199-c camshafts
BC adjustable exhaust cam gears
Custom port and polish
Coated piston tops, combustion chambers, valve faces, and exhaust ports
Supertech +1mm Stainless intake valves
Supertech +1mm Inconel exhaust valves
OEM Subaru Valve seals
OEM Subaru Valve locks
Supertech Titanium retainers
Supertech 80 lb dual valve springs
Subaru OEM head gaskets
Subaru OEM 11mm oil pump "gutted"
Custom designed PRC 6 stage Dry sump pump
Custom Billet oil "sump"
Custom Oil cooler
Custom Intake Manifold
Cusco engine/trans mounts
NGK one step colder plugsa
Boomba Racing 75mm Drive by wire throttle body
Fluidampr damper
ARE dry sump mandrel
Meziere electric water pump
Block O ringed .008
Block line bored
Block halves machined flat
Complete rotating assembly balanced
Gates Kevlar Timing belt
Ecentric idler adjusters
Custom manual timing belt tensioner
Custom front oil feed line
Valve covers modified for -12 an scavenge
Engine control and ignition
Haltech Elite EMS
AEM twinfire ignition
MSD wires and boots
mallory coils
Mechman high output billet alternator
Turbo
PTE 6466
PTE wastegate
Tial Q bov
custom intercooler piping
Treadstone core
Custom built front mount manifold
Misc.
Koyo Aluminum Radiator
Custom 3.5" exhaust
Apexi Turbo Timer
XS power batteries
Summit racing battery relocation kit
Header Wrap
Wire tuck
Fuel system
Walbro 255lph intank pump
Fuel lab FPR 13109
Fuel lab fuel pressure gauge
New 8an fuel feed line
New 6an fuel return line
Custom surge tank
Fuelab prodigy pump
Five 0 Motorsport 2200cc injectors
There is a ton of custom parts that I have left out for now. More details will be given as things come together. I will try and get some pictures of the build process over the next few weeks.
Last edited by 2006whitesti; 10-27-2015 at 02:22 PM. Reason: 2006whitesti's engine build PTE 6466 Updates on page 2
2006whitesti is offline   Reply With Quote
Old 05-05-2010, 12:39 PM   #2
2006whitesti
Member#: 124311
Some random pictures, more just me messing around. I will have some better material soon
Old 05-05-2010, 12:40 PM   #3
2006whitesti
Member#: 124311
My heads
Cosworth for comparison
Stock port, cosworth, mine
Old 05-05-2010, 12:42 PM   #4
2006whitesti
Member#: 124311
Intake flow numbers are as follows....
Stock 06 STi head( would not flow any more above .450)
.100 84.9
.150 131.1
.200 174.33
.250 215.7
.300 242
.350 253.3
.400 258
.450 260
My head
.100 95.3
.150 144.5
.200 189.23
.250 233.6
.300 269.9
.350 294.4
.400 307.3
.450 315.4
.500 319.9
.550 322.56
Old 05-05-2010, 06:32 PM   #5
2006whitesti
Member#: 124311
On more random picture of head parts.
Old 05-05-2010, 06:56 PM   #6
toyjunkie
Member#: 177315
2004 sti
wrb
nice build. what is your goal? this seems very close to what i am putting together. i cant wait to see your results
toyjunkie is offline   Reply With Quote
Old 05-05-2010, 07:37 PM   #7
2006whitesti
Member#: 124311
Well to be honest, at this point I am not sure what to expect. It started as a street build and snowballed in to the mess I have now. Hopefully it turns out to be a very driveable car on pump, and a monster on e85 and or vp116.
Old 05-05-2010, 07:45 PM   #8
toyjunkie
Member#: 177315
2004 sti
wrb
i got me a snowball too. SNOWBALL FIGHT!!!!! he he heh
Old 05-05-2010, 08:16 PM   #9
2006whitesti
Member#: 124311
I hear ya. It is crazy how fast a project can get out of hand. I will be doing plenty of track days with the car, as I have with every other vehicle I have owned, but I still want the car to be somewhat streetable. If I find it to be to much, I will just make it a dedicated track car. This cycle never seems to end.
Old 05-06-2010, 05:27 AM   #10
2006whitesti
Member#: 124311
Here are just a few more of random parts laying around.
New 11mm oil pump with second shim installed.
Old black oil filter and new blue one.
Gruppe-s flywheel
Old 12-14-2010, 10:45 PM   #11
2006whitesti
Member#: 124311
Some more parts pics.
K1 Billet Forged 79mm Crankshaft (thanks Maxwell Power)
Wiseco Forged pistons, pins, and rings.
ARP case bolts
Old 12-17-2010, 11:14 PM   #12
2006whitesti
Member#: 124311
Block is leaving Monday for sleeves, boring, and line hone. I can not wait to see this thing.
Old 12-17-2010, 11:23 PM   #13
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Definitely subscribed. Cool build so far... can't wait to see it all together... those parts are so shiny
Jessekrs123 is offline   Reply With Quote
Old 12-17-2010, 11:41 PM   #14
Ryan314
Member#: 82989
Hybrid EJ257
Very nice. Is there a reason why you went for the stainless valves over the black nitrided ones?
Ryan314 is offline   Reply With Quote
Old 12-17-2010, 11:44 PM   #15
nes
Member#: 258299
2009 wrx
blue
looks like your crank is a model
nes is offline   Reply With Quote
Old 12-17-2010, 11:55 PM   #16
2006whitesti
Member#: 124311
I can't wait either. 3.5 years in the making. I do not even remember how many miles my car has on it. LOL
Damn I can not believe you caught that. Actually those valves were for another head. My intake valves are the nitride coated ones.
I know. It is even more impressive in person.
Old 11-02-2011, 07:27 PM   #17
2006whitesti
Member#: 124311
And one of the bay.
Heads are off again and at machine shop getting some more work done. Hopefully the engine will be together soon. I broke my back so things are moving even slower than before.
Old 05-11-2012, 02:58 PM   #18
2006whitesti
Member#: 124311
Bump cause I have decided to go dry sump. Hope to have a few pictures of the parts up in a few days. If anyone needs a brand new 11mm oil pump, pm me. It has had one shim added, can be removed if you would like.
Old 07-10-2012, 07:58 PM   #19
FLYGUY09
Member#: 281578
FAST WRB 02, Slvr 07
91 Stealth R/T VR4 'SOLD'
Howd this build go??
FLYGUY09 is offline   Reply With Quote
Old 07-14-2012, 12:33 PM   #20
2006whitesti
Member#: 124311
Still working on it. I should have some pretty big updates in a few weeks.
Old 10-10-2012, 10:16 PM   #21
2006whitesti
Member#: 124311
Small update. Got the engine bay sprayed a few weeks back. Everything is coming together. Just waiting on a few parts and then I will post a real update.
Old 10-11-2012, 12:50 AM   #22
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
Very nice build. In for more updates.
gotsugg is offline   Reply With Quote
Old 10-11-2012, 07:15 AM   #23
Wrblvsti
Member#: 334777
05 Wrx sti
World rally blue
Hey can u message me any small rebuild advise I recently blew my engine and need a rebuild looks like you know what to get and put it together I just need a point in the right direction before I spend money on parts I don't need it would be very helpful thank
Wrblvsti is offline   Reply With Quote
Old 10-11-2012, 12:44 PM   #24
2006whitesti
Member#: 124311
I will help any way I can. First thing you need to do is decide what the car is going to be used for. If you don't have an end goal, how will you know where to start?
Old 10-11-2012, 02:31 PM   #25
Wrblvsti
Member#: 334777
05 Wrx sti
World rally blue
Sorry I post on here like if everyone knows me and knows my car lol it's a 05 sti not looking for crazy numbers just a good solid build that will last if I hit anywhere in the 350 range ill b happy bit if I can get more hey I'll take it lol
Engine build questions? Engine Builders help!! awdeclipseguy Built Motor Discussion 7 01-03-2010 04:54 AM
Looking for information on engine build CUNNINGHAM Normally Aspirated with bolt-on Forced Induction Powertrain 1 06-09-2002 05:19 PM
anyone have one of those dyno or engine build up software kits? funscooby Motorsports 0 01-17-2002 02:44 AM
SomeTorque specifications needed for engine build. DJIMPREZA Technical Forum Archive 2 09-20-2000 12:51 PM
Tech Section Update - SOHC Engine Build Trey Technical Forum Archive 27 07-04-2000 01:26 AM
