Old 05-05-2010, 01:47 PM   #1
erikm
Member#: 107019
Stg2 08 STi MBP
Franz Diebold tuned!
Default -11 knock learning?
08 STi
Was just driving around normally and my DAM dropped to 0.5 all of a sudden, then I noticed that when I hit the gas in any gear my live data would show -11.8 knock learning for about 400rpms and then it would go back to 0.
Did this for about 3 minutes and then went away completely. DAM went back up to 0.8 and that is where it is at now.
I've had compression/leak down tests recently here are the results:
Cyl 1 - 147psi 10%
Cyl 2 - 145psi 8%
Cyl 3 - 150psi 8%
Cyl 4 - 142psi 12%
No smoke coming from exhaust or oil filler.... car drives great when the DAM is 1.0
Running the stock map as the OTS maps were not liked by my ECU either. Definitely have some issues causing this knock learning!
Help?
erikm is offline   Reply With Quote
How come I Can't see feedback knock correction, fine learning knock correction? AraSh Open Source Reflashes 23 01-08-2014 07:04 PM
HUGE knock learning but DAM stays at 1? erikm Engine Management & Tuning 18 05-22-2010 06:59 PM
Data logging newb: Knock learning vs. Correction Liquidr1 AccessPort 13 03-10-2010 01:42 AM
learn me about detonation/knock azn2yunr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-08-2005 09:53 PM
IAM = 16, Knock Correction learning turns off. jblaine Engine Management & Tuning 41 09-12-2004 10:49 AM
