Old 05-05-2010, 02:12 PM   #1
ret63
Member#: 191542
2010 Impreza OBS
Sage Green
Default Noticed a green connector under the dash disconnected?
I was in the process of installing my HD radio and noticed this under the dash (passenger side) by the carpet. It appears to be a green plug that is not connected....
Would anyone know what this for? Should it be connected?
ret63 is offline   Reply With Quote
Old 05-05-2010, 02:21 PM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Typically, that is half of the "flash block" and needs to be connected ONLY for flashing the ECU with a new map... my swapped 00' ONLY has the green connector, while others also have a white connector that gets jumpered while flashing..
So no, it stays disconnected..
Old 05-05-2010, 02:23 PM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Although, it's fun to plug it in and turn the ignition on and listen to the fuel pump do it's dance.. lol..
Old 05-05-2010, 02:26 PM   #4
ret63
Member#: 191542
2010 Impreza OBS
Sage Green
LOL! Thanks...
You would think something like that would be in a hidden place and not out in the open to fool with!
Old 05-05-2010, 03:13 PM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
It's usually not, it's usually under the steering column, it's where mine is located..
Upper left corner...
Maybe you aughta wire tie it up outta the way..
Old 05-05-2010, 03:13 PM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
daAAANNNG double post.. lol..
Old 05-05-2010, 11:33 PM   #7
Web Foot STi
Member#: 39086
2004 STi
The GD has that plug under the dash on the far left of the drivers foot well. It's kind of a pain, literally, to get to, but you can get to it.
Web Foot STi is offline   Reply With Quote
Old 05-06-2010, 06:13 PM   #8
Eyeflyistheeye
Member#: 69694
2014 EuroPinto 5MT
For what it's worth, a BL Legacy has two sets of green connectors, one under the glove box and the other inside of the fuse box that appear when you drop the dash.
The ones under the glove box are for flashing the ECU and the ones in the fuse panel are to use the onboard code reader.
Eyeflyistheeye is offline   Reply With Quote
Old 05-06-2010, 08:12 PM   #9
ICE_COLD
Member#: 159930
2006 STI
leave it unplugged thats the d-check
ICE_COLD is offline   Reply With Quote
Green connectors under driverside dash plus a white one Division By Zero Engine Management & Tuning 10 03-03-2006 11:15 AM
The unhooked green connector under the dash? fizzak Newbies & FAQs 6 12-22-2005 10:43 PM
Green Connector under steering dash in 04 STi. LESLIEx317537 Electrical & Lighting 2 07-27-2005 06:05 PM
The Green Harness under the dash? BillJC Electrical & Lighting 3 02-15-2003 08:15 PM
Weird green connector under dash? Eric SS Technical Forum Archive 4 08-27-2000 05:51 PM
