#1 |
Member#: 237554
i have a 96 impreza coupe and live in mass so i have to pass emmisions.
my plan is to do a hybrid build starting with a ej257 shortblock new from subaru(should be picking up soon) and eventualy buying new heads ecu and harness basicly what i want to kno is if i want to run avcs and pass emmision do i have to use the udsm 2.5 heads and ecu and just say screw the whole hybrid idea or could i use jdm 207 heads and run a usdm sti ecu to control the avcs? if i use 2.0 heads i plan on getting the combustion chamber machined to get the CR back to normal instead of running a thicker head gasket . i would just like to run the avcs without dropping bank on usdm heads.
#2 |
Member#: 237554
are usdm and jdm 2.0 heads the same besides the avcs? and is going for the avcs even worth it in the end if im doing a hybrid swap? should i just go with factory us wrx heads with upgraded internals and save myself the trouble
#3 |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
save yourself alot of work and headaches and do a full 2.5 conversion.
#4 |
Member#: 240161
Vehicle:2002 wrx wagon R.I.P 87 bmw e30 |
| Thread Tools | |
| Display Modes | |
| Exciting New Head Option for EJ205/EJ257 Hybrid Builds! | Equilibrium Tuning | Built Motor Discussion | 447 | 02-28-2013 10:02 PM |
| Suberdave's EJ257/207/H/G/K hybrid build | suberdave | Pre-2002 Factory Turbo Powertrain | 32 | 10-31-2011 08:27 PM |
| ej251/ej257 hybrid sohc build - ARP hsk q's | master c | Built Motor Discussion | 6 | 04-07-2011 11:19 PM |
| FS: 2002 WRX 2.5 EJ257 Hybrid Build | 02WRXmoddedrex | Private Vehicle 'For Sale' Classifieds | 3 | 04-14-2010 09:25 PM |
| Oil Leak on Driver's Side after EJ257 Hybrid Build | lancelucas | Service & Maintenance | 10 | 05-28-2008 10:23 AM |
