Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Private Classifieds
Old 05-05-2010, 11:13 PM   #1
subygirl
Member Sales Rating: (9)
Member#: 61617
2009 WRX 5-door
Dark gray metallic
12/31/15 UPDATE: I want this car and parts gone before we have to move again. We are accepting offers on the whole lot of loose parts and the parts car. We will consider all offers. Parting this out got pushed to the back burner for a few years which is the reason for the lull
This is an updated list as of 6/1/13!
Our GTX sold last year, but we still have the parts car sitting around. Car was hit in the rear, but there is minimal damage except for the wrinkle in the frame at the doors.
We have brought a slew of parts back from VA and are now housed in our garage. The parts car is still available to be purchased as a whole for a now discounted price, and does include some extra parts we couldn't bring back with us.
Loose parts in NC Some stuff has prices with it, others we are still researching current market price - feel free to offer
Head with cams
Miata automatic pistons (gives gtx higher compression) & 2 gtx pistons –
Steering column controls -
Stock turbo with cracked manifold and some shaft play–
Complete injector harness –
Passenger side slightly rusty motor mount –
Top transmission motor mount good shape –
8 used hydraulic lash adjusters –
starter –
New old stock drivers door seal in factory bag -
Stock BPV
Top radiator mounts good condition –
Front sway poly bushings, -
Front stock sway bushings –
8.5mm Jacob’s electronics energy core spark plug wires
Gtx 1 wire oxygen sensor
HVAC controls –
2 new in bag hydraulic lash adjusters
Fuel level sensor – free (go with gas tank?)
Turbo oil feed line –
Stock fuel rail with good fuel pressure regulator –
Passenger side window motor
Power window switch passenger side
Steering column plastic pieces
80W 4in Sony Xplode speakers, 25W RMS, 4ohm impedance
MAF from 626 GT
MAF from non turbo 323
7/8ths master cylinder with fluid reservoir
Corner light driver’s and passengers side
Gtx stock stereo
Passenger side tail light
Gtx hub, pre trimmed for vr4 big break front
Starter
2 alternators
Passenger side mirror with chunk taken out of edge
Drivers side under seat heating vent
E spec headlight with corner light (corner has broken glass)
2 or 3 heads
1 block
The parts car is currently sitting just outside of Roanoke, VA at the in-laws. The car includes:
Full interior (minus headliner)
a second set of rear interior seats
Full dash minus center console pieces
sensors
Falken Zeik 512 tires with 1,000 miles on them
stock wheels
stock struts - needs rebuild
full sealed power steering rack
all glass and body panels
all brakes
all 4 good hubs
rear axles
rear diff
sways and end links
**parts car does not have the following: passenger side door and fender, spoilers, a/c system, drivers side mirror, front bumper assembly, sunroof assembly and crank
Car is dirty from sitting under a car cover, but there is no rust and is water tight. We have title in hand. Taking offers.
List of sold and pending parts
Front Seats - SOLD
Gas tank - SOLD
Gas filler neck -SOLD
Sunroof assembly and crank - SOLD
Upper and Lower spoiler - SOLD
Center console around shifter - SOLD
Diff lock motor (needs testing) - SOLD
K&N stock replacement filter - SOLD
Light bar , 2 super sport lights and 2 blazer 120 lights - SOLD
HKS intercooler 10x10x3 core – SOLD
original Rod Millen Springs - SOLD
Roadrace Engineering full set of solid strut tower braces - SOLD
Spare transmissionSOLD
3 or 4 Good Radiators - SOLD
3 heads 1 SOLD ... 3 still available
Good HKS muffler from the original system designed for the GTX SOLD
AFM cone adapter with an Injen Cone filter (cotton like K&N) - SOLD/Collins
Shifter Cables SOLD
oil pump SOLD
good fuel tank with pumps pending
Road Race remapped ECU SOLD
stock flywheels SOLD
gauge clusters SOLD
626gt Intercooler - SOLD
Road Race Manuel Boost controller SOLD
Dirtra Struts SOLD
Mazdaspeed Comp strut mounts. SOLD
Mazdaspeed top motor mounts SOLD
drive shaft SOLD
Front bumper SOLD
Whole wire harness SOLD
axles SOLD
Front strut brace – $80 SOLD
Rear strut brace - $80 SOLD
Rear Dirtra strut assemblies w/Rod Millen springs and Mazdaspeed comp top mounts - $325 SOLD
Front Bilstein insert assemblies w/Rod Millen springs and Mazdaspeed comp top mounts- $325 SOLD
AFM cone adapter with Injen filter - $30 SOLD
RRE manual boost controller SOLD
3 broken tab center wheel caps SOLD
2 4pt harnesses, unknown brand, 2in webbing SOLD
Engine wire harness including fuse box SOLD
Valve cover SOLD
Sunroof assembly and crank SOLD
drivers side mirror SOLD
rear seat belts SOLD
passenger side complete door SOLD
passenger side front fender SOLD
Front bumper turn signals (2), connectors taken off, wires still there SOLD
Front speaker grill covers SOLD
Grab bag of rusty motor mounts SOLD
front headlights and corner lights SOLD
shifter cables SOLD
full AC system SOLD
a large rubbermaid container full of miscellaneous parts like cam gears, braces, calipers, etc SOLD
subygirl is offline   Reply With Quote
Old 05-08-2010, 07:45 PM   #2
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 05-11-2010, 12:32 PM   #3
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 05-13-2010, 07:00 PM   #4
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 05-17-2010, 06:58 PM   #5
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 05-19-2010, 06:55 PM   #6
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 05-22-2010, 10:57 AM   #7
Dhillbilly1
Member#: 247404
Originally Posted by subygirl View Post
Our GTX sold last year, but we still have the parts car sitting around. Car was hit in the rear, but there is minimal damage except for the wrinkle in the frame at the doors. Whole car is complete but without an engine. We do have several engine components sitting around that could be put together to make a complete engine set up though.
All parts are currently sitting just outside of Roanoke, VA at the in-laws. I do not have pictures because we live in Indiana. We will be going down there over memorial day weekend (may 29-31) and will be pulling parts people are interested in and selling parts to those that can drive there. We will be able to meet up with people on the way back through to sell/drop off parts.
A mostly complete list:
original Rod Millen Springs - pending
Poly center bushings for stock swaybars
HKS intercooler (10"x10"x3" core)
Spare transmission
Control arms
3 heads
one block
miata pistons (automatic I think)
connecting rods
RoadRace Rally air box
stock turbo on a cracked exhaust manifold
Another K&N airfilter panel that fits the GTX Box
Oil pans (one, maybe 2)
2 full sets of GTX seats (front and rear)
Shifter Cables
cams/ cam gears
oil pump
set of stock wheels with unused Falkin Ziek tires
stock flywheels
gauge clusters
626gt Intercooler
Dirtra Struts Pending
Mazdaspeed Comp strut mounts. Pending
Mazdaspeed top motor mounts Pending
Nuckles, hubs....
drive shaft
axles...
And.....Probably lots more
Right now we are accepting offers on all parts.
All of the parts should fit in the back of a pickup truck and the rest are stuffed into a rust free rolling chassis which can be towed by a dolly. (it was hit in the rear last year and is now used for storing clean parts)
$3,000 if you would like to take the car and all the parts as a whole.
interested in the prices on the wiring harness if it hasn't been hacked up,ecu,air box,and turbo/componets!
Dhillbilly1 is offline   Reply With Quote
Old 05-22-2010, 01:22 PM   #8
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
wire harness - what section of the harness are you looking for? Just the engine, or more?
RRE ecu - $200
RRE air box - $40
turbo - I am not sure on its condition. It might need to be rebuilt, or it might be ok. I won't know until I get my hands on it next weekend.
Old 05-22-2010, 02:16 PM   #9
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
Here are the only pictures we have right now. These were taken right after the accident 2 years ago.
Old 05-22-2010, 09:59 PM   #10
Dhillbilly1
Member#: 247404
RRE ecu - $200
RRE air box - $40
main harness from the computer to engine if no wires cut and all that tie into it for other componets! interested in the whole harness if pricing is right! Just trying to save myself from having to redo the one currently in the car someone hacked on! Can fix it but prefer one that hasnt been messed with! Also woud be interested in a distributor and possibly a block! Why is the engine dissassembled if I might ask? Thanks for getting back so quick too!
Old 05-22-2010, 10:16 PM   #11
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
main harness from the computer to engine if no wires cut and all that tie into it for other componets! interested in the whole harness if pricing is right! Just trying to save myself from having to redo the one currently in the car someone hacked on! Can fix it but prefer one that hasnt been messed with! Also would be interested in a distributor and possibly a block! Why is the engine disassembled if I might ask? Thanks for getting back so quick too!
I'll get back with you about pricing on the harness ... have to think about a price on that one lol. There was one wire that we replaced going to the starter, but other than that, it is fully intact. I am not sure if we have a distributor in our lot right now, but I can let you know for sure next weekend.
When this car got rear-ended we bought a rolling gtx shell to swap this engine and tranny into since it was just rebuilt. So this car now has the engine components that came with the rolling shell. The previous owner of that car had everything taken apart with plans of rebuilding it all, but never got to it. I do have miata pistons also, if you are interested.
Old 05-22-2010, 10:43 PM   #12
Dhillbilly1
Member#: 247404
Look I live about 4 1/2 hours from there maybe best to let you all get in there and figure what you have and who bought what and you all give me a holler when you know whos not backin out on you, tell me what you have left and if I can use any of it I show up with cash and we work it out from there. Am interested in the harness for sure! Never said what the ecu was mapped to on the boost? and do you need their box or will it run with the stock box?
Old 05-23-2010, 01:01 PM   #13
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
The ecu is mapped for 16psi at 7200rpm. It does not require to air box, so it will work with the stock one. Just the engine side of the harness will be $50. Make us an offer on the whole thing - it will require pulling the dash out and what not and I couldn't find any comparable listings to get a price range.
PM me your phone number and I'll try to give you a call friday night once I have put my hands on everything. If anyone wants to pick up any parts - we will have Saturday afternoon and Monday open for pick up.
Old 05-24-2010, 12:21 AM   #14
Dhillbilly1
Member#: 247404
As I pmd you Ill take the ecu and wiring harness at said price, will you take another 50.00 for the front bumper? It has been pointed out to me I really could use it!lol
Old 05-24-2010, 02:51 PM   #15
TransplantGuy
Member#: 247588
Default 1988 Mazda 323 GTX complete part out
I'm looking for a sunroof and hatch for a GTX. I'm in Illinois and could head to Bloomington, IN to meet you. I'd like the HKS muffler as well, if it's the one from the turbo-back ("off-road only") exhaust, rather than the cat-back set (the difference is pipe diameter, I believe).
I'd also take the fuel tank/pump setup as well.
Thanks in advance.
Scott
TransplantGuy is offline   Reply With Quote
Old 05-24-2010, 11:12 PM   #16
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
Thanks in advance.
Scott
I don't believe that HKS made a turbo back for this car. What we have is the axle back part of the cat-back HKS exhaust.
The car is sitting outside with a car cover on it. Until we are able to get it to Bloomington and part it out completely in our garage, we need it to stay water tight, so I don't feel comfortable pulling the sunroof or hatch off at the moment.
I am not sure that we will have room in the car for the gas tank/fuel pump with everything else we are pulling. We will bring it back with us if we still have room.
Old 05-24-2010, 11:26 PM   #17
TransplantGuy
Member#: 247588
Default HKS exhaust & GTX parts
HKS made a turbo-back setup for a while (shortly after the car's intro), but it was off-road only so there weren't many of them sold. No cat, but a resonator in place of the cat, and included a whole new downpipe from the turbo as well. I have the complete setup in place on one of my cars now, but could use some spare pipes, and the pipe that has the "S" in it to go up and over the back axle on my car snagged an obstruction while being driven onto a trailer.
I understand the weathertight issue and wouldn't want to leave the car open either, so if it works out that the items I mentioned earlier are available, I'd appreciate a yell.
I have three GTXs now, two in mint condition in dry storage with 14-17,000 miles on them (yes, that low), but my daily driver now has 72,000 (still low for a 22 year old car) and needs the usual maintenance & rust work.
Thanks for your reply, and good luck on your parting-out process.
Scott
Old 05-24-2010, 11:40 PM   #18
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
Well I learn something everyday It is awesome to hear of someone taking care of these cars. We were caretakers for a while, but the world was out to get us with these cars. My husband, Joe will actually be in Illinois tomorrow (Urbana) and just mentioned that he would love to see your cars if you are on his beaten path.
I will definitely contact you when we have the car here, no worries. Uhaul wants an arm and a leg to trailer it up here, so I am waiting on my dad to decide when he wants to drive to Michigan to visit family so he can trailer it up here on his car trailer.
Old 05-24-2010, 11:51 PM   #19
TransplantGuy
Member#: 247588
Yes, I really enjoy these cars, though I don't have the time to do so as much as I'd like. I'm proud of my sons for their love of cars and their ability to learn so much about them. Both have Mazdas still, with one also having two Subarus.
My "Subaru" son, who tipped me to your original post here, went to school in Urbana, but we're almost four hours north of there, in Northern IL, which probably is a bit out of the way. But we made that trip between home and U of I many times over the time he was there.
I don't know if I'd trust anyone else to trailer your car, especially U-Haul. It was their trailer that snagged the exhaust system of the GTX that I'm now looking for parts for!
If you do have time to get up here drop me a note as two of the cars are stored off-site, though I have full access 24/7. If only I had a ten-car garage, as we also have an '81 RX-7 with 17K miles on it as well.
Thanks for the note!
Old 06-08-2010, 01:32 PM   #20
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump for an updated parts list and prices
Old 06-09-2010, 05:37 PM   #21
Corinator
Member#: 211974
2004 WRX STi PTE6466
2002 Sentra SE-R Spec V
Bump for a fellow IIC member!
Corinator is offline   Reply With Quote
Old 06-12-2010, 02:54 PM   #22
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
el bumpo
Old 06-16-2010, 11:53 AM   #23
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump - get those parts out of my garage!
Old 06-20-2010, 10:38 PM   #24
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 06-26-2010, 03:00 PM   #25
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
1988 Mazda 323 GTX complete part out subygirl Non-Subaru Stuff 7 06-08-2010 01:35 PM
1988 Mazda 323 GTX forsale! *RARE* gr8wheels South West Impreza Club Forum -- SWIC 13 03-11-2004 03:18 PM
FS: 1988 Mazda 323 GTX in AZ AaronB Private Vehicle 'For Sale' Classifieds 7 03-09-2004 05:29 AM
1988 Mazda 323 GTX Turbo AWD gr8wheels Private Vehicle 'For Sale' Classifieds 34 03-09-2004 05:26 AM
