Old 05-06-2010, 01:31 PM   #1
wlit
Member#: 157385
2007 Impreza WRX
Urban Gray Metallic
Question Experience with installing brake rotors and pads for 2007 WRX?
I would like to found out if anyone has experience installing brake rotors and pads for 07 WRX (one with red 4-piston front calipers) Can you refer me with some links on how to or step by step instruction on how to get this done? My cars has about 40K miles, normal driving, recently during tire rotation, I notices the front pads doesn’t have much meat left and thinking it may be time to replace it. The rotor still in good condition but I am thinking to replace it as well with Brembo plain.
I call the nearby Subaru dealership and found that they sell the OEM front pads for $170, a bit pricy than I expected but it is a set that comes with shims & clips. With one you get in TireRack maybe not included.
Thought and Suggestion?
wlit is offline   Reply With Quote
Old 05-06-2010, 02:27 PM   #2
Daedalus
Member#: 29049
2007 WRX Wagon
Don't replace the rotors. It'll be a waste of money. Do your self a favor and get the StopTech Street Performance Pads from www.wrxbrakes.com (There is a review thread floating around here). Well that is if you just want performance street pads.
Pad install is stupid easy!
1. Jack up car and secure on jack stands
2. Remove wheel
3. Remove the two pins in the caliper housing (for the fronts you must remove that retaining spring first)
4. Remove the + shaped thingy
5. Pull out one pad
6. Use that pad and leverage the piston(s) back into the caliper housing
7. Assemble new pad with original backing and antisqueel goo
8. Insert new pad
9. Repeat 5-8 for the other pad in the caliper
10. Reassemble in reverse order
Repeat for the other 3 wheels.
Daedalus is offline   Reply With Quote
Old 05-06-2010, 02:37 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
forget the rotors
just put new pads on
takes 20 minutes
Old 05-06-2010, 03:08 PM   #4
wlit
Member#: 157385
2007 Impreza WRX
Urban Gray Metallic
I need more info from step 3-6
3. Remove the two pins in the caliper housing (for the fronts you must remove that retaining spring first) - easy to remove and put it back with a screw driver?
4. Remove the + shaped thingy (huh?)
5. Pull out one pad
6. Use that pad and leverage the piston(s) back into the caliper housing (so you pull out the old pad and stuck it back to push the piston back to the caliper WITHOUT first removing the whole caliper like transitional brake and the use of c-clamp?)
--Do I need hand brakes on or off, when I work on the front pads?
--Do I need to open the cap of brake fluids and release/loosen the brake lines attach the caliper?
Old 05-06-2010, 03:11 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Is there someone locally to you who knows brakes well that can teach you this? Perhaps in exchange for a pizza and a 6 pack?
I'm serious. Brakes are a no joke thing. Even on low horsepower cars they are a no joke thing. It is much better to have someone who knows the ropes teach you instead of risking it.
Old 05-06-2010, 11:11 PM   #6
Daedalus
Member#: 29049
2007 WRX Wagon
I used a larger needle nose plier to push them out from the back. Then grip from the front and pull. They aren't in very tight and you can probably get them in with your hands. Clean them up before re-inserting and it'll be easier.
It's funny that the rear pins have a phillips head on the front to make it easier to push/rotate in. But it's more needed on the front so you can realign the spring/clip for the front ones.
There's a cross shaped, flat metal clip that I believe is used to control the vibrations of the pads. It's held in by the pins and will probably come shooting out when you pull the last pin.
5. Pull out one pad
Use the pliers to help wiggle them out.
Pull pad out. Rotate 90 degrees, and kinda use it as a pry bar to push the piston back in. Because the red brakes aren't sliding calipers, you won't be removing them. So a C clamp won't fit. Leverage/hand pressure will be enough to compress the piston enough. Thats why you only do one at a time so that when you push one piston in, the other doesn't come out (held in by the other pad). When doing the fronts, you'll have to play with it a bit so that both pistons go in.
On if the car is jacked up only in the front and the rears are still on the ground. Chock them also. The last thing you want is your car rolling backwards and off the jackstands.
Open the cap only. Surround the opening with towels to absorb any brake fluid that bubbles over. None did when I did my pads.
All this is explained much better in the Factory Repair Manual. See if you can borrow/buy one.
Old 05-07-2010, 12:47 AM   #7
wlit
Member#: 157385
2007 Impreza WRX
Urban Gray Metallic
Thank you very much for the additional info. Here are some images I found on the web for 2008 STI. I think they are similar to 07 WRX
The pins, cross shaped, flat metal clip?
Don't see much room to fit my finger to it nor rotate it 90 degrees
Old 05-07-2010, 12:57 AM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
and if you got somebody to show you what to do.......it would be better
Old 05-07-2010, 12:58 AM   #9
brianha42
Member#: 193148
2006 WRX Wagon
not gonna leave my brakes to my novice self, getting a shop to do pads, rotors, ss lines, and tic master cylinder brace for 250.
brianha42 is offline   Reply With Quote
Old 05-07-2010, 06:52 AM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
d0000000000d....that is a waste of $250
you should post in your local area forum for somebody to help ya......beer and pizza is cheaper than $250
hell....I'd do it for ya for $100....and the only reason I'd charge at all is 'cuz I'm broke
Old 05-07-2010, 08:15 AM   #11
Web Foot STi
Member#: 39086
2004 STi
Brake pads are so easy it's one of the few jobs I still do my self. Just dive in.
Web Foot STi is offline   Reply With Quote
Old 05-07-2010, 10:36 AM   #12
wlit
Member#: 157385
2007 Impreza WRX
Urban Gray Metallic
Uncle Scotty you are big help, images more than a thousand words. Brakes are very critical parts of any vehicle and I do hear many people said it is very easy things to do. I do not have any experience with installing pads, that worry me the most but at the same time I really want to do it myself since I have interest to work on cars (I am sure we all are if you are driving a Subaru and posting in NASIOC =) and learn from it and help friends and families out when needs.
So we have a 16 inch type huh? What is 16 inch stand for, the rotor size?
The instruction show how to remove the existing pad but it did not mention how to put it back on, so I assume it is in reverse order. But what about pushing the piston back into the caliper (by finger, screw driver, or the old pads) any brake pressure I need to adjust to ensure it working correctly? Thank you!
Old 05-07-2010, 11:19 AM   #13
Web Foot STi
Member#: 39086
2004 STi
Yep, just use the old pads to push to pistons back in. Then slide in the new pads. It really is that easy.
16" is wheel size, not manhood...
Old 12-30-2010, 12:31 AM   #14
journey
Member#: 74555
2006 WRX Wagon-Stg 3
San Remo Red
For anyone following the above directions, I wanted to note that the 2006/2007 WRX (i.e., non-STI) with the red calipers will follow the directions for the "16 INCH TYPE" even though stock wheels are 17 inch -- there is an M-clip that keeps the "pad pins" in place, and one end of the "cross springs" has a bend/ curve in it. If anyone is interested, I took a pix of it when replacing my front brake pads tonight.
journey is offline   Reply With Quote
Old 12-31-2010, 09:45 AM   #15
dnorton
Member#: 218997
07 WRX Mikey Tuned
JE/FSR built,35r 1300c
I hate to be the only guy here that has anything to say about the rotors. My 07 when I did my brake job instead of putting new pads on old rotors I switched the Rotors also and added SS brake lines. It was easy to do just did a lot of research before I started. My Rotors might have been ok to turn down and use again but myself I wouldn't put new pads on used Rotors that haven't been at lease turned. Just my 2 cents not trying to piss anyone off just thought I'd share my feelings on brakes.
dnorton is offline   Reply With Quote
New Brake lines and Pads for 2010 WRX? Rfish117 Brakes, Steering & Suspension 9 03-16-2010 07:21 PM
WTB: new slotted brake rotors and pads for 06 sti orpyak Private 'Wanted' Classifieds 0 08-15-2009 05:32 PM
WTB: Rotors and pads for 05 WRX skydes SCIC Private Classifieds 0 12-17-2007 08:29 PM
Brakes, rotors and pads for sale. CT. Chuck Annicelli NESIC Private Classifieds 10 01-26-2006 02:13 AM
just installed new rotors and pads. now parking brake needs adjustment? Wagon Joe Brakes, Steering & Suspension 8 04-19-2005 01:31 PM
Message Board Statistics All times are GMT -4. The time now is 05:53 AM.
