Old 05-06-2010, 02:14 PM   #1
SVT_WRX
Member#: 164830
G61 III OVE 58e
Default +++SVT_WRX TUNED:356 WHP 348 WTQ Airboy
Event: DYNO PULL
Ambient Temp: 90*F
Elevation: 435 feet above sea level
Weather: SUNNY
Car: 2002 WRX
Tuner: PHATRON AND MYSELF
Dyno Info: MUSTANG DYNO
Transmission: STOCK 5 SPD
Gear: 4TH
Peak HP at RPM: 312---308 .99 CF
Peak Torque at RPM: 329---323 .99 CF
Baseline hp/tq for a stock STI on same dyno: 220-225 STI 2.5L
Target Boost: 25
Target AFR: 12:1 TAIL PIPE READINGS 11:3 DOWNPIPE READINGS
Fuel: E85
Engine/Power Modifications: (EVERYTHING HAS BEEN INSTALLED BY ME AND ME ONLY! I DO ALL MY OWN WORK) STOCK BLOCK 130,000 MILES, EVO III 16G, HALLMAN MBC, KSTECH 83 MM CAI INTAKE, SPT INTAKE HEAT SHIELD, 3" TBE, MODDED STOCK INJECTORS, WALBRO 255, AGENCY POWER UP-PIPE, GRIMMSPEED CROSSPIPE, PERRIN TURBO INLET, CX RACING INTERCOOLER, INTERCOOLER WATERSPRAYER, FORGE BPV, INTERNAL WG, NGK IRIDIUMS (1 STEP COLDER), OS TUNED, AUTOMETER BOOST GUAGE, INNOVATE LC-1 WIDEBAND, GOLAN ALCOHOL COMPLIANT FUEL FILTER
Driveline Modifications: REBUILT 5 SPD FROM ANDREWTECH 06/07 GEARS, ACT XTSS CLUTCH KIT W/ HD PRESSURE PLATE (508 LBTQ) 225-45-17 FALKEN RT-615.
Suspension Modifications: GF210 SPRINGS, TOKICO D-SPEC ADJUSTABLE STRUTS, STI TRANNY MOUNT,STI PITCH STOP, H-BRACE, MRT MASTER CYLINDER BRACE
Other Modifications: FULL WEIGHT
WIDE A** DYNO!
Code:
Time    LOAD    RPM    IDC    IAT    MRP    MAFV    TOA    LC-1
0    1.13    2717    14.49    70    0.52    2.34    100    13.51
212    1.21    2732    15.15    70    1.37    2.4    100    16.51
415    1.26    2683    16.03    70    2.15    2.42    100    14.54
623    1.33    2702    17.31    70    2.94    2.46    100    14.07
837    1.42    2840    18.17    70    3.85    2.56    100    13.1
1044    1.49    2873    19.61    70    4.89    2.62    100    13.08
1251    1.57    2917    20.53    70    5.94    2.7    100    13.16
1455    1.64    3014    23.15    70    7.06    2.72    100    13.16
1667    1.74    3085    25    70    8.31    2.86    100    13.42
1871    1.87    3140    28.56    70    4.97    2.88    100    12.79
2082    2.08    3254    33.32    70    11.8    3.08    100    12.72
2287    2.32    3352    38.62    70    14.48    3.12    100    12.07
2487    2.69    3472    45.92    68    17.73    3.36    100    11.73
2689    3.09    3592    55.17    68    21.27    3.54    100    11.58
2889    3.39    3738    64.6    68    24.11    3.68    100    11.6
3089    3.32    3866    64.33    68    24.17    3.68    100    11.57
3293    3.26    4080    67.02    68    24.13    3.7    100    11.6
3489    3.24    4173    68.55    68    24.13    3.72    100    11.63
3694    3.23    4302    71.59    68    24.09    3.78    100    11.76
3896    3.23    4491    75.54    68    24.17    3.82    100    11.76
4103    3.21    4635    77.48    68    24.07    3.86    100    11.48
4309    3.2    4817    79.12    68    24.04    3.88    100    11.51
4515    3.17    4963    81.53    68    23.82    3.9    100    11.35
4716    3.15    5060    83.13    68    23.47    3.94    100    11.36
4922    3.13    5226    84.73    68    23.26    3.98    100    11.36
5119    3.11    5334    86.48    66    23.09    4    100    11.58
5320    3.08    5478    87.65    66    22.95    4.02    100    11.44
5525    3.03    5635    87.75    66    22.89    4.02    100    11.58
5727    2.97    5703    87.6    66    22.8    4.04    100    11.54
5927    2.92    5832    88.34    66    22.76    4.02    100    11.39
6132    2.85    6000    89.6    66    22.55    4.04    100    11.55
6337    2.81    6073    88.1    66    22.55    4.02    100    11.44
6536    2.77    6178    89.61    66    22.51    4.04    100    11.42
6741    2.72    6313    89.8    66    22.53    4.04    100    11.39
6939    2.68    6432    89.19    66    22.59    4.06    100    11.35
7143    2.65    6504    90.04    66    22.72    4.04    100    11.38
7339    2.62    6556    89.51    66    22.62    4.04    100    11.1
7547    2.26    6678    34.19    66    20.32    4.06    71.37    11.32
Last edited by SVT_WRX; 01-14-2012 at 08:00 PM. Reason: CORRECTION FACTOR WAS INCORRECT
SVT_WRX is offline   Reply With Quote
Old 05-06-2010, 02:36 PM   #2
SVT_WRX
Member#: 164830
G61 III OVE 58e
369 WHP 387 WTQ estimated numbers on a Dynojet, same conditions.
Old 05-06-2010, 02:37 PM   #3
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Looks like a good tune, nice graph! I would think a 16G+E85+25psi would equal more than 73hp more than a stock STI. Are you sure a stock STI dynos 235 on that mustang? Did you do a compression test prior to tune/installing parts?
Steve.804 is offline   Reply With Quote
Old 05-06-2010, 02:38 PM   #4
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Ahhh now that's more like it. No way a stock STI is putting down 235 on that dyno.
Old 05-06-2010, 02:41 PM   #5
SVT_WRX
Member#: 164830
G61 III OVE 58e
No compression test done prior. I'm sure the motors tired though.
Old 05-06-2010, 04:45 PM   #6
SVT_WRX
Member#: 164830
G61 III OVE 58e
Sorry, that was a typo. Stock STI 220-225 HP on this dyno.
Old 05-06-2010, 04:51 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Glad everything went well.
You should post up an airboy plot as well....or i can when i get home.
Be nice to see mustang v airboy comparison.
Old 05-06-2010, 06:03 PM   #8
SVT_WRX
Member#: 164830
G61 III OVE 58e
Old 05-06-2010, 06:07 PM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
here you go.....u can delete yours
Code:
Old 05-06-2010, 06:08 PM   #10
SVT_WRX
Member#: 164830
G61 III OVE 58e
^^^^ 3rd gear, 300 delta, 66*, 225/45/17. That dyno was sure putting a load on my car. I had to richen it up to make more power. On the street, it feels much faster now.
Old 05-06-2010, 06:10 PM   #11
SVT_WRX
Member#: 164830
G61 III OVE 58e
Thanks Ron. She feels much faster now. Time to head to Fontana to see what she will do on the 1320.
Old 05-06-2010, 06:22 PM   #12
knuts
Member#: 116814
2003 wrx wagon
blue
I think the dyno CF you have listed is a typo. 1.02 would make more sense for your altitude...
knuts is offline   Reply With Quote
Old 05-06-2010, 06:28 PM   #13
SVT_WRX
Member#: 164830
G61 III OVE 58e
That's not a typo. CF was 1.2.
Old 05-06-2010, 06:32 PM   #14
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
In for airboy results....looks really responsive!
zeropsi is offline   Reply With Quote
Old 05-06-2010, 07:05 PM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
I cant post pics here, but i just did an airboy of the log above on a smoothing of 5 and it shows. i had 485 ft, 66*, and 10% humidity (lol a little low i guess)
309 whp
323 tq
Old 05-06-2010, 07:10 PM   #16
SVT_WRX
Member#: 164830
G61 III OVE 58e
I got exactly 308/323. The airboy run was done with the following:
Temp 66*, HUM. 70% ELV. 500 ft.
Regardless, Airboy is pretty damn close if not dead on with a Mustang dyno.
Old 05-06-2010, 07:17 PM   #17
zeropsi
Member#: 175453
AE86 GT-S coupe
Damn, some days airboy is a dead lock with a Mustang dyno.
Old 05-08-2010, 11:36 AM   #18
SVT_WRX
Member#: 164830
G61 III OVE 58e
The proof is in the pudding. When an Airboy is done right, numbers are identical on a Mustang dyno...assuming the dyno is calibrated correctly. The guy operating the dyno was pretty impressed. He said all out stage 2 (pump gas) STI's don't put out this much power/torque on this dyno.
Old 05-08-2010, 11:53 AM   #19
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
PLEASE Add the Airboy plot to the first post. Why r u using such a big intake?
Congrats
Old 05-08-2010, 11:59 AM   #20
SVT_WRX
Member#: 164830
G61 III OVE 58e
^^^ Since you asked oh so nicely...
Why not use a big intake? Do you think I'll make more power with my APS 65MM CAI?
Old 05-08-2010, 12:28 PM   #21
Gilmore25
Member#: 58985
Did you Dyno in 4th gear? Doesn't 4th go to 140mph?
Nice results for a 2.0
Gilmore25 is offline   Reply With Quote
Old 05-08-2010, 12:34 PM   #22
juanmedina
Member#: 133146
Sorry I forgot to add PLEASE , no harm intended, just asking questions
GL
Old 05-08-2010, 12:44 PM   #23
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
GL
hater
Car looks good
BUILTSTI is offline   Reply With Quote
Old 05-08-2010, 12:46 PM   #24
SVT_WRX
Member#: 164830
G61 III OVE 58e
Thanks. I've seen a few, but not many unmolested 2.0's (USDM) put down this much power.....on a Mustang dyno. Well, in this forum anyway. I'd say Ron and myself didn't do too bad.
I just discovered yesterday that the stock BPV is opening at 22-23 PSI now whereas before it was cracking open at 25 psi. It's tired. Time for a Turbosmart Dual BPV!
Road dyno: 3rd gear
Mustang dyno: 4th gear
Old 05-08-2010, 12:47 PM   #25
SVT_WRX
Member#: 164830
G61 III OVE 58e
Originally Posted by BUILTSTI View Post
hater
Car looks good
Thanks Chief.
Sreet Tune, Dyno Results: JDM STi EJ207 Blouch Dom3, dyno video too DuCash Proven Power Bragging 46 11-01-2009 11:25 AM
ECS Tuned 04 WRX Stage 2 - 234whp 244wtq Mustang Dyno BONFIRE074 Proven Power Bragging 26 08-08-2009 08:46 AM
06 Wrx VF39 - Mustang Dyno - 555 Motorsports Tuned Mooneyes13 Proven Power Bragging 54 04-11-2009 10:24 AM
Latest dyno results: 145hp, 144ft-lb on Mustang dyno Patrick Olsen Normally Aspirated Powertrain 39 08-27-2008 03:19 AM
Dyno Results: EJ207 TD05-18g/ecutek tuned by Xotic *Video/Pics gregfeder Proven Power Bragging 20 11-19-2005 03:29 PM
