Old 05-06-2010, 10:39 PM   #1
RawrlySnarly
Member#: 229562
1995 Civic (Daily)
Default 06 STI, KW Variant 3. I need to complete these. Help please.
About a year or so ago I got a really good deal on KW Variant 3's for a friend. We picked them up and installed them using the Stock Top Hats since they requested that. Now they've decided they want more control over the setup which means some Top Hats. Now my questions are:
-Which Top Hats would you recommend? I've heard good things about Group-N but I'd like more options.
-Another friend has BC Coilovers on his 08 STI and it comes with the Knob to adjust the stiffness, where can we pick that up for the KW's? Is this possible?
-If so, where can you find the extended ones to go through the Rear Deck in the car making it easier to tighten the suspension without removing everything?
Thanks!
RawrlySnarly is offline   Reply With Quote
Old 05-06-2010, 11:06 PM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
GTWorx has some top hats...
There is no adjustable knob for the KWs... you have to use a hex tool
There is no extended knob for the KW's either.... Look for a hex tool at your local hardware store with an extended t-shaped handle on it.
jigga is offline   Reply With Quote
Old 05-06-2010, 11:30 PM   #3
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
are you looking for camber adjustment with added caster? If so, look into the GTWORX camber plates. they have .8" of caster built in, and great build quality with the support from RCE/GTWORX. Cant say enough good things about these guys
here is a thread on IWSTI from a guy that made some adjusters for his T2's. I just ordered some myself as i just received my T2's
http://www.iwsti.com/forums/gd-suspe...-rear-t2s.html
hope that helps
Boxer4u is offline   Reply With Quote
Old 05-06-2010, 11:42 PM   #4
RawrlySnarly
Member#: 229562
1995 Civic (Daily)
Thanks for all the help so far! Would anyone know off hand if the KW's click when loosening/tightening the stiffness like BC's do? Those adjusters look great, I'll probably attempt something like that for my friend since I'm slightly more handy and have a lot more free time, haha. Thanks again.
Old 05-07-2010, 07:19 AM   #5
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Ground Control's front plates are the best ones available for the car, IMHO.
http://forums.nasioc.com/forums/show...highlight=60mm
Adding lots of travel and tons of adjustment... and if you dig the aesthetic thing, this means you can lower the car more without compromising bump travel as much.
Old 05-07-2010, 07:48 AM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I have Vorshlag front camber plates, and the "modified" Group-N rear tops with my V3's. I like the Vorshlags because of the built in bearing. For the rearm the Group-N's are really all you need IMO.
I have a set of these I can sell you:
Old 05-07-2010, 03:51 PM   #7
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
As stated if you need camber adjustment then get some vorshlag camber plates or something similar.
If not, Group-N mounts or Whiteline Com-C's will work great too.
Feel free to PM us for info or if you'd like a set
Circuit Motorsports is offline   Reply With Quote
Old 05-07-2010, 04:51 PM   #8
dunk
Member#: 15359
Agreed. I think the Ground Control design is superior to any of the other camber plates due to the extra travel.
dunk is offline   Reply With Quote
FS/TX: 06 STi BBS wheels and tires-- NEED TO SELL ASAP Manoxide069 Wheels/Tires 12 07-20-2009 12:33 AM
2008 STI KW Variant 3 South Coast Subaru Suspension/Brakes/Handling 4 06-09-2008 01:53 PM
need to replace fenders help please XtremeRallyTuning Interior & Exterior Modification 1 12-12-2007 07:32 PM
WTS KW Variant 3 Coilovers For 05-07 STI [email protected] Suspension/Brakes/Handling 14 08-03-2007 08:03 PM
KW Variant 3 Coilovers 02-07 WRX 04 STI Paintballguy Suspension/Brakes/Handling 0 07-05-2007 09:20 PM
