Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 05-07-2010, 03:12 PM   #1
RavSpec
NASIOC Storefront Vendor
Vendor Sales Rating: (88)
Member#: 26854
2002 Impreza
WRX
Default DBA Rotors + Ferodo Pads Combo / BC Racing Coil Over / Zeal Coil Over Kit
DBA Rotors / Hawks Pads / Ferodo Pads
First, I would like to introduce the DBA Rotors. These are awesome rotors from down under (Australia), three option to choose from standard, 4000 and 5000. Standard are for street, they're better than OE due to the "kangaroo paw" which increases cooling up to 20%. 4000 & 5000 is for street/track with thermal-graphic in addition to the "kangaroo paw" and the 5000 is the ultimate 2pc rotor with aluminum hat for added heat protection to your wheel bearing.
Street Series
Ideal for towing and heavy loads, where additional heat is usually generated.
The slotting efficiently clears dust and debris, while creating better friction and a cleaner disc rotor.
4000 Series
DBA’s mid-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.The unique 6x6 Wiper Slot is designed to efficiently clear dust and debris while maintaining consistent friction and a cleaner disc surface.4000 series rotors also incorporate the innovative Kangaroo Paw ventilation design, which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%
Designed for the performance street and motorsport enthusiast.
5000 Series
DBA’s high-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling, Thermo-Graphic paint markings for effective heat monitoring and Kangaroo Paw ventilation which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%
The 5000 series rotors are designed for the serious driver. These 2-piece ultra-high performance rotors feature aerospace grade materials for added thermal (heat) protection to you vehicle's wheel bearings.
The aircraft-grade aluminium centre/hat provides greater resistance to distorion as it allows the disc to expand uniformly.
WRX Front (02-05) - 2/4 Pot Front
-Standard Rotors
- Slotted (650SL/SR) - $240 pair shipped
- Cross Drilled & Slotted (650X) - $260 pair shipped
-4000 Series
- Slotted (4650SL/SR) - $280 pair shipped
- Cross Drilled & Slotted (4650SR) - $320 pair shipped
-5000 Series
Black / Gold
- Slotted (5000SL/SR) - $700 pair shipped
- Cross Drilled & Slotted (5000XS) - $760 pair shipped
WRX Rear (02-05)
-Standard Rotors
- Slotted (644SL) - $200 pair shipped
- Cross Drilled & Slotted (644X) - $200 pair shipped
-4000 Series
- Slotted (4644SL/SR) - $245 pair shipped
- Cross Drilled & Slotted (4644XS) - $270 pair shipped
2004 STI (5x100) - Front
-Standard Rotors
- Slotted (646SL/SR) - $295 pair shipped
- Cross Drilled & Slotted (654X) - $320 pair shipped
-4000 Series
- Slotted (4654SL/SR) - $350 pair shipped
- Cross Drilled & Slotted (4654XS) - $3805pair shipped
-5000 Series
Black / Gold
- Slotted (5654SL/SR) - $797 pair shipped
- Cross Drilled & Slotted (5654XS) - $824 pair shipped
2004 STI (5x100) - Rear
-Standard Rotors
- Slotted (655SL/SR) - $255 pair shipped
- Cross Drilled & Slotted (655X) - $275 pair shipped
-4000 Series
- Slotted (4655SL/SR) - $305 pair shipped
- Cross Drilled & Slotted (4655XS) - $340 pair shipped
2005 STI (5x114.3) - Front
-Standard Rotors
- Slotted (2654SL/SR) - $295 pair shipped
- Cross Drilled & Slotted (2654X) - $318 pair shipped
-4000 Series
- Slotted (42654SL/SR) - $348 pair shipped
- Cross Drilled & Slotted (42654XS) - $372 pair shipped
-5000 Series
Black / Gold
- Slotted (52654SL/SR) - $797 pair shipped
- Cross Drilled & Slotted (52654XS) - $824 pair shipped
2005 STI (5x114.3) - Rear
-Standard Rotors
- Slotted (2655SL/SR) - $251 pair shipped
- Cross Drilled & Slotted (2655X) - $348 pair shipped
-4000 Series
- Slotted (42655SL/SR) - $305 pair shipped
- Cross Drilled & Slotted (42655XS) - $342 pair shipped
2008 + WRX - Front
-Standard Rotors
- Slotted (650SL/SR) - $241 pair shipped
- Cross Drilled & Slotted (650X) - $264 pair shipped
-4000 Series
- Slotted (4650SL/SR) - $284 pair shipped
- Cross Drilled & Slotted (4650XS) - $324 pair shipped
-5000 Series
Black / Gold
- Slotted (5010SL/SR) - $711 pair shipped
- Cross Drilled & Slotted (5010XS) - $765 pair shipped
2008+ STi - Front
-Standard Rotors
-4000 Series
-5000 Series
Black / Gold
Performance Ceramic for Luxury and Touring (PC) - Specially formulated ceramic composite developed to meet the ultra-low dust, low noise performance of OE ceramic brake pads. Performance Ceramic pads also feature a fade resistant, linear friction profile that produces improved braking over OE with smooth engagement characteristics. Performance Ceramic – quiet, clean & fast-stopping. Recommended for import & domestic automobiles, luxury SUV’s, sport trucks & vans.
High Performance Street Compound (HPS) - When it comes to performance braking, there is no competition. This unique Ferro-Carbon compound combines the safety and quality of Aerospace design partnered with the braking technology of motorsports. Much improved braking over OE and standard replacement brake pads. Recommended for import & domestic automobiles.
Autocross & Track Compound (HP+) - The HP Plus Ferro-Carbon material can take the heat at the track and get you home safely without having to change your brake pads. This compound was designed for autocross, Solo II, and Track Day applications.
Warning! Due to the dramatic friction levels produced by this product to achieve race level braking; rotor wear, noise, dust and pad life may be affected.
02-02 WRX
Front
Performance Ceramic - $89
High Performance Street - $88
HP + - $116
Rear
Performance Ceramic - $80
High Performance Street - $73
HP + - $100
03-03 WRX
Front
High Performance Street - $83
HP + - $110
Rear
HP + - $100
04-05 WRX
Front
HP + - $110
Rear
Performance Ceramic - $79
High Performance Street - $75
HP + - $104
06-07 WRX
Front
Performance Ceramic - $84
High Performance Street - $84
HP + - $110
Rear
Performance Ceramic - $75
HP + - $97
08-09 WRX
Front
HP + - $110
Rear
Performance Ceramic - $81
High Performance Street - $79
HP + - $106
04-09 STi
Front
Performance Ceramic - $121
High Performance Street - $118
HP + - $137
Rear
High Performance Street - $76
HP + - $98
FREE SHIPPING WHEN PURCHASING FRONT & REAR PADS AT THE SAME TIME!!!
PM/AIM/Call us for a package price, or BEST PRICING!!!
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ KW ] [ DBA ROTORS ] and many more!
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 05-07-2010, 03:12 PM   #2
RavSpec
Member#: 26854
2002 Impreza
WRX
FERODO Brake Pads Available Here !!
DS2500 - (Street /Club Sport /Autocross)
- STI (Brembo Caliper) - $219 Shipped Front / $115 Shipped Rear
- WRX (4 Pot) Front - $199 Shipped ** stock 06-07 WRX
- WRX (2 Pot) Front - $139 Shipped
- WRX (1 Pot) Rear - $159 Shipped
(Ferodo compound code H)
The DS2500 is currently the best hybrid track/street pad on the market. It features the moderately high bite and solid fade resistance of a track pad, with the relatively low dust and noise levels of a street pad. When used as a street pad, it can produce some squeal on certain vehicle platforms. During aggressive driving the DS2500 is known for its flat torque curve, which means as temperatures go up, the response through the brake pedal remains consistent. If you drive aggressively on the street, do some canyon runs, autoX, and maybe some light track duty on street tires, the DS2500 is tough to beat.
When used on fast, heavy cars on the track with race tires, pad wear rates tend to be higher than some of the full track pad compounds. Under those conditions, we would recommend the Ferodo DS3000 or DS1.11.
DS3000 - (Semi Metalic / Track)
- STI (Brembo Caliper) - $329 Shipped Front / $179 Shipped Rear
(Ferodo compound code R)
DS3000 is one of the most decorated race pads in the global motorsports market, having won in diverse venues from rally to open wheel cars. The DS3000 has high bite and good fade resistance. It has a slightly rising torque curve, which means that as temperatures go up, bite increases slightly. Although the bite of the DS3000 is slightly higher than the DS1.11, wear rates are also higher. If you are doing extended lapping (30 minute+ sessions) or endurance racing, and are concerned about pad wear rates, the DS1.11 is probably the better choice for you.
DS1.11 (Semi Metallic / Endurance Race)
- Ask for Pricing and ETA !!
(Ferodo compound code W)
The DS1.11 is one of Ferodo's latest race pad offerings. It has slightly less bite at high temps. vs the DS3000, but doesn't decompose nearly as quickly under extended heavy use on the track. The DS1.11 is known for its extremely flat torque curve, which means that as temperatures go up, the response through the brake pedal remains consistent. If you want a pad that you can thrash all day without having it burn up or fade, the DS1.11 is a great choice.
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 05-07-2010, 03:12 PM   #3
RavSpec
Member#: 26854
2002 Impreza
WRX
BC Racing Coilover BR model
BC Racing Coilover BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
* Mono-tube shock design
* 30 levels of damping force adjustment
* Pillowball mounts and adjustable camber plates included*
* Adjustable rear camber plates available
* Separate Full length height adjustable
* Inverted and Non-Inverted setups
* One year warranty
* Rebuildable *Fronts, where applicable
Available for:
93-01 Impreza (GC)
02-07 WRX / STI
08-10 WRX / STI
11~12 WRX / STI
05~09 Legacy GT
10~12 Legacy GT
$1000 Shipped
$1199 Install
Add Swift Assist Spring - $250 USD
Technical
* Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
* Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
* Patented concave lower locking ring, to prevent unseating
* Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
* T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
* Iron lower brackets on MacPherson struts to ensure rigidity
* Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
* High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
* 2 step coating process utilizing nickel and chromium plating to prevent corrosion
* Newly developed lubricant oil in all shock cartridges minimizes aeration and cavitation.
* An additional bearing beneath each pillowball mount provides a smooth action and prolongs the life of the pillowball itself.
* Each BC damper is individually dyno tested before leaving the factory, making sure each damper is matched to within 5%, ensuring an equal balance in handling. OEM standards are 13% in comparison.
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 05-07-2010, 03:15 PM   #4
RavSpec
Member#: 26854
2002 Impreza
WRX
Hey All:
Introducing the Endless Zeal Coil Over System. These are pricy but are one of the best coil over system that you can possibly purchase. Custom spring rate are available. Please ask when purchase.
Function Xs - 6 ways adjustable - $2350 Shipped
Function X - 30 ways adjustable - $2750 Shipped
$55 For Rear Extension Kit
For the next generation hard user, we’ve developed the Function-X Series. The Function-X is now born and is currently the most popular race application amongst the ZEAL line-up. With advanced damping capabilities in effect, our efforts have recently focused towards our new X-Coil Hyper Spring. Through consistent and progressive research and experience, we’ve improved spring quality to achieve an even smoother and more responsive feel and ride. The ability to grasp precise road data has improved. The X-Coil spring achieves exactly this. Our Dynamometer Data proves this with stable rebound and compression levels (within a 0.1 Meter Per Second range) for level travel at very low speeds, very high speeds, and everything in between. By keeping very detailed, precision spring motion in mind, we are able to set the shock’s piston valving to superior levels. The combination of the shock and spring is superior. Our Linear Spring Motion with no Friction Loss is superior and the shock can be adjusted very precisely (Function-X includes 30-Way Damping Adjustability), thus the setting levels have broadened and can be fine-tuned with advanced precision and feel. Lightweight aluminum upper mounts, spring seat preload and spring seat locks, height-adjustable lower brackets and lock seats (for non-strut type applications) include a durable, Alumite finish for rust proof characteristics. Steel shell casing includes a special chromate plating for rust proof characteristics also. Adjustable brackets are newly designed and slender. Driving feel is amazing for the hard-user. MacPherson Strut-Type systems are specifically produced as an inverted-monotube type.
Zeal Function A Coil Over System
The typically delicate aluminum body has instead achieved high rigidity due to the Function-A’s nickel boron plating, increasing resistance to abrasion and high temperatures. The low frictional properties of boron also allow a more direct damping action. Optional X-Coil-R springs utilize the newfound performance of the super light weight Function-A. Both 6 and 30 levels of damping adjustment are available. Custom spring rates are available for your own custom Function coilovers.
*Coilover overhaul performed in-house at our facilities in California.
6 ways - $2980 Shipped
30 ways - $3399 Shipped
Note: Add $400 for aluminum upper pillow ball mounts
Note: Add $200 for X Coil R spec lightweight spring
The Function-T completely eliminates the usage of hexavalent chrome with the shell casing now being produced with a nickel boron plating. Different from existing chrome plating products, it is much more anti-corrosive and practically eliminates the spring seat seizing to the adjustable brackets. Optional X-Coils-R springs utilize the new found performance of the Function-T. Both 6 and 30 levels of adjustment are available. Custom spring rates are available for your own custom Function coilovers.
Endless / Zeal Super Function Series / Aluminum Shock Body
The Super Function series is a popular track-spec coilover kit designed for use with S-Tire compounds. The series consists of five types: A, B, C, D, E. Depending on the vehicle and type of driving, a user can choose from five different types of Super Function coilovers to best suit their needs. The upper mount is a pillow-ball type and the damper case is made of lightweight heat-resistant aluminum. Experience direct suspension feel and less unsprung weight. Recommended for track only applications.
Type-A: 6 levels of damping adjustment
Type-B: 30 levels of damping adjustment
Type-C: 6 levels of compression, 6 levels of rebound adjustment
Type-D: 6 levels of compression, 30 levels of rebound adjustment
Type-E: 30 levels of compression, 30 levels of rebound adjustment
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 05-15-2010, 02:08 AM   #5
RavSpec
Member#: 26854
2002 Impreza
WRX
weekend bump
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 05-19-2010, 10:29 PM   #6
RavSpec
Member#: 26854
2002 Impreza
WRX
mid week bump !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 05-22-2010, 12:05 PM   #7
RavSpec
Member#: 26854
2002 Impreza
WRX
BC Racing Coil OVer Kit w/ Swift Assist Spring
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 05-28-2010, 11:01 PM   #8
RavSpec
Member#: 26854
2002 Impreza
WRX
weekend bump!
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 06-08-2010, 10:56 PM   #9
RavSpec
Member#: 26854
2002 Impreza
WRX
quick bump
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 06-30-2010, 09:39 PM   #10
RavSpec
Member#: 26854
2002 Impreza
WRX
quick bump !!!
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 07-05-2010, 05:18 PM   #11
RavSpec
Member#: 26854
2002 Impreza
WRX
weekend bump !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 10-08-2010, 06:18 PM   #12
RavSpec
Member#: 26854
2002 Impreza
WRX
weekend bump
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 10-21-2010, 10:23 AM   #13
RavSpec
Member#: 26854
2002 Impreza
WRX
Quick bump
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 10-27-2010, 11:42 PM   #14
RavSpec
Member#: 26854
2002 Impreza
WRX
Ferodo Pads In Stock !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 11-04-2010, 01:52 AM   #15
RavSpec
Member#: 26854
2002 Impreza
WRX
Hawks and Ferodo pads in stock !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 11-06-2010, 12:19 AM   #16
RavSpec
Member#: 26854
2002 Impreza
WRX
Quick bump !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 11-20-2010, 03:03 AM   #17
RavSpec
Member#: 26854
2002 Impreza
WRX
weekend bump
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 11-24-2010, 03:25 PM   #18
RavSpec
Member#: 26854
2002 Impreza
WRX
quick bump !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 12-02-2010, 02:05 AM   #19
RavSpec
Member#: 26854
2002 Impreza
WRX
mid week bump :0
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 01-04-2011, 01:07 AM   #20
RavSpec
Member#: 26854
2002 Impreza
WRX
New Year 2011 / Bump ...
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 01-08-2011, 02:01 AM   #21
RavSpec
Member#: 26854
2002 Impreza
WRX
Weekend Bump !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 01-11-2011, 12:31 AM   #22
RavSpec
Member#: 26854
2002 Impreza
WRX
quick bump
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 01-13-2011, 11:05 PM   #23
BoostbyU06
Member Sales Rating: (5)
Member#: 156340
2007 STI
DBA 4000 cross drilled slotted and hawk ceramics front and rear for 2007 sti to 98422?
BoostbyU06 is offline
Old 01-14-2011, 01:25 AM   #24
RavSpec
Member#: 26854
2002 Impreza
WRX
$950 shipped with Technafit brake lines.
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 01-20-2011, 02:11 AM   #25
RavSpec
Member#: 26854
2002 Impreza
WRX
quick bump !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Closed Thread
DBA Rotors, Hawk Pads, Goodridge Brake Lines, and Motul Fluids. Let's make a combo WeSellCarParts Vendor 'General Sale' Forum 1 10-24-2009 04:58 PM
FS OH: Back up for sale - Prodrive Alcon front calipers, 2 piece rotors, Ferodo pads tundra Suspension/Brakes/Handling 16 08-26-2009 05:59 AM
DBA Rotors / Ferodo Pads / Technafit Lines Package Deal RavSpec Suspension/Brakes/Handling 126 11-07-2008 06:11 PM
