Old 05-07-2010, 04:07 PM   #1
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Default Oxygen sensor for JDM STI V5 application
I think it's time to replace the oxygen sensor for my JDM Sti V conversion done by Rallispec. I replaced the MAF sensor a couple times and it fixed the intermittent rhythmic idle and cutting out when boost started to climb but now it appeared again where it hunts up and down at idle and then when it warms up it goes away. No other symptoms.
I did a search just now on the forums and came up with part Bosch A24-A71 028 92010 that I found in here http://forums.nasioc.com/forums/show...nsor+jdm+sti+V
Any one have any ideas of where I can order this sensor I did a google search and not too much came up specific on buying a part.
How is the part number laid out ... is the whole number an actual part or the 92010 is just a serial number ?
Please any compatible parts or leads to this part would be great so I can get one on order and installed.
Best Regards,
Jason
jkjersey is offline   Reply With Quote
Old 05-09-2010, 01:35 PM   #2
Wannabe WRX
Member#: 130623
1998 Legacy L
Green
If your sensor is 3-wire, then you can use the o2 sensor from the 98RS.
If your sensor is 4-wire, use the one for the 2002 WRX.
Wannabe WRX is online now   Reply With Quote
FS -- (SoCal) Front Oxygen Sensor for STi singlefin Engine/Power/Exhaust 1 04-19-2010 03:33 AM
WTB: Front o2 oxygen sensor for 2004 sti kevinh211 Private 'Wanted' Classifieds 2 11-18-2009 10:12 PM
Alternator for a jdm sti v5 motor in a 98 rs? 2-7offsuit Subaru Conversions 13 12-17-2005 11:59 AM
Rear Oxygen Sensor for Link? cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 15 04-11-2003 09:49 AM
oxygen sensor for o2 gauge. veedubaholicvr6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2002 10:20 PM
