Old 05-08-2010, 01:55 AM   #1
SubaruWrxNewb
Member#: 236017
Default EVOIII 16G Questions.
Just got Stage 2. Absolutely love it. Now I am planning on my next upgrade, which will be an EVOIII 16G turbo swap. I have a couple questions because I have heard different things.
By the way, I have a 2005 WRX.
1. Which intercooler will work best? TMIC or FMIC? And which brand?
2. Which fuel pump should I be getting? My friend has a Walboro 255 but the constant whining sound I hear while riding is very irritating. Any other fuel pumps I can look into getting? Will I need a fuel pump regulator?
3. I plan on getting 650cc injectors. Will these be fine or should I go bigger?
Thats all I have for now. If I have anymore I will just post them as I go.
Thanks for any help!
-Ricky
SubaruWrxNewb is offline   Reply With Quote
Old 05-08-2010, 01:58 AM   #2
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
I've got a Walbro and don't have any whining, nor have I ever heard of them having a whining problem.
575rider is offline   Reply With Quote
Old 05-08-2010, 02:00 AM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
1. FMIC if you don't got money, if you do get the Spearco TMIC
2. Walbro 255, yeah it's annoying, but it's pretty much the only one, I know there is a supra fuel pump or something like that, but I doubt it's much quieter.
3. 650cc injectors should be fine, but I'd contact your tuner, that is your best bet.
I do suggest watching out for your transmission though.
Jubert69 is offline   Reply With Quote
Old 05-08-2010, 02:09 AM   #4
SubaruWrxNewb
Member#: 236017
Thanks guys.
And, yeah Ive heard about watching the transmission. I dont plan on racing or anything like that. This is my DD.
Anyone else have suggestions? Id like more than one or two opinions.
Old 05-08-2010, 02:10 AM   #5
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
1. TMIC, no question.
2. I've run a Walbro for near 7 years and have never noticed any abnormal sounds. The Supra pump (GSS341) is exactly the same as the ones we put on our cars (GSS342) except for fitment. No, you don't need an FPR.
3. 650s should be fine.
Byzantium is offline   Reply With Quote
Old 05-08-2010, 02:54 AM   #6
chop204
Member#: 171741
2009 Civic SI
Crystal Black Pearl
STI TMIC ( best bang for your buck)
I've heard nothing but good things about the walbro fp's.
650-750 should be fine
chop204 is offline   Reply With Quote
Old 05-08-2010, 03:27 AM   #7
JamesBernard
Member#: 180038
IB You dont even
own a subaru!
If you're trying to avoid lag, look into some heat retention mods; Ceramic coating & heatwrapping exhaust manifold and uppipe. This can greatly reduce spool time. And maybe add 3 port BCS for faster spool
JamesBernard is offline   Reply With Quote
Old 05-08-2010, 04:10 AM   #8
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
get a grimmspeed boost control solenoid while ur at it
if ur broke, find a gm bcs. i got mine for $50 bux shipped on classifieds
blakkboxer is offline   Reply With Quote
Old 05-08-2010, 09:58 AM   #9
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I disagree. You can find a good used TMIC like Spearco or APS in a similar price range, and they are far superior.
Just make sure you get the matching APS splitter/bellows, and you'll really need the STi scoop to take full advantage. Doing this all correctly will cost almost as much as a FMIC.
A FMIC will make more power, and be better DEPENDING on your goals, but they aren't for everyone. You will lose a bit of throttle response, but can make more power from the midrange to top-end, with more boost and more timing more safely than a TMIC.
Audiosavvy is offline   Reply With Quote
Old 05-08-2010, 10:35 AM   #10
SubaruWrxNewb
Member#: 236017
I have a GM 3-Port EBCS.
Lets say I go with a FMIC. Which should I look into getting then?
Old 05-08-2010, 10:36 AM   #11
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
i got a css fmic on mine and i use a mbc
shift0246 is offline   Reply With Quote
Old 05-08-2010, 11:01 AM   #12
Byzantium
Member#: 207826
85k 2002 WRX
CSS was a scammer. Also, you paid $500 for a $300 intercooler. I paid $200 more for the intercooler that the CSS is a bad copy of.
If you're looking at FMIC, the Injen Phantom is probably your best bet. Due to it's proportions you won't suffer as greatly with some of the FMIC downsides, however the intercooler itself is quite small (smaller than pretty much any TMIC that will fit on your car).
Old 05-08-2010, 11:05 AM   #13
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
[quote=Byzantium;30666085]CSS was a scammer. Also, you paid $500 for a $300 intercooler. I paid $200 more for the intercooler that the CSS is a bad copy of.
actually i paid 350 for it and it fits perfect. i havent had any problems with it for about a year and a half.. holds 23psi all day
Old 05-08-2010, 11:12 AM   #14
SubaruWrxNewb
Member#: 236017
Lets not fight. I just want to know some intercoolers that will give the best bang for buck.
Old 05-08-2010, 11:49 AM   #15
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Part of my setup:
Evo III 16G
Grimmspeed 3 port BCS
TGV deletes
Turbo XS TMIC
EWG dump to atmosphere
IWG blocking bracket
Walbro pump
DW 1000cc injectors (same price as the 850's so why not? Plus I run e-85)
Cobb TBE with thermal wrap
Turbo inlet
This is my "in-between" setup which I use for auto-x, so I had quick spool and a "wall" of torque in mind when I chose to go this route. It put down more power on Surgeline's dynamometer than any other 16G setup to date, so regardless of the actual HP number, I did get real gains by getting the supporting mods in place. Now the curves and numbers will look different on your 2.0, but I think the point remains the same. I haven't seen any gains from a FMIC with this setup that suit my needs, or I would have simply gone that route. When I did this setup cost was not an issue, so it definitely wasn't about the $, it was about my intended use and what would serve that purpose the best.
UFOpilot is offline   Reply With Quote
Old 05-08-2010, 12:52 PM   #16
SubaruWrxNewb
Member#: 236017
Originally Posted by UFOpilot View Post
Part of my setup:
Evo III 16G
TGV deletes
Turbo XS TMIC
Walbro pump
Turbo inlet
What numbers did you put down?
Old 05-08-2010, 03:59 PM   #17
Audiosavvy
Member#: 150794
Qcab dakota 4x4
It doesn't matter because any dyno is different.
Old 05-08-2010, 08:39 PM   #18
SacksLax
Member#: 193949
I have a hyperflow TMIC on mine, I like it a lot as well. 650's will be fine, also just get the Walboro
SacksLax is offline   Reply With Quote
Old 05-08-2010, 08:46 PM   #19
xeiros
Member#: 205411
2006 WRX STI
Obsidian Black
You must not talk to many current or former DSM'ers. We call them whine-bro's. Not all of them do, but it's been common enough to where people know about it.
xeiros is offline   Reply With Quote
Old 05-08-2010, 08:47 PM   #20
SubaruWrxNewb
Member#: 236017
Yeah, my friends was on a 98 GS-T. Whined constantly. Could not stand it.
Old 05-08-2010, 09:00 PM   #21
ftnjun2x
Member#: 107096
04 WRX
Sorry to hijack the thread, but is it necessary to replace the fuel pump for this type of upgrade? Coz I'm planning to go this route too.
ftnjun2x is offline   Reply With Quote
Old 05-08-2010, 11:10 PM   #22
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Necessary if you want to get the most out of the setup, the stock fuel delivery is not enough for much more than a monster-tune on the td04. You won't be able to utilize more air without more fuel.
Old 05-08-2010, 11:12 PM   #23
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Which is exactly why I didn't post up the numbers. Also notice I don't have them in my profile either, though there is a thread floating around with the charts in it if the person who posed the question wanted to see the curves. Which really tell more of the story than specific numbers could.
Old 05-09-2010, 01:52 AM   #24
SubaruWrxNewb
Member#: 236017
I just want a DD with good power. I mean, Stage 2 is amazing, but I just want a little more. Once I go with the EVOIII 16G setup, I'll probably be done with the motor. Going to start focusing on everything else.
Old 05-09-2010, 04:05 AM   #25
vinxH
Member#: 159796
2006 WRX
vinxH is offline   Reply With Quote
*Help* I need help choosing the better 16g..TD05 Big 16g or FP 16g or EvoIII 16g? min88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-04-2009 12:38 AM
16G evoIII smog questions orchidrider Southern California Impreza Club Forum -- SCIC 8 02-01-2009 02:26 AM
Difference between FP EVOIII 16G and Blouch EVOIII 16G?? Alan l. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-30-2008 03:31 AM
goin EVOIII 16G soon, one question about intake setup 280hp_REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-04-2006 09:19 AM
Super 16g vs. EvoIII 16g dpk777 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-28-2006 11:02 PM
