Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 05-08-2010, 11:42 AM   #1
TurboQueef
Member#: 86700
2005 STI
Silver/Black,11.44@123.60
Default 21500 miles on an Axis / RAW Performance motor
Did you ever wonder what the inside of a Axis / RAW Performance built motor looks like after 21500 miles?
At 21500 miles the motor was still running strong.. making same power as it did at 5K miles when I started to add BOOST to it.
The only issue I had with this motor was piston slap from the drivers side. It became noticeable at 5K miles.
I continued to drive the car with the piston slap and put 16500 additional miles on it.
I decided to pull the motor and drive it down to Ron's shop in Columbia IL for a refresh. The car is for sale... for the right price (see my classified add if interested). My plan was to evaluate the motor condition after 21500 miles and if everything looked good... upgrade the performance a bit more with ported heads and aftermarket rods.
Ron, Shawn (Ron's assistant) and I were very happy with what we found inside the motor... very minimal wear and no surprises.
The video below captures the key points of our evaluation.
About my project:
2005 STi, AXIS / RAW Performance motor (see spec below), FP Red, KS Tech 83mm CAI, DW 850 injectors, Tuned with ROMRaider & StreetTUNER by myself (with help from a few very good friends).
The car was achieving 29.72 miles per gallon highway driving.
I ran a best of 11.44 @ 123.60 in the 1/4 mile
My build specs:
About Axis / RAW Performance:
The video probably speaks for itself... but I will add that I am very impressed with the quality of work Ron produces. In addition to top quality the customer service is unbelievable. I really appreciate Ron and Shawn's willingness to allow my son and I to capture the experience on film.
If you are looking for a solid build, I recommend Ron and his team. If you are interested, visit his webpage: http://raw1performance.com/
TurboQueef is offline   Reply With Quote
Old 05-08-2010, 11:56 PM   #2
cha86
Member#: 111048
I <3 debt
word rally suck.
ok..im not one to question rons ability to build engines, but keeping those cam caps in order is pretty important, not one minute into the video they just discard them into a box.
i dunno about all that.
cha86 is offline   Reply With Quote
Old 05-09-2010, 12:02 AM   #3
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
21,500 miles isnt exactly a lot
wrxwhat is offline   Reply With Quote
Old 05-09-2010, 12:07 AM   #4
MartinSTi05
Member#: 145145
2006 wrx STi
All the caps are numbered from the factory.
MartinSTi05 is offline   Reply With Quote
Old 05-09-2010, 01:07 AM   #5
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
they are not only numbered position wise but also with the matching 3 digit # on the back of the head so they are matched to the appropriate head.
john 1badSTI is offline   Reply With Quote
Old 05-09-2010, 01:33 AM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
The deposits on the valves..... was that from running c16 race fuel?
jigga is offline   Reply With Quote
Old 05-09-2010, 01:56 AM   #7
TurboQueef
Member#: 86700
2005 STI
Nope... it was from Citgo 110 leaded
Old 05-09-2010, 10:04 AM   #8
2milehi
Member#: 81633
'98 RS-T
How much clearance was there between cylinder #4 and the associated piston?
2milehi is offline   Reply With Quote
Old 05-09-2010, 10:23 AM   #9
TurboQueef
Member#: 86700
2005 STI
Let me confirm with Ron, I believe: Passengers side (no noise) were around 0.003, noise maker was 0.0035
Old 05-09-2010, 07:23 PM   #10
cha86
Member#: 111048
I <3 debt
word rally suck.
are you sure? i never saw any numbers on mine. just a small arrow indicating direction..i guess i was just over cautious on my build then i suppose
Old 05-09-2010, 07:56 PM   #11
MartinSTi05
Member#: 145145
2006 wrx STi
Every Subie ive ever torn apart the caps are serialized and have int and or ex somewhere on them.
Old 05-09-2010, 08:02 PM   #12
sense of nature
Member#: 112759
2018 bugSti
SexyRP
The way that piston moved in the video it looked alot more than .0035
sense of nature is offline   Reply With Quote
Old 05-09-2010, 10:54 PM   #13
subSTIaru
Member#: 224925
i believe that they use CP pistons they ask for a lot of clearance and they always slap i had a car in that sounds just like that with CP pistons it souned like it had a rod knock it is normal for cp's
subSTIaru is offline   Reply With Quote
Old 05-09-2010, 11:14 PM   #14
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
^^^^ This
that looked real sloppy.
woodys77 is offline   Reply With Quote
Old 05-10-2010, 05:22 AM   #15
TurboQueef
Member#: 86700
2005 STI
Just checked with Ron, the noisy on was .0037 all rest were .0032~.0034.
He is going to set the refresh a little tighter, .0027~.0028
Old 05-10-2010, 06:50 AM   #16
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Of course it is, the bore clearance is measured at the largest point on the piston, which is near the base of the skirt. The crown is much smaller as it expands more due to being much hotter.
A 99.5mm piston crown will expance to 99.86mm when going from 20degC to 180degC, so obviously it needs to be MUCH smaller than the base of the piston.
Originally Posted by woodys77 View Post
^^^^ This
Pavlo is offline   Reply With Quote
Old 05-10-2010, 10:10 AM   #17
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Interesting insight....
Old 05-10-2010, 01:59 PM   #18
Pavlo
Member#: 23015
95-> GC8
The top ring land will also be oval too, and some piston companies use grooves to allow a tighter clearance, if the pistons scuff the grooves allow the high spots to deform or wear without seizing in the bore.
Old 05-10-2010, 03:38 PM   #19
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
They're marked as to what positionand direction they go on the head so putting them backin the right spot is all about knowing what direction is fron and what cylinder is what.
Old 05-10-2010, 04:08 PM   #20
03silverscoob
Member#: 192856
2004 Sti
JBP
I have a motor from them also, but mine actually has like 30k miles almost. it has the cp pistons and mine are noisy as hell! theyve gotten a lil louder, but theyve really stayed about the same for awhile. they do sound like a rod knock, alotta people have asked me about it.
03silverscoob is offline   Reply With Quote
Old 05-10-2010, 08:50 PM   #21
TurboQueef
Member#: 86700
2005 STI
Yea... the sound is horrible.. and embarrassing .... till you get into the throttle and all worries go away.
I carpool with a guy to and from work... he is a performance nut ... but... the first time he heard the piston slap, he asked that I give him warning before mashing it ... so he could put his safety glasses on
Old 05-10-2010, 08:56 PM   #22
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
do you have a clip of the motor running?
AWDWRXLOVER is online now   Reply With Quote
Old 05-10-2010, 09:06 PM   #23
TurboQueef
Member#: 86700
2005 STI
Sure.. here is a clip from last Friday as I was positioning it for the extraction!
Old 05-10-2010, 09:15 PM   #24
TurboQueef
Member#: 86700
2005 STI
Old 05-10-2010, 09:19 PM   #25
TurboQueef
Member#: 86700
2005 STI
And.. finally, here is what it sounded like running the 11.44 pass (the slap started to happen well before this pass was made)
Axis/Raw Performance customers....... boogerwrx Built Motor Discussion 728 09-23-2014 10:18 PM
Do you own/have owned an Axis/Raw performance block? Post up Stames_wiltz Proven Power Bragging 74 05-30-2009 08:41 PM
FS: Axis/RAW performance longblock P&P heads builtgt35rsti Engine/Power/Exhaust 27 05-24-2009 04:12 PM
Axis/Raw performance??? adofly General Community 19 05-08-2009 07:00 PM
Meth on an RS? ANY performance gains? shanemono4 Water/Methanol Injection, Nitrous & Intercooler Cooling 2 07-06-2008 11:23 AM
