Old 06-07-2002, 09:07 PM   #1
evorace1
Member#: 17310
92 Mitsu Eclipse
Cool WRX RECORD Dynapack Dyno Results for Evolution Racing Sports WRX
We made 5 successful pulls at Knowledge Performance in Woodstock, Georgia. The guys are great down there. Very friendly and very helpful with a brand spanking new dynapack awd dyno. Southeast guys should really check them out. Their website is www.knowledgeperformance.net I want to give a big thanks to those guys.
Results AT THE WHEELS
389.3 horsepower at 6352 rpm
313.4 ft/bs of torque at 5653 rpm
Scan of dyno of course will be available soon. All done on the stock ecu with an apexi safc. I just got back from there.
chad
evolution racing sports
evorace1 is offline   Reply With Quote
Old 06-07-2002, 09:08 PM   #2
jmott
Member#: 6713
2007 Prius
brown
awesome!
whats the latest list of mods?
jmott is offline   Reply With Quote
Old 06-07-2002, 09:11 PM   #3
evorace1
Member#: 17310
92 Mitsu Eclipse
the car hasn't changed since we first posted pictures, except with minor things.
Forced Performance Green
2 1/4in Catless Uppipe/3in Downpipe
STI Injectors
Supra Pump
HKS Exhaust
HKS Standard Wastegate
Joe P MBC
Blitz FMIC
Apexi SAFC
HKS FCD
Stock bottomend, stock heads, stock cams, stock intake mani, stock throttlebody, stock exhaust manifold except port matched to the bigger uppipe.
Old 06-07-2002, 09:12 PM   #4
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default Re: Dynapack Dyno Results for Evolution Racing Sports WRX
chad
GREAT results and I tell you some great guys ! Very very excelent guys ! Theyt desreve the crown of the most HP and they sure knew what they were doing !
alfriedesq is offline   Reply With Quote
Old 06-07-2002, 09:14 PM   #5
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
BTW - when are the rest of you guys going to start believing me about the SUPER AFC???
Old 06-07-2002, 09:15 PM   #6
evorace1
Member#: 17310
92 Mitsu Eclipse
thank you al. We appreciate your support.
i tried to tell folks that the afc was a neat gadget.
Old 06-07-2002, 09:16 PM   #7
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Did you guys see the new FP30 turbo on the Forced Performance web site ???
Old 06-07-2002, 09:18 PM   #8
evorace1
Member#: 17310
92 Mitsu Eclipse
oh yeah! hmmm...wonder what's next for our wrx?
Old 06-07-2002, 09:19 PM   #9
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
I can't wait till these guys get to the 1/4 mile race track !
BTW - PPS - If this was on street gas i'm going to need a Xanax pill to de-stress!
Hoping this is race fuel !
How much boost was this at - - how many RPM;s to reach boost power ?
Old 06-07-2002, 09:21 PM   #10
evorace1
Member#: 17310
92 Mitsu Eclipse
c16 gas and 23.9lbs of peak boost
Old 06-07-2002, 09:32 PM   #11
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Thanks !
Looks like the GREEN is a perfect match for the WRX!
I have another turbo on order - and soon we'll see some comparsions with other kinds of turbos - eg Garret
BTW - anyone know exactly which parts are IN the GREEN??
GREEN looks like a killer combo on the WRX!
Old 06-07-2002, 11:08 PM   #12
evorace1
Member#: 17310
92 Mitsu Eclipse
the green is td06h t04e 50 trim 7cm2 housing
Old 06-07-2002, 11:09 PM   #13
jmott
Member#: 6713
2007 Prius
brown
I believe the SAFC is a fine tool for adjusting the air fuel ratio.
now, where is the tool for timing?
Old 06-07-2002, 11:10 PM   #14
evorace1
Member#: 17310
92 Mitsu Eclipse
the stock ecu will take perfect care of that. I had 28 degrees spark advance to redline. You just have to know how to trick it.
Old 06-07-2002, 11:13 PM   #15
FloridaWRX
Member#: 7708
'83 huffy 10-speed
yellow
can you post a dyno map of this setup on street gas (93) ?
FloridaWRX is offline   Reply With Quote
Old 06-07-2002, 11:16 PM   #16
evorace1
Member#: 17310
92 Mitsu Eclipse
unfortunately I can't. I did not dyno the car on pump gas.
Old 06-07-2002, 11:22 PM   #17
FastRedWrx
Member#: 11773
2002 Imprezza WRX
Sedona Red
Would you recommend the safc if you can't get it dyno tuned? If so what would you use to monitor the changes with?
FastRedWrx is offline   Reply With Quote
Old 06-07-2002, 11:35 PM   #18
mynew02
Member#: 13726
2002 WRX - 264 AWHP
ION-Turbo&LINK [email protected]
By all means! How?
Great results!
-Jonathan
mynew02 is offline   Reply With Quote
Old 06-07-2002, 11:36 PM   #19
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Any chances they dyno'd a stock WRX on that dyno? It's kind of hard to pull the figures out of thin air, a comparison to a stock car would be very useful. Great numbers in any respect, I have no doubt you'll be deep in the 11s whenever you get to a 1/4 strip.
Old 06-07-2002, 11:38 PM   #20
FloridaWRX
Member#: 7708
'83 huffy 10-speed
yellow
any plans on hitting the track, id love to see some trap speeds
Old 06-07-2002, 11:48 PM   #21
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Originally posted by mynew02
By all means! How?
Great results!
-Jonathan
Thats the wonder of the Super AFC - its amazing what leaning out the A/F ratio a little bit can do to the timing curve on the WRX!
Old 06-07-2002, 11:55 PM   #22
mynew02
Member#: 13726
2002 WRX - 264 AWHP
I think the wild card for the S-AFC is the race fuel. No reason to retard to redline with that C16 (unless your worried about pushing the cylinder pressures too high.)
This is very exciting given the small number of mods!
-Jonathan
Old 06-08-2002, 12:07 AM   #23
evorace1
Member#: 17310
92 Mitsu Eclipse
i think vishnu and turboxs have dynoed stock wrxes on several occassions. I know Todd (ByByv8) put down 199 at the wheels without the spray on the very same dyno, if the guys from knowledge performance told me correctly.
Old 06-08-2002, 12:07 AM   #24
evorace1
Member#: 17310
92 Mitsu Eclipse
By all means! How?
Great results!
-Jonathan
Old 06-08-2002, 12:09 AM   #25
evorace1
Member#: 17310
92 Mitsu Eclipse
i will be hitting the 1/4 soon. However, I did run the car in the 1/8th.
[email protected]
That is the fastest 1/8th mile of any subaru currently known in the United States, if I am not mistaken.
Evolution Racing Sports WRX Evolution Racing Sports Member's Car Gallery 48 02-13-2002 06:15 PM
Vishnu Stage Zero AWD Dynapack dyno results shiv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-12-2002 12:05 PM
Evolution Racing Sports (merged thread) WR_eXe Vendor Reviews 4 12-10-2001 07:15 PM
Evolution Racing Sports wRx14pSi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-11-2001 09:05 AM
anyone from van dealt with evolution racing sports before?? Akord Vancouver Impreza Club Forum -- VIC 1 09-04-2001 01:55 PM
