Old 10-12-2010, 09:51 PM   #26
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Sorry I didn't respond earlier. The point of modding the stocker was two-fold:
1) To get more efficiency from the bigger scoop, you'll need to raise the splitter to seal against the top (underside) of the scoop. If you install a taller scoop you'll have a good 1 inch gap between the splitter and scoop - effectively rendering the larger scoop useless.
2) I enlarged the splitter to direct (and contain) all airflow to the larger footprint of the new TMIC. This should be done with all aftermarket TMIC's (regardless of the scoop used).
Originally Posted by quazimoto View Post
Most aftermarket splitters direct and distribute air equally over the TMIC. The one the OP made will just cool the top part of the TMIC.
Not 100% true...I do agree that by having the added diffuser the STI splitter has, will help assist/direct airflow to the front of the TMIC. BUT, I think it's hard to prove that I'm only cooling the top(rear) part of the TMIC without it. I am still getting the same amount of air passing through the intercooler... right? If anything by having the extra diffuser, you're actually creating an obstuction which will slow the incoming airflow, but you'll have the benefit of knowing the airflow is distributed between the top and bottom.
paintbing is offline   Reply With Quote
Old 10-13-2010, 01:36 PM   #27
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Even though it's the same amount of air going through, that air will be moving more quickly if it's concentrated on a small part of the IC. Because of the faster moving air, the heat will have less time to transfer to the air as it passes through. Also, the IC surface area being exposed to incoming air will be less without a diffuser. If less surface area is exposed, less heat can be transfered.
In a perfect world, air would flow evenly over the entire IC.
573 is offline   Reply With Quote
Old 10-14-2010, 03:28 PM   #28
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Kind of....
We need to take into account the theory behind the wind-chill factor. The faster the air moves across a surface, the quicker the said surface will transfer heat... to a degree.
Once the air speed reaches a certain point (not sure what it is) the amount of heat transfer is flattened. Whether that speed is 10 mph or 100 mph I am not sure.
Either way, their will still be air moving through the entire TMIC. The top may be faster while the bottom might be slower, but air is still moving across all points.
Old 10-14-2010, 06:17 PM   #29
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
has anyone done this with a stock wrx splitter to fit an sti top mount? also what else could serve as a good material to use for the seal?
EvileyeZ88 is offline   Reply With Quote
Old 10-14-2010, 07:28 PM   #30
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Many people have used garage door seals - it's a foam/rubber compound that will help seal the TMIC to the scoop/splitter.
Old 10-14-2010, 07:36 PM   #31
EvileyeZ88
Member#: 233501
99 outback sport
perfect thanks
Old 10-14-2010, 09:50 PM   #32
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Kind of....
Part of the whole wind chill thing is more air is hitting you. in this instance, there's a fixed amount of air coming in through the scoop. you're better off distributing that air evenly over the ic so it can pick up as much heat as possible as it passes through. if you want to take advantage of the whole wind chill thing, drive faster.
Old 10-14-2010, 10:14 PM   #33
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
+1, I did a bit of a test when I made my air splitter/divider for my '02 WRX and there was a difference of about 2*C colder IC core on average, but the main effect was faster cool-down, noticeably faster cooling down of the IC...
wrxdrvr is offline   Reply With Quote
Old 03-11-2011, 04:54 AM   #34
wrxkyle
Member#: 199635
02-4 rSTI
i think i'm going to bust out the cardboard tomorrow and see how much of the zerosports wrx splitter i can replicate and measure out, just got an aps tmic and sti scoop. looking at an aps splitter but that's still 70$ at least used and i'm not sure how well it will even fit or how well their intercooler spray nozzles work. now, considering i'll probably buy the aps one anyway, and they don't sell in the US anymore, how cosher would it be to reverse engineer i?
wrxkyle is offline   Reply With Quote
Old 07-23-2012, 02:04 AM   #35
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Bump from the dead, good 'ol search led me here and I completed this project this weekend.
I don't have a bunch of good pics but there was quite a bit needed to fit the version 9 intercooler. There is still a few minor tweaks I need to do but overall it should work better than the wrx splitter with no seal.
Still need to fill a few gaps.
ImNOrobo is offline   Reply With Quote
Old 08-13-2012, 01:25 AM   #36
EvileyeZ88
Member#: 233501
99 outback sport
I started to mod my stock splitter, but the 06/07 wrx gets a postage stamp for a tmic, so that turned into a mess.
I just decided to make one completely from scratch.
All parts bought from home depot for under $30
Piece of 3'x3' aluminum $21.98
1/4" weather stripping $3.50
42" of 1 3/4 foam $2.55
42" of 2 3/4 foam. $3.55
Traced my zerosports splitter to get the general shape.
Then drilled the mounting holes and added weather stripping.
Then measured the opening for the tmic
Drilled the holes for the Turbo to vent, and mounted the thicker foam with silicone.
It's still a little bit rough, but it works great and keeps the tmic nice and cold.
Top mount will go from 140* to 90* in under 3 minutes
Next up will be to add the diverter fins, and some form of seal for my SRI
~Evil
Old 08-13-2012, 02:08 AM   #37
N8F
Member#: 305804
2006 Impreza WRX
~Evil
Genius sir. Pm me if you're interested in making another one to sell
N8F is offline   Reply With Quote
Old 08-13-2012, 02:11 AM   #38
EvileyeZ88
Member#: 233501
99 outback sport
You sir have a pm
Old 09-06-2012, 02:06 AM   #39
Trudd84
Member#: 250706
2004 Impreza WRX
I will also be attempting this in a week or so, my 04 STi scoop should be in this Saturday. I have a question. Seeing as how this is all under the hood and scoop, nobody really ever sees it. My question is why not use cardboard to get an exact shape, and fiberglass it? I mean, in the end it's light weight, heat resilient for what it will need to do and a few good coats of resin and 2 layers of cloth and it will be strong enough to withstand the little bit of force it will have on it... but my footprint isn't changing, just the scoop. so maybe it will be easier for me. Will report back.
Trudd84 is offline   Reply With Quote
Old 09-06-2012, 02:26 AM   #40
luvless2620
Member#: 190566
At EvileyeZ88: Wow that splitter looks nice. Any plans on making a bellow for it as well?
luvless2620 is offline   Reply With Quote
Old 09-06-2012, 06:32 AM   #41
EvileyeZ88
Member#: 233501
99 outback sport
Its got 2" foam on the front and sides, and 1 1/2" foam at the rear which creates a nice seal, and keeps the tmic nice and cool
I may eventually add diverter fins if I feel it needs them.
~Evil
Old 09-06-2012, 09:21 AM   #42
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
I simply cut my splitter at the back seam, and formed it to the inner form of the hoodscoop. Added braces to keep it solid, then used "speed tape" to fill the voids, and added 4 layers of it. It's held up for 8 months no problem, and you can clearly see the entire TMIC now. I may add a fin or two at a later point. I might grab pictures later.
Splitter with big TMIC ptirmal Newbies & FAQs 15 02-14-2007 04:12 AM
what splitter for big tmic pux888 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-01-2005 12:53 PM
does anyone make a new TMIC gasket and splitter for hyperflow TMIC? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-16-2004 12:04 PM
FS: Zerosports Replica Splitter for TXS TMIC and STI scoop wrx_fun Private 'For Sale' Classifieds 6 01-09-2004 09:26 PM
Scoop splitter for APS TMIC Nick W Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-07-2003 06:10 PM
