Old 05-09-2010, 12:49 AM   #1
UncleSpud
Member#: 144294
09 WRX Sedan
Default Sticky Throttle question on Cobb Stage 1 '09 WRX Sedan
I received my AP yesterday, and promptly uploaded the Cobb Stage 1 map (91 octane) to my '09 WRX Sedan. Very pleased with the results--acceleration is smoother, throttle response is more crisp, and the car pulls like crazy from 3500 RPM to redline. The car has every bit as much top end as my previous car--an '06 STI.
Having chipped two vehicles in the '90's (a '93 BMW 325is and a '98 M3), I can tell you that the AP has far greater bang-for-buck than the two Dinan chips I bought. I could barely notice a difference with the chips on my Bimmers--big difference with the Cobb map.
One thing still puzzles me: my '09 has the sticky-throttle issue that's plagued other '09 Rexes. I thought it might disappear with the Cobb map, but it hasn't. It doesn't affect drivability--it's mostly an annoyance as the revs don't always drop when you stab the clutch. That one nit aside, I'm a happy camper.
I wonder if Travis from Cobb Tuning (or others) might weigh-in on this issue?
UncleSpud is offline   Reply With Quote
Old 05-09-2010, 08:22 AM   #2
arghx7
Member#: 232940
I don't think the drive-by-wire dashpot logic has been disassembled much for Subarus, either by Cobb or Ecuflash/RomRaider guys. There must be some routines which control the rate at which the throttle plate closes on decel, but I've never seen any tables in ATR for them.
arghx7 is offline   Reply With Quote
Old 05-12-2010, 03:15 PM   #3
BgEzZy
Member#: 136627
10 WRX
Does this happen only when coming to a stop with the clutch in?
BgEzZy is offline   Reply With Quote
Old 05-15-2010, 01:40 AM   #4
UncleSpud
Member#: 144294
09 WRX Sedan
Sometimes, but not always.
Old 05-17-2010, 02:36 AM   #5
BgEzZy
Member#: 136627
10 WRX
Mine does the same thing, sometimes revving over 3000 RPM. Took it to the dealer and they told me it is normal. They said it does this in order to achieve zero partial emissions. Not sure if you are having the same issue. But, sounds similar.
Old 05-17-2010, 10:40 PM   #6
amach1
Member#: 220913
2010 WRX, 5d
Same thing on my (stock) 2010 WRX. It is more a nuisance than anything else and can make you feel like a complete klutz, maneuvering in a parking lot with the revs creeping up to 3,000!
I have learnt to quickly shift into neutral and back again to drop the revs. As BgEzZy suggested, itís probably mapped that way for emissions.
Heck, if Cobb or Perrin can find a fix, it might persuade me to go AP stage 1. Clearly, Subaru hasnít a clue.
amach1 is offline   Reply With Quote
Mid-range dip in power on Cobb Stage 1 WRX - Datalogs inside - Please help! BlackPooL Engine Management & Tuning 2 01-19-2010 10:27 PM
Question on cobb AP for 07 wrx JustAnotherSubie Newbies & FAQs 1 02-24-2009 11:50 PM
Stage 1 '09 WRX feedback nhmtns AccessPort 1 11-20-2008 12:35 PM
Loud Turbo, Low Boost on Cobb Stage II 2003 WRX..??? kyoung05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-10-2007 01:46 AM
some questions about COBB stage 1... ChrisWRB Engine Management & Tuning 8 07-04-2005 07:06 PM
