Old 05-10-2010, 01:25 PM   #1
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
Default need Cage build feed back...
Built up a cage for a Lemons car. This is a budget build so we kept it pretty basic but I am interested in hearing any constructive criticism. Ok, I'll start with an easy one: Harness bar located way too low. That is being fixed today. What else?
TubeDriver is offline   Reply With Quote
Old 05-10-2010, 01:27 PM   #2
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
looks pretty good. i'd throw another bar in the nascar bars in the doors. at least the drivers side. thats a pretty big opening IMHO
Old 05-10-2010, 01:29 PM   #3
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
Make the hoop diagonal one continuous piece.
edit: make the hoop diagonal an actual hoop diagonal.
TyrannoSullyRex is offline   Reply With Quote
Old 05-10-2010, 01:34 PM   #4
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
Thanks. We plan on putting a diagonal in the middle of the square portion of the door bar.
Old 05-10-2010, 01:38 PM   #5
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
Yea, that would be nice. We probably will not do this as it would require replacing and redoing that entire section. However, the rear diagonal meets the letter of the rulebook requirements for SCCA.
We might beef up that area with a gusset or two where the rollhoop "diagonal" and harness bars meet up. We might also turn the rear diagonal into an "X" brace which will help to support the main hoop.
Old 05-10-2010, 03:54 PM   #6
Element Tuning
Member#: 54918
Are all your drivers short? The harness bar and hoop look to far forward for someone 6ft.
Nascar bars are too far apart.
I think you should have asked this before you built it. LOL!
Element Tuning is offline   Reply With Quote
Old 05-10-2010, 04:02 PM   #7
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
3 out of 4 drivers are 6'+ and they fit fine. The 4th driver is 5'6" and can barely touch the pedals or see over the dash bar. Don't let the giant 25" Volvo steering wheel throw off your sense of proportion.
We had to get something in fast so we just went for it figuring that we could make some adjustments later on.
Old 05-10-2010, 04:09 PM   #8
MasterKwan
Member#: 98961
2003 WRX
I'd cut out all the tubes out of the main hoop. The ones inside the hoop. Then add 1 diagonal and a proper harness bar. I'd have probably moved the main hoop farther to the back too.
What spec does "Lemons" require you to follow?
Old 05-10-2010, 04:15 PM   #9
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
At minimum, cage must include: Full front and rear hoop, appropriately braced to each other along the roofline; two drivers-side door bars (X-design is acceptable); appropriate main-hoop backstays with no bends, located as close to 45 degrees from horizontal as practical; one main-hoop diagonal; appropriate spreader plates and gussets; complete 360-degree welds at all joints. Each major load-bearing member must be formed from its own single, continuous tube. Shoulder-harness bars strongly encouraged, and virtually necessary for proper shoulder-harness mounting in some applications (the attachment point of all shoulder harnesses must be between zero and 15 degrees lower than the seat-entry point); dash bars very strongly encouraged.
o 3.1.1: Rollbar Tubing and Padding: Minimum tubing size for cars weighing under 3000 pounds as raced is 1.50" x .120" or 1.75" x .095". Cars weighing over 3000 pounds as raced must use a minimum tubing size of 1.75" x .120". Properly-bent, racecar-grade and -quality tubing is mandatory: no stretched or crushed bends allowed. DOM mild steel is very strongly recommended over ERW (seamed) tubing.
Old 05-10-2010, 04:24 PM   #10
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
We read the rules which I believe are similar to SCCA cage requirements regarding rear hoop diagonals to mean that:
at least a single diagonal must brace the rear main hoop. That diagonal can be located inside the rear hoop or located in the rear hoop rear support legs.
Old 05-10-2010, 04:32 PM   #11
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
Rule of thumb i've used for the past 20 years. Build a car for the WORST case scenario.
IE dont do a halfass job on safety equipment.
Old 05-10-2010, 04:38 PM   #12
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
I agree. We are running a 4L 6 nozzle AFFF fire supression system. We are redoing the harness bar so adding a single continuous diagonal within the rear hoop might be pretty easy to do.
Once we have an additional diagonal in the NASCAR door bar I believe it will be sufficient. We also have the OEM horizontal formed steel door bar left intact (although the rest of the door is gutted).
I just am not sure if the rear diagonal alone technically meets the requirements for the rear hoop diagonal?
We are doing a shakedown run this weekend at a local HPDE but have plenty of time to mod the cage as needed for the race.
Old 05-10-2010, 04:45 PM   #13
Element Tuning
Member#: 54918
Oh it's a Volvo, my bad
Old 05-10-2010, 04:46 PM   #14
jamal
Member#: 71875
98 2.5GT
my wheels fit
you should really do this, along with some work on the nascar bars.
jamal is offline   Reply With Quote
Old 05-10-2010, 06:05 PM   #15
MasterKwan
Member#: 98961
2003 WRX
Personally, I don't think it does. Look at page 84 and 85 of the GCR. The intent is a single unbroken bar turning the hoop essentially into two triangles.
[IMG][/IMG]
My M3 cage.
2. Main Hoop Bracing
a. Main hoops shall incorporate a diagonal brace. The brace
shall either be in the plane of the main hoop, or extend
from the top of one rear brace (described in 9.4.B.2.c) to
the bottom of the opposite rear brace. Automobiles with
mid mounted engines can have the lower mounting point
attach to the frame of the automobile within six inches of
the main hoop. In the case of braces in the plane of the
main hoop, the brace must span at least 50% of the width
of the main hoop, and at least 75% of the height of the
main hoop as shown in figure 12.
I might be wrong.
Old 05-10-2010, 06:33 PM   #16
Viperguy324
Member#: 121108
2006 06 Spec C
6 nozzle..wow.. 2 in the cockpit? No rear fire wall?
as for the cage, what is fixing the the A-pillars together? no dash bar?..looks like you went for the nascar bars.. focusing on side impact but have not tied them together in the front
Viperguy324 is offline   Reply With Quote
Old 05-10-2010, 06:51 PM   #17
cooleyjb
Member#: 55727
#533 Spec Racer Ford
Honestly 6 nozzles in my car would run, the required minimum into the engine and the rest around the driver. Fire systems are there to buy me time, not my car. A full fire crew has trouble putting out fuel fires in the engine compartment.
cooleyjb is offline   Reply With Quote
Old 05-10-2010, 07:01 PM   #18
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
[IMG][/IMG]
My M3 cage.
I might be wrong.
Correct. A few people had to redo their diagonal at the Houston race because it was similar to the OP's. Although none of them had one end terminating on a rear stay (which is really not good).
Old 05-11-2010, 08:41 AM   #19
Viperguy324
Member#: 121108
2006 06 Spec C
[IMG][/IMG]
My M3 cage.
I might be wrong.
That A to Main looks pretty short...
Old 05-11-2010, 09:46 AM   #20
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
There is a dash bar (along the top of the dash).
Old 05-11-2010, 10:13 AM   #21
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
OK, we have made some changes.
Stage 1 (completed before this weekend)
1) We are adding a single section diagonal in the rear hoop.
2) raising the harness bar
3) adding window net attachments
Stage 2 (done before the Lemons event)
1) adding diagonals in the NASCAR door panels
Old 05-11-2010, 11:44 AM   #22
MasterKwan
Member#: 98961
2003 WRX
It's not a race car. It's a "keep me alive in case I F up at an HPDE cage" or maybe "Re-enforce the flimsey BMW cage". Still meets all the specs. If I wanted to race, I'd just need to add net hardware and door bars.
Old 05-11-2010, 12:45 PM   #23
Viperguy324
Member#: 121108
2006 06 Spec C
to this day I cannot understand this logic.. how about its a "yeah someone ****ed up and its what I have to live with cage" ...who would do something half ass... were you trying to save $2 by having the tube shorter.. I doubt it.
Why would anyone waste the time removing everything.. all the prep and then install a half-ass cage becuase "I only drive autocross/hpde" ...
anyways, whatever your excuse.. it looks weak at that point.
Old 05-11-2010, 01:47 PM   #24
MasterKwan
Member#: 98961
2003 WRX
Haha money... Money had nothing to do with it. It's the cage that I wanted built and it meets all specs. There's nothing wrong with that cage. You just like to find fault in everything that you haven't done yourself. I understand, that it's just how you are. Every topic is the same thing "...well in the vaterland, we do it this way...".
I'm honestly surprised you haven't posted pictures of your golden cage yet...
Old 05-11-2010, 02:10 PM   #25
STi-MAN
Member#: 70252
05 STI
blue
He will.. give it some time.. there will be a golden cage in this thread.
STi-MAN is offline   Reply With Quote
I Need Feed Back Asap !!!!!!!!!!!!! TurboCharged97L Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-26-2004 02:52 PM
PLEASE READ THIS i need some feed back pestysti Tire & Wheel 9 02-25-2004 10:59 AM
feed back needed babyblue Tri-State Area Forum 0 03-06-2003 11:25 PM
I need feed back from people with this setup SjpWrx Factory 2.0L Turbo Powertrain 3 03-05-2003 06:27 PM
just got back from Detroit...need people to feed my ego Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 6 01-22-2002 12:14 AM
Message Board Statistics All times are GMT -4. The time now is 12:15 AM.
