North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 03-03-2012, 07:48 PM   #176
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Originally Posted by Boost4life05
I'll be coming by on way back up north...i'll be sure to take some pics and vids.
On the dyno now all buttoned up time to make some magic.
Sinister redlines is offline   Reply With Quote
Old 03-03-2012, 07:56 PM   #177
TurboRX
Member#: 2455
99 2.5RS
996 Race Car
Can't wait to hear how much magic you made.
TurboRX is offline   Reply With Quote
Old 03-03-2012, 09:35 PM   #178
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Well, I do not want this to go bad and hard to say exactly what happened but it lost a rod bearing. Was low boost 15psi and very safe tune no knock whatsoever. Thankfully Mike, Steve, and Tim noticed oil pressure dropping and power dropping. Hopefully it is easy fix as really no metal in the oil bit it is making some noise.
Old 03-03-2012, 09:37 PM   #179
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
But it did make 400whp at 15psi.. I wish I could just catch a break. More life challenges not like I need any more right now.
Old 03-03-2012, 10:30 PM   #180
theotherguy
Member#: 191514
'05 FXT
Damn Chris! Your dad and I were talking about your car this week and we were both excited over it. It was great to see how supportive he is. Just another small bump, you'll get it! Let me know if you need anything.
theotherguy is offline   Reply With Quote
Old 03-03-2012, 10:34 PM   #181
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Thanks Tony, I am at my end of wits with this car. I will get it fixed already talked to Dom about it and he is going to take a look at it as soon as I get it out. It is really hard to say what the failure was. Thats kinda why I am just going to go the get it fixed and figure out what caused it only for the reason to prevent it again.
Old 03-03-2012, 10:57 PM   #182
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
http://www.youtube.com/watch?v=owqCv...ature=youtu.be
Run right before the issue started..
Old 03-03-2012, 10:58 PM   #183
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
if it was losing pressure than it must be something else than the pure fact of it just spun a bearing. something else failed causing it to loose pressure.
did you ever figure out the e85 breather thing?
NW2TONE is offline   Reply With Quote
Old 03-03-2012, 11:02 PM   #184
NW2TONE
Member#: 212509
your **** go faster
save that oil so you can send it in for analysis.
Old 03-03-2012, 11:06 PM   #185
RexRexRex
Member#: 37389
2003 gt35r wrx
Built not bought
Sorry to hear bud but that's some serious power for 15psi.
RexRexRex is offline   Reply With Quote
Old 03-03-2012, 11:06 PM   #186
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
We dissagree Dave, it was running extremely well then power dropped and the oil presure dropped 15psi. It still ran well and had 48psi oil at idle. Then they did a slight no load roll and you could hear the rod. I also talked to a few people and the ethanol in the oil can is normal under break in, it slowed down considerably.
Old 03-04-2012, 12:12 AM   #187
NW2TONE
Member#: 212509
your **** go faster
Old 03-04-2012, 12:42 PM   #188
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Yes we did and changed the oil again. Dom knows all the facts and nobody is assuming anything at this point. MPS builds have a strong background and no issues. At the same time Dom has and continues to stay involved. I just want to conquer this car and drive the damn thing.
Old 03-04-2012, 12:54 PM   #189
TurboRX
Member#: 2455
99 2.5RS
996 Race Car
Man, I'm sorry to hear that. Hopefully your luck changes for the better soon.
Old 03-04-2012, 01:08 PM   #190
jdm05
Member#: 180155
e85 05 wrx
Nice vid, good luck with issues
jdm05 is offline   Reply With Quote
Old 03-04-2012, 02:55 PM   #191
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
so sad face
BREWPUBEAVER is offline   Reply With Quote
Old 03-04-2012, 05:08 PM   #192
Maxwell Power
Member#: 190729
Chris and I spoke at length about the nature of the problem.
Currently, the plan is as follows:
Remove engine
tear down engine piece by piece to determine extent of damage.
Inspect bearings.
The type of bearing wear and number of worn bearings should give us a good idea what happened. Craig and I reviewed the blueprinting sheet that we completed when assembling Chris' engine and can rule out assembly or clearances. My current suspicion is that a rod bolt stretched or broke. These rods were provided by Chris and had been used in his previous build and have been torqued repeatedly in their life. I think we'll find that there is minimal damage (they shut it down immediately and never pushed it) that worst case will require a crankshaft, new bearings and new rod bolts. I'm guessing the crank will still be good, but we are planning for worse. If it is a rod bolt, then I suppose we should have been more diligent in getting the history of these bolts before we decided to use the rods.
This engine while still new, has had a very hard life. From the first minute this engine ran it has been plagued with engine management issues. The first time it ran on four cylinders properly was only a week or so ago and this engine has been run numerous hours prior to that. It was also broken in on e85 (against my better judgement) and has shown excessive e85 in the oil at each change.
regardless of all that, we'll get to the bottom of it and get her up and running again soon.
Maxwell Power is offline   Reply With Quote
Old 03-04-2012, 05:16 PM   #193
PurpleDoors
Member#: 225582
2002 VF39'd EJ205
BRP RS Sedan
I was in the other side of the shop when this happened. Never a good thing to hear.
PurpleDoors is offline   Reply With Quote
Old 03-04-2012, 09:34 PM   #194
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Dom is correct, these rods are manly turbo tuffs. They where in my striker engine that ran a total of maybe two hours and never where under any real load. Basically idled around and a little road tuning with little to no boost. I had a reputable shop resize them after to reuse them and was told by the machine shop bolts where fine and I should have used my better judgement and changed them.
Old 03-04-2012, 10:06 PM   #195
Maxwell Power
Member#: 190729
We don't know if it is actually even the cause. Just one of my theories. We'll know soon enough.
Old 03-06-2012, 01:01 AM   #196
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Well she is home, back off the trailer again. Tomorrow comes the engine removal and Thursday head up to mps and try to figure out what went wrong and fix it. Rode in mikes monster and that car totally relit my wanting to finish my car.
Old 03-06-2012, 01:28 AM   #197
scraggy
Member#: 136384
06 SGM TR FPGreen
Stage 0011.1
I havent met you yet, but ive been through the thread twice. Im really waiting for you to catch a break. Hopefully this gets sorted out and you finally get to enjoy your car. I think this thread qualifies for a "Support Sin Fund".
scraggy is offline   Reply With Quote
Old 03-07-2012, 01:22 PM   #198
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
So I have the engine almost out, looking at my options at this point. If it is repairable easy enough than do so as long as we find the cause and fix it. Or start over with stock block with rods and pistons. I am so broke because of this car I could have almost had half the cost of a new gtr. How sick is that and besides driving it the few hundred miles last week it sat four years. Time for a new cheaper hobby like rabbits at least then when they post me off I can eat em.
Old 03-08-2012, 01:33 AM   #199
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
It is out and Dom will take it apart tomorrow night for evaluation.
Old 03-09-2012, 02:07 AM   #200
jibber
Member#: 6675
98 SF5 some mods
01 allroad
Booo, so weak!
jibber is offline   Reply With Quote
Does the turbo spin up when the clutch is in or in neutral? mmiller2002 Newbies & FAQs 14 11-26-2008 08:59 AM
How do you get the jackstands under when the jack is in the way? perret318 Newbies & FAQs 25 03-12-2006 05:38 PM
okay so the MR is out, the STi is in trouble, are they gonna make the S202 for the v8 03boxer4 General Community 47 11-04-2004 04:43 PM
Well the STi is in the shop grknss New England Impreza Club Forum -- NESIC 4 11-13-2003 01:12 PM
The cage is in the Impreza...new Tim O'Neil/Brent Hatch design. Thoughts? Sean Motorsports 21 05-03-2003 10:31 AM
Message Board Statistics All times are GMT -4. The time now is 02:33 PM.
