South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 05-10-2010, 10:03 PM   #1
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
Default anyone in prescott have a wrx tranny or engine out of a wrx?
I need to check and see how much play/noise/resistance there is on the input shaft on a wrx tranny that is known to be good.
dan az is offline   Reply With Quote
Old 05-10-2010, 11:48 PM   #2
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
there shouldnt be much play at all, though someone will correct me if im wrong.
SubeSTIle is offline   Reply With Quote
Old 05-11-2010, 04:23 AM   #3
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Look in the manual use a dial gauge. Should not have any up down side to side play. In and out a lil. What would you need the engine for?
Is there a noise you are trying to diagnose? Try explaining the noise and when it happens I know it is hard but might be able to help.
Smoby is offline   Reply With Quote
Old 05-11-2010, 04:25 AM   #4
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Oh yeah dunno if you remember me I gave you the IAC gasket a while back but I am in P town for a few days and have heard a good share of bad trans. If time is available can see if a second opinion would help.
Old 05-11-2010, 11:32 AM   #5
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
trying to locate a nasty grinding/rattle on decelaration only, and only after the car has been driven for awhile, also after it is all good and hot there is a rattle at idle that sounds almost like rod knock/pinging but both conditions go away as so as you push the clutch in. I took the engine out yesterday and I am leaning towards a bad throwout bearing, its an ACT and only has 12k on it.
Old 05-11-2010, 12:37 PM   #6
jessiyya
Member#: 184197
2003 Impreza WRX
Default Same F&^king Problem
I live in Dewey and work in Prescott. My car makes the same grinding noise during deceleration. Third gear is the worst, then fourth. 1st and 2nd dont make any noise. My car has a little under 130K on it and I'm hoping its not going to cost too much. Let me know if you figure out the problem and I'll post anything I learn as well.
jessiyya is offline   Reply With Quote
Old 05-11-2010, 12:45 PM   #7
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
When you push in the clutch does the noise instantly stop or can you hear it slow down kinda gradually?
Old 05-12-2010, 02:24 AM   #8
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
yea noise instantly stops, pulled motor out today and the throwout bearing is like a dry rollerskate bearing, sucks since there is only 10 to 12k on it, thankfully i have my old one still so hopefully this fixes the problem.
Old 05-12-2010, 06:19 PM   #9
shwoop_soobie
Member#: 102323
99 power poles
beware
when you drive do you keep your left foot riding over the clutch pedal?
even a little bit of pressure on it will cause the bearing to wear pre-maturely... i used to have the habit of riding over the clutch pedal and i wore mine out in a hurry...
shwoop_soobie is offline   Reply With Quote
Old 05-12-2010, 06:26 PM   #10
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
nope foot is off the clutch, clutch cylinder kept a little pressure on it though
Old 05-16-2010, 11:04 PM   #11
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
well changing the throwout bearing didn't fix it, I removed heat shields and beat in a part of the exhaust that could touch towards the rear of the car, im really reaching out on a limb to try to find something other than the tranny. Ill find out if it was exhaust or heat shields tomorrow, its doubtful though.
Anyone in DFW have Pinks+Tops &/or STi Short Shift? Shoefly Texas Impreza Club Forum -- TXIC 4 10-06-2004 10:53 AM
Complete 2.5rs engine/tranny or part out Structure828 Private 'For Sale' Classifieds 5 04-07-2004 11:12 AM
anyone in alberta have vishnu stage zero or sub zero? soon2bwrx Canada Region Forum 8 12-03-2002 12:08 PM
anyone in TXIC have a wrecked/parting out WRX? petrol Texas Impreza Club Forum -- TXIC 0 10-30-2002 11:34 AM
Anyone around here have motor and tranny mounts in a WRX? gtguy Mid West Subaru Owners Club Forum -- MWSOC 2 08-09-2002 08:42 AM
