Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 05-11-2010, 03:00 PM   #1
Bochet
Member#: 155613
Default To-Do List for my 2001 2.5RS - Pointers?
So she just turned over 100K.
I need a new clutch, the one that is in there is just a crappy clutch and shudders like no one's business. I'd like to go ahead and get a new flywheel and replace whatever else should be done while the tranny is out. I'd like to keep the clutch and flywheel OEM. What else usually gets changed out with a clutch job? I've got a new slave and line.
I've got a torn boot on my front, passenger side half shaft, so I'm going to go ahead and replace the half shaft. The unfortunate thing about this is that it's flung that heavy grease onto the cat and it stinks up to high heaven once heated up. I cleaned it off well with engine cleaner, but it's under the heat shield, and a never ending battle.
I need to replace the wobble joint in the trans linkage. I have the parts for this.
I need to do the timing belt. I've heard people recommend doing the water pump at this time as well. Anything else that is normally done?
I'd also like to upgrade to stainless lines on the brakes.
Everything else is great, 100K and running strong. The car just needs these few maintenance items. I'd like to be able to call someone up and order the parts, can you guys recommend a good vendor for all of the above needed parts?
Thanks all.
Bochet is offline   Reply With Quote
Old 05-11-2010, 04:36 PM   #2
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
I would go with a OEM Exedy clutch and make sure to put one of these in when you do it, this will fix the shuttering
http://www.subaruwrxparts.com/shop/p...&idcategory=19
http://forums.nasioc.com/forums/show...out+repair+kit
I'll add more when I have more time
dstan is offline   Reply With Quote
Old 05-12-2010, 09:18 AM   #3
Bochet
Member#: 155613
Good info, thanks for the link to teh snout repair kit, that's something i never would have thought of.
Old 05-12-2010, 11:08 AM   #4
mofugga
Member#: 19540
2000 old skool RS
BRP
The guys at turn in concepts have the tranny linkage part but be preparedto curse like a sailor! When I replaced mine I also put in a Grp n tranny mount, I'd highly recomend it if you don't have one yet.
mofugga is offline   Reply With Quote
WTT/FS 2008 Subaru Legacy 2.5i Ltd for 2000-2001 2.5rs + Cash or 2002-2003 WRX + Cash CCSubaru Private Vehicle 'For Sale' Classifieds 2 04-24-2010 08:45 PM
Need engine for my 2001 2.5RS Newbiewithscooby's Private 'Wanted' Classifieds 0 11-18-2009 09:21 PM
Need used set of racing tires/wheels/both for my 2001 2.5rs! Hitting the TRACK thurs! thumpetto007 Mid West Subaru Owners Club Forum -- MWSOC 7 05-11-2009 11:18 PM
My 2001 2.5RS Turbo Project-----Advise welcome redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 2 03-10-2002 03:19 AM
Just Picked up my 2001 2.5RS P023869 Newbies & FAQs 17 02-14-2001 05:13 PM
