Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 06-08-2002, 07:04 PM   #1
Bobby321
Visiting NASIOC Timeout
Member#: 19774
Default turboing 1.8litre
ive got a 95 inpreza with a 1.8litre, fwd, id love to swap it but for the time being id like to go turbo, a friend of mine said he can ake the manifold and use either a stock mitsu 3kgt 13b turbo, or an eclipse 14b. how much boost can i run and not blow it up with stock internals. also once the kit is on will it recognize boost??? Will an AFC be good enough to use??? Any help will be greatly appreciated.... thanks bobby
Bobby321 is offline   Reply With Quote
Old 06-08-2002, 08:39 PM   #2
RaceCarRiot
Member#: 6542
1997 Ver IV
check out www.uniquemotorsports.com/subachad
that should give you all the info you need.
RaceCarRiot is offline   Reply With Quote
Old 06-09-2002, 02:29 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
If I were you, i'd throw like 15psi or so into that thing... screw if it blows up, 1.8's are cheap
Old 06-09-2002, 03:34 AM   #4
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
With a good aftermarket engine management, I would think the 1.8L could take about 12psi. With a good turbo, rrfpr, fuel pump, intercooler... about 7psi on pump gas.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 06-09-2002, 10:55 AM   #5
Bobby321
Member#: 19774
well now that u say that it might take about 12psi... how much horsepower do u think that it will make????
Old 06-09-2002, 11:51 AM   #6
XT6Wagon
Member#: 524
04 STi
You do realise that an EJ-25 Long block is likely cheaper, and just about as much power as a mild Turbo 1.8?
Then you can start from the much better EJ-25 base later when you go turbo.
XT6Wagon is offline   Reply With Quote
Old 06-10-2002, 01:38 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Why not be unique?
Plus, the 1.8 might be capable of higher revs with its smaller displacement... If we could just get past this damn 6000 redline
Old 06-10-2002, 01:56 AM   #8
XT6Wagon
Member#: 524
04 STi
Sure the 1.8L could rev higher, if you could get a valve train to take it. Even so a EJ20 or EJ22 should be good for atleast 10K on a off the shelf built bottom end. (stock block, regular production aftermarket pistons and rods).
Even the EJ-25 has a very short stroke compared to such high reving motors as the B18C5, so even the marginal R/S ratio doesn't both its ablity to rev.
Old 06-10-2002, 12:36 PM   #9
subachad
Member#: 8488
Teal
the ej25 thing is a good point. Even with the boost, I'm only a little faster than a new Mustang GT. On the other hand, if you get a turbo kit now, you could drop a 2.2L turbo motor in later and have a kickass setup.
Chad
93 1.8T
Turbo 1.8 lil_revolution Newbies & FAQs 1 11-09-2009 11:19 AM
where to get 2.8 litre... vanillajuice Built Motor Discussion 17 08-12-2008 09:46 PM
1.8 litre is sooo slow Bobby321 Proven Power Bragging 29 09-21-2002 02:54 PM
which up-pipe for a 95 1.8 litre auto Bobby321 Normally Aspirated with bolt-on Forced Induction Powertrain 4 07-13-2002 05:51 PM
Turbo 1.8 need help Tensecgn Normally Aspirated with bolt-on Forced Induction Powertrain 26 05-23-2002 03:52 PM
