Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 05-13-2010, 11:29 PM   #1
MacSti
Member Sales Rating: (13)
Member#: 111075
2005 IWSTI Elite Mod
Default FS:(NJ) Deadbolt SZ49...May need a Rebuild...$550 shipped
For those of you who do not know, my turbo blew so I decided to upgrade. http://www.iwsti.com/forums/2802788-post1525.html My Loss is your gain because I am selling this turbo for a great price. There is almost no play in the shaft but because of an issue with my filter, some debris got past the filter and chipped up the wheel.
Asking $550
Disclaimer: This turbo may require a rebuild and may need a compressor wheel. Blouch does rebuilds starting at $349 for the basic rebuild on this turbo, so this is a steal. 1) this turbo is not being produced anymore. 2) a number of upgrades that came from Deadbolt.
I will have the turbo off the car on Friday so pics of the current condition will be posted then.
Specs:
Modified ZILLA(TM) TD06H clipped turbine wheel(FATBOY),
-49lb compressor wheel
-Monster Port(TM)
-Black Xtreme(TM) coating on turbine housing
-Red Ceramic coating on the compressor housing
-3" Inlet**
-Internally Wastegated with adjustable waste-gate spring from 15-19 lbs
** 3 inch inlet WILL require the use of Tumble Generator Valve Deletes on cars equipped with TGV's. Will also require a 3 inch inlet tube.
With appropriate modifications and tuning this turbo can sustain 30 PSI and well over 400WHP!
Some of my Dyno Charts with this turbo:
PUMP GAS 93 Octane
Deadbolt SZ49 24psi - 3 inch inlet, IWG, Fatboy wheel, APS525 FMIC, PE850, APS 70mm, Greddy EVO2 Cat Back, HKS headers, Prodrive Boost Solenoid - Tuned EFI Logics
PUMP GAS +75% Methanol
Deadbolt SZ49 24psi - 3 inch inlet, IWG, Fatboy wheel, APS525 FMIC, PE850, APS 70mm, Greddy EVO2 Cat Back, HKS headers, Prodrive Boost Solenoid, Aquamist HFS6 Methanol injection - Tuned EFI Logics
Pictures from when I received it back from Deadbolt 2 Years ago.
Asking $550
PM me with any questions if you have them.
~Mac
MacSti is offline   Reply With Quote
Old 05-19-2010, 08:47 AM   #2
MacSti
Member#: 111075
Wednesday Bump!
Old 05-20-2010, 08:43 AM   #3
MacSti
Member#: 111075
First one to offer $550 gets it!
Old 05-20-2010, 01:15 PM   #4
Izero
Member Sales Rating: (6)
Member#: 121332
2004 STi
Platinum Silver Metallic
GLWS... wish it didn't need a rebuild
Izero is offline   Reply With Quote
Old 05-20-2010, 01:20 PM   #5
MacSti
Member#: 111075
I would be happy to send it to Blouch instead of the buyer for whomever buys it. But since your in NJ, I would be happy to meet up with you and show it to you. I am willing to negotiate but $550 shipped is very fair considering a basic rebuild is $375 from Blouch. The custom compressor wheel is $275.
I will be honest in saying, now that I know I had a engine issue with the car (Head Gasket), the turbo may not need a rebuild.
Old 05-20-2010, 01:26 PM   #6
MacSti
Member#: 111075
Old 05-20-2010, 01:48 PM   #7
Izero
Member#: 121332
2004 STi
what makes you think it needed a rebuild in the first place if you don't mind me asking?
Old 05-20-2010, 01:54 PM   #8
MacSti
Member#: 111075
It all goes back a while...
A few months ago, when I went into boost, I would get a bunch of blue smoke emitting out of my exhaust and a good amount of Oil Loss when I was hammering on it. Took it to EFI to have some other work done and for them to check it out. Compression tests checked out fine and was still producing GREAT power, so we were all stumped on what it was. The only culprit it could of been was the turbo because my A/O seperator was not really wet at all.
I purchased an ATP3076 and had EFI do the entire install and during the first pull on the dyno with less boost then I had before, Blew the headstuds sending coolant out of the overflow.
That being said, I have been getting minor issues with the coolant before this but didn't put 2 and 2 together. Looking back on it, I am thinking that it wasn't the turbo at all and was the engine the entire time.
The compressor wheel has some nicks on it from an issue with my 70mm intake and the cover coming off allowing some debris to enter the compressor side. Would it be safe to run without doing anything, I think so because my issue ended up being a head stud issue, not turbo.
Old 05-20-2010, 02:18 PM   #9
Chris05STi
Member Sales Rating: (40)
Member#: 88248
2005 Subaru STi
^That may be the issue - your head bolts lifting causing that problem. Honestly, this is a great price for a turbo that is capable for 400+whp. This would be the perfect time in sending it in to Blouch and having them upgrade it so you could make 450+whp. I have my SZ55 Deadbolt turbo with 0 issues, she put 412whp on a mustang dyno before my head bolts lifted, oh that was with the Aquamist HFS-6 and just putting the baseline with no added tuning! Should be good for 500+whp no problem. Steve good luck with the sale, at that price, its going to go by QUICK!
Chris05STi is offline   Reply With Quote
Old 05-22-2010, 12:22 AM   #10
MacSti
Member#: 111075
Bump!
Old 05-23-2010, 08:38 PM   #11
MacSti
Member#: 111075
Bump!
Old 05-25-2010, 01:13 PM   #12
MacSti
Member#: 111075
Bump for a great turbo.
Old 05-26-2010, 01:19 PM   #13
MacSti
Member#: 111075
Wednesday Bump!
Old 06-07-2010, 11:31 PM   #14
MacSti
Member#: 111075
Bump!
Old 06-14-2010, 12:01 AM   #15
MacSti
Member#: 111075
Bump!
Old 06-17-2010, 10:18 AM   #16
MacSti
Member#: 111075
Thursday Bump!
Old 06-27-2010, 10:11 PM   #17
MacSti
Member#: 111075
Bump!
Old 06-29-2010, 10:30 PM   #18
MacSti
Member#: 111075
Sold!!!
FS/NJ: Deadbolt SuperZilla SZ49 Turbo 0miles freelifetime rebuilds intpostman23 Engine/Power/Exhaust 12 01-26-2009 01:23 PM
FS/NJ: Deadbolt SuperZilla SZ49 Turbo 0miles freelifetime rebuilds intpostman23 Engine/Power/Exhaust 28 09-16-2008 04:02 PM
Wtt: My Deadbolt sz49 for Your Deadbolt 18g spooln04 Private 'For Sale' Classifieds 13 05-26-2006 07:45 PM
deadbolt sz49 RichWRX Private 'Wanted' Classifieds 2 06-09-2005 08:40 AM
Deadbolt SZ49 ECUTek tuned!!!! ami2fst4u Proven Power Bragging 20 01-08-2005 07:23 PM
