Old 05-13-2010, 11:41 PM   #1
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
Default aftermarket taller 5th gear?
i am considering upgrading 1-4 in my 5spd but i want to know if there are any options as far as a taller 5th gear or changing the pinion/ring gear. i would like the 1-4 to auto cross with/ have fun but i would also like to see less than 3krpm when cruising in 5th at 75-80mph. do any of you have any advice on this other than a 6spd swap? thanks for any suggestions
jam69007 is offline   Reply With Quote
Old 05-13-2010, 11:44 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
TALLER?????
the bloody 5th is already a WAY overdrive at .738
****ing 4th is .972
are you nuts???
taller tires
Old 05-14-2010, 12:03 AM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
There are no taller 5th gears. You could go 3.7 final instead of your 3.9, but that will definitely change 1-4.
Concillian is offline   Reply With Quote
Old 05-14-2010, 02:10 AM   #4
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
Who sells a ring and pinion to change it to a 3.7 final drive?
What the heck is wrong about wanting to upgrade my gears AND get better gas mileage when cruising?
Old 05-14-2010, 07:10 AM   #5
carnz-pj-410
Member#: 110994
Old japanese cars
are the best
oem 06-07 wrx R&P is 3.70
carnz-pj-410 is offline   Reply With Quote
Old 05-14-2010, 08:16 AM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
To change your final drive would cost $XXXX so doing so would be super moronic. LISTEN to Uncle Scotty. Get some taller tires to change your APPARENT final drive, read the Transmission FAQ for how to change your final drive as there are calcualtors in there to do it smartly. Using this method, your autocross wheels/tires would be great and your street wheels/tires would be great for MPG.
Taller 5th gear for 5MT? BadTrip Transmission (AT/MT) & Driveline 49 06-17-2008 10:09 PM
Taller 5th gear for 04 FXT 5M? Seayak Transmission (AT/MT) & Driveline 13 05-03-2006 12:16 AM
WRX 5MT: Taller 5 Gear? kellie00 Transmission (AT/MT) & Driveline 0 04-27-2005 07:24 AM
top gear and 5th gear vids lettucemanatee Off-Topic 10 11-25-2003 01:09 AM
USA STi gets taller 5th and 6th gear Jude DeMeis STi Forum Archive 18 03-16-2003 05:42 PM
